Home » Eclipse Projects » Equinox » Mixing planner and slicer for target platforms?
Mixing planner and slicer for target platforms? [message #517745] Mon, 01 March 2010 17:03
when configuring provisioned target platforms, I stumbled upon the restriction that you
cannot mix the slicer -> include all environments and planner -> include required software
options. Is this intentional? Couldn't the planner also include all environments? Couldn't
there be at least some sites being sliced and some sites planned in the same target
(currently you can only use slicer XOR planner in the same target platform)? Problem with
the current situation is, if you want to setup a cross-platform-target platform you end up
with listing every dependent bundle/IU yourself - a little bit of help from the planner
would be helpful here :)
Greetings,
Ralf
http://www.ralfebert.de/blog/eclipsercp/
Previous Topic:Publisher Problem with 3.6M5
Next Topic:Browser for installable units in a metadata repository?
Current Time: Sat Jul 19 03:56:30 EDT 2025
Powered by FUDForum. Page generated in 1.04684 seconds
