Home » Modeling » UML2 Tools » Reverse engineering with eclipse modelling
Reverse engineering with eclipse modelling [message #517366] Sat, 27 February 2010 04:25 Go to next message
Hello user's of the forum. I'm a newbye forumers and I have a question.
I read other topic about some eclipse plugin, like omondo, that permitted reverse engineering, like create UML class or sequence diagram from existing java class.
My problem instead is this: I must write an eclipse tutorial about Eclipse Modeling Project and in particular I must describe how do reverse engineering with only this envervoiment?
I can't use another envervoiment or additional plugin, only Eclipse Modeling Tool (367MB of download for understand).
There is a way for do reverse engineering of only class and sequence diagram from original java code?
Sorry for the bad english.
Thank you for the answer.
Re: Reverse engineering with eclipse modelling [message #517388 is a reply to message #517366] Sat, 27 February 2010 07:47 Go to previous messageGo to next message
--------------050007030904090507060805
Marco,
I think MoDisco is the closest thing to what you're asking about:
http://www.eclipse.org/gmt/modisco/
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Marco,<br>
<br>
I think MoDisco is the closest thing to what you're asking about:<br>
<blockquote><a href="http://www.eclipse.org/gmt/modisco/">http://www.eclipse.org/gmt/modisco/</a><br>
</blockquote>
<br>
Marco R. wrote:
<blockquote cite="mid:hmaoeq$fhr$1@build.eclipse.org" type="cite">Hello
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
</blockquote>
</body>
</html>
--------------050007030904090507060805--
Re: Reverse engineering with eclipse modelling [message #517396 is a reply to message #517366] Sat, 27 February 2010 09:18 Go to previous messageGo to next message
Thank's for the answer.So i can't do reverse engineering with only the envervoimnet of eclipse modelling?
Re: Reverse engineering with eclipse modelling [message #517410 is a reply to message #517396] Sat, 27 February 2010 10:20 Go to previous messageGo to next message
Marco,
I pointed you at a project that's part of Eclipse modeling; did you have
a look?
Re: Reverse engineering with eclipse modelling [message #517435 is a reply to message #517410] Sat, 27 February 2010 18:01 Go to previous messageGo to next message
RIght Ed Merks,
Now I have understand. Thnak' you for all.
I generate the class diagram...but there is a procedure for generate a sequence diagram of an operation class?
I don't understand how. Can you help me for the last time?
Thank you another time.
Re: Reverse engineering with eclipse modelling [message #517440 is a reply to message #517435] Sat, 27 February 2010 14:00 Go to previous messageGo to next message
Marco,
MoDisco has its own newsgroup/forum. I've added it to the "to" list of
this reply. I don't know if there is a mechanism in MoDisco for
generating a sequence diagram; probably not.
Marco R. wrote:
> RIght Ed Merks,
Re: Reverse engineering with eclipse modelling [message #517573 is a reply to message #517440] Mon, 01 March 2010 06:34 Go to previous messageGo to next message
Hi Marco, Hi Ed,
I wrote a response about MoDisco existing features on MoDisco newsgroup.
Re: Reverse engineering with eclipse modelling [message #625504 is a reply to message #517396] Sat, 27 February 2010 10:20 Go to previous messageGo to next message
Marco,
a look?
Re: Reverse engineering with eclipse modelling [message #625505 is a reply to message #517410] Sat, 27 February 2010 18:01 Go to previous messageGo to next message
RIght Ed Merks,
Re: Reverse engineering with eclipse modelling [message #625506 is a reply to message #625505] Sat, 27 February 2010 18:47 Go to previous messageGo to next message
Marco,
Marco R. wrote:
> RIght Ed Merks,
Re: Reverse engineering with eclipse modelling [message #625511 is a reply to message #625506] Mon, 01 March 2010 06:35 Go to previous message
Hi Marco, Hi Ed,
Fabien GIQUEL
R&D Engineer
Mia-Software
4, rue du Château de l'Eraudiere
44324 NANTES CEDEX 03
Previous Topic:Reverse engineering with eclipse modelling
Next Topic:Stereotype image always displays as yellow triangle w/ exclamation point
Current Time: Sat Jul 26 11:35:29 EDT 2025
Powered by FUDForum. Page generated in 0.11848 seconds
