Re: Adding origin [message #517702 is a reply to message #516282] |
Mon, 01 March 2010 13:42  |
Hi Chris,
thanks for the info. I did open Bug
https://bugs.eclipse.org/bugs/show_bug.cgi?id=304182 for this feature
request.
Cheers, Lars
On 23.02.2010 05:50, Chris wrote:
> currently you can't do that from the plugin. You have to use command
> line tools or edit your .git/config file directly. When you fetch or
> push with the plugin you can specify a custom URL (here you could enter
> your github url) but AFAIK this URL is not persisted and the next time
> you want to contact the same remote again you would have to specify the
> URL again.
> Ciao
> Chris
Re: Adding origin [message #577717 is a reply to message #514011] |
Tue, 23 February 2010 08:50  |
currently you can't do that from the plugin. You have to use command line tools or edit your .git/config file directly. When you fetch or push with the plugin you can specify a custom URL (here you could enter your github url) but AFAIK this URL is not persisted and the next time you want to contact the same remote again you would have to specify the URL again.
Ciao
Chris
Re: Adding origin [message #577743 is a reply to message #577717] |
Hi Chris,
request.
Cheers, Lars
> URL again.
> Ciao
> Chris
FUDForum. Page generated in 0.03528 seconds
