Re: ProgressMonitor "always run in background" problem [message #517055 is a reply to message #517024] |
Thu, 25 February 2010 12:52   |
actually, the post you mentioned exactly suggests this, to set a persistent setting :).
WorkbenchPlugin.PlatformUI.getPreferenceStore().setValue( IPreferenceConstants.RUN_IN_BACKGROUND, false );
Doing this will cause a warning, because this is workbench internal. I'm using this in my application
as well and it works. but it is really ugly, of course. so if someone knows a better way i'd be glad to hear
about it.
greetings,
-ben
Am 25.02.2010 20:04, schrieb alopecoid@gmail.com:
> I recently checked "Always run in background" for the "Progress" view. I
> would like to undo this. How can this be accomplished?
> From your previous post, you point to a thread that states that I would
> have to edit the Eclipse code to do this? That doesn't make sense to me.
> At most I would think that I would have to change some persistent
> setting somewhere. But edit the code?!?!
> Thank you.
Re: ProgressMonitor "always run in background" problem [message #517741 is a reply to message #517722] |
Mon, 01 March 2010 12:00   |
Window -> Preferences -> General -> uncheck 'always run in background'
I'm just wondering, it seems that this has nothing to do with RAP in particular.
I thought you were refering to a self-build RAP application, i guess that's why
you got the 'codebase' answers.
For questions about the Eclipse IDE itself you should consider asking in the Eclipse
User-Boards, since this is a newsgroup especially for Rich-Ajax-Platform developers.
So most probably you'll get a developer answer here ;)).
HTH,
-ben
Am 01.03.2010 21:18, schrieb alopecoid@gmail.com:
> Rüdiger Herrmann wrote on Mon, 01 March 2010 12:48
>> This setting can be changed in the WorkbenchPreferencePage.
> Would you mind telling me exactly how to navigate to this page? I can't
> seem to find it anywhere.
> Just to clarify, I am not an Eclipse developer... I know next to nothing
> about the Eclipse codebase. It seems that you are referring me to a
> class name when you write something like "WorkbenchPreferencePage".
> I am looking for something more like:
> Go to: Window > Preferences > Some Section > Some Other Section. Once
> there, it's the checkbox labeled "something".
> Thank you!
FUDForum. Page generated in 0.04450 seconds
