Home » Eclipse Projects » Eclipse 4 » Unable to get SWT Flex examples (want to port GEF app to web)(CVS error: java.io.IOException: proxy error: Forbidde)
Re: Unable to get SWT Flex examples (want to port GEF app to web) [message #517712 is a reply to message #517483] |
Mon, 01 March 2010 14:28   |
I can download everything from home. There are two documents that are almost identical:
http://www.eclipse.org/e4/development/readme/readme_e4_0.9.h tml#R-Demos-Flex
and
http://wiki.eclipse.org/E4/SWT/Running_the_demos
The main difference is that the first wants a download from a branch, R0_9, and the second doesn't mention this. Either way, I get the errors described below.
I've got e4, version 0.9, with ActionScript Developer, Flex (with -Dflex.sdk=C:/Flex in eclipse.ini), Java 1.6, and the following items listed in Package Explorer:
org.eclipse.draw2d
org.eclipse.e4.swt.releng (I've imported the project sets)
> org.eclipse.swt (not compiling)
org.eclipse.swt.e4
org.eclipse.swt.e4.examples
org.eclipse.swt.e4.jcl
>org.eclipse.swt.examples (not compiling, dependent on org.eclipse.swt)
I've followed the instructions down to "Get the demos". I've renamed .classpath_flex to .classpath in the org.eclipse.swt.examples project..
When I build (or clean with Build Automatically on), I get 19 errors, of which 15 are
Package 'org.eclipse.swt.awt' does not exist in this plug-in /org.eclipse.swt/META-INF line 12 Plug-in Problem
Package 'org.eclipse.swt.examples.accessibility' does not exist in this plug-in MANIFEST.MF /org.eclipse.swt.examples/META-INF line 10 Plug-in Problem
(and 13 more like #2;)
Draw2d, swt.e4.examples, and swt.examples "cannot be build until [their] prerequisite org.eclipse.swt is built, and, finally
The project was not built since the source file /org.eclipse.swt/Eclipse SWT/flex/org/eclipse/swt/widgets/Widget.java could not be read
That's because the directory org.eclipse.swt/Eclipse SWT has no flex subdirectory (although it has cairo, carbon, cocoa, etc., including Win32 - I'm compiling on WinXP (ugh).
Is this simply a missing file? Or did I screw up at an earlier step?
Anything anyone can suggest would be greatly appreciated.
Current Time: Sat Jul 26 11:34:13 EDT 2025
Powered by FUDForum. Page generated in 0.06087 seconds
