Home » Archived » Test and Performance Tools Platform (TPTP) » PrivilegedActionException when using TPTP(PrivilegedActionException when using TPTP)
PrivilegedActionException when using TPTP [message #517075] Fri, 26 February 2010 00:24 Go to next message
I'm using TPTP 4.6.1 with Galileo, running Tomcat 6 inside of Eclipse, and I'm getting a PrivilegedActionException in my code when monitoring with TPTP. The exception happens when I try to do dozer mapping, which attempts to use reflection. I don't have security enabled on the server properties page. The exception only occurs when monitoring is on. If I pause monitoring, it works fine.
[Updated on: Fri, 26 February 2010 12:17] by Moderator
Re: PrivilegedActionException when using TPTP [message #517659 is a reply to message #517075] Mon, 01 March 2010 10:53 Go to previous message
Hi Keith,
Could you try configure the profiling filter such that the involvled class
and pacakges is filter out and see if you continue the profile without
having the error?
Eugene
"Keith H" <khamburg@gmail.com> wrote in message
news:hm7lu7$ej9$1@build.eclipse.org...
Previous Topic:DatapoolSuggestedType with "valueOjbectExtension" and "valueObjectValidatorExtension&
Next Topic:Object Allocation analysis on JVM 1.5
Current Time: Sun Jul 27 04:13:49 EDT 2025
Powered by FUDForum. Page generated in 0.04074 seconds
