Storing data in database directly from the report [message #517618] |
Mon, 01 March 2010 09:41  |
Is there a possibility (and if yes - any samples, links or hints?) to execute insert or update queries on some database directly from the report after generation? It may require some additional classed, of course. What I want to achieve is to store some calculations' results from heavy reports and use them in other reports. Ideally I would like to retrieve database connection directly from some data source, so it's wouldn't require separate connection definition (but it's, of course, not necessary, any insert/update possibility would do).
Darek
Re: Storing data in database directly from the report [message #517672 is a reply to message #517618] |
Mon, 01 March 2010 11:22  |
Darek,
Re-using the connection can be problematic. If you passed in the
connection it should be easy to reuse. To implement the insert you need
to create a Java or JavaScript handler in the afterFactory event and
have it make the connection, insert, and close the connection. Take a
look at the scripting page for details on event handlers.
http://www.eclipse.org/birt/phoenix/deploy/reportScripting.p hp
Jason
Dariusz Filipski wrote:
> Cheers,
> Darek
FUDForum. Page generated in 0.30419 seconds
