Home » Archived » Buckminster » "Unable to acquire application service" on Mac OS X
"Unable to acquire application service" on Mac OS X [message #517230] |
Fri, 26 February 2010 11:10  |
I just ran into a little problem when running Buckminster on Mac OS X,
just thought I should post a note about it in case somebody else runs
into this.
When starting Buckminster it failed with this exception in the log:
!SESSION 2010-02-26 16:59:50.552
eclipse.buildId=unknown
java.version=1.6.0_15
java.vendor=Apple Inc.
BootLoader constants: OS=macosx, ARCH=x86_64, WS=carbon, NL=de_DE
Framework arguments: help
Command-line arguments: help
!ENTRY org.eclipse.osgi 4 0 2010-02-26 16:59:52.200
!MESSAGE Application error
!STACK 1
java.lang.IllegalStateException: Unable to acquire application service.
Ensure that the org.eclipse.core.runtime bundle is resolved and started
(see config.ini).
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:74)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at
sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at
at
at
java.lang.reflect.Method.invoke(Method.java:597)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
I guess the problem is the combination ARCH=x86_64, WS=carbon which was
guessed automatically, when I explicitly specified these when
installing Buckminster this fixed the problem:
../director -r
http://download.eclipse.org/tools/buckminster/headless-3.5/ -d
/Users/ralf/jobs/re_builds/buckminster35/ -p Buckminster -i
org.eclipse.buckminster.cmdline.product -p2.os macosx -p2.ws cocoa
-p2.arch x86_64 -p2.nl en
Greetings,
Ralf
http://www.ralfebert.de/blog/
Re: "Unable to acquire application service" on Mac OS X [message #517243 is a reply to message #517230] |
Fri, 26 February 2010 11:20   |
Hi Ralf,
Thanks for sharing this info. It should go into the "troubleshooting" section of our docs. I've seen other types of
strange guesses before (motif instead of swt typically).
- thomas
On 02/26/2010 05:10 PM, Ralf Ebert wrote:
> into this.
> !STACK 1
> (see config.ini).
> at
> at
> at
> at
> at
> at
> at
> guessed automatically, when I explicitly specified these when installing
> ../director -r
> Greetings,
> Ralf
Re: "Unable to acquire application service" on Mac OS X [message #538024 is a reply to message #535846] |
Fri, 04 June 2010 10:31   |
QuadBox:director maarten$ ./director -r http://download.eclipse.org/tools/buckminster/headless-3.5/ -p Buckminster -i org.eclipse.buckminster.cmdline.product -d /Library/Java/Development/buckminster/ -p2.os macosx -p2.ws cocoa -p2.arch x86_64 -p2.nl en
Installing org.eclipse.buckminster.cmdline.product 1.1.350.r11146.
Operation completed in 3798 ms.
So far it works
QuadBox:buckminster maarten$ ./buckminster install http://download.eclipse.org/tools/buckminster/headless-3.5/ org.eclipse.buckminster.aggregator.engine.feature -consoleLog
!SESSION 2010-06-04 16:23:14.266 -----------------------------------------------
java.version=1.6.0_20
BootLoader constants: OS=macosx, ARCH=x86_64, WS=carbon, NL=nl_NL
Framework arguments: install http://download.eclipse.org/tools/buckminster/headless-3.5/ org.eclipse.buckminster.aggregator.engine.feature
Command-line arguments: install http://download.eclipse.org/tools/buckminster/headless-3.5/ org.eclipse.buckminster.aggregator.engine.feature -consoleLog
!ENTRY org.eclipse.osgi 4 0 2010-06-04 16:23:15.191
!STACK 1
java.lang.RuntimeException: No application id has been found.
at org.eclipse.equinox.internal.app.EclipseAppContainer.startDe faultApp(EclipseAppContainer.java:236)
at org.eclipse.equinox.internal.app.MainApplicationLauncher.run (MainApplicationLauncher.java:29)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
QuadBox:buckminster maarten$ ./buckminster -application org.eclipse.buckminster.cmdline.product install http://download.eclipse.org/tools/buckminster/headless-3.5/ org.eclipse.buckminster.aggregator.engine.feature -consoleLog
!SESSION 2010-06-04 16:27:11.293 -----------------------------------------------
Framework arguments: -application org.eclipse.buckminster.cmdline.product install http://download.eclipse.org/tools/buckminster/headless-3.5/ org.eclipse.buckminster.aggregator.engine.feature
Command-line arguments: -application org.eclipse.buckminster.cmdline.product install http://download.eclipse.org/tools/buckminster/headless-3.5/ org.eclipse.buckminster.aggregator.engine.feature -consoleLog
!ENTRY org.eclipse.osgi 4 0 2010-06-04 16:27:12.324
!STACK 1
java.lang.RuntimeException: Application "org.eclipse.buckminster.cmdline.product" could not be found in the registry. The applications available are: org.eclipse.buckminster.cmdline.headless, org.eclipse.equinox.app.error, org.eclipse.equinox.p2.artifact.repository.mirrorApplication , org.eclipse.equinox.p2.director.app.application, org.eclipse.equinox.p2.director, org.eclipse.equinox.p2.garbagecollector.application, org.eclipse.equinox.p2.metadata.repository.mirrorApplication , org.eclipse.equinox.p2.publisher.InstallPublisher, org.eclipse.equinox.p2.publisher.ProductPublisher, org.eclipse.equinox.p2.publisher.FeaturesAndBundlesPublisher , org.eclipse.ant.core.antRunner, org.eclipse.update.core.standaloneUpdate, org.eclipse.update.core.siteOptimizer, org.eclipse.equinox.p2.updatesite.UpdateSitePublisher, org.eclipse.equinox.p2.publisher.UpdateSitePublisher, org.eclipse.equinox.p2.publisher.CategoryPublisher, org.eclipse.jdt.core.JavaCodeFormatter, org.eclipse.pde.build.Build, org.eclipse.buckminster.aggregator.
QuadBox:buckminster maarten$ ./buckminster -application org.eclipse.buckminster.cmdline.headless install http://download.eclipse.org/tools/buckminster/headless-3.5/ org.eclipse.buckminster.aggregator.engine.feature -consoleLog
!SESSION 2010-06-04 16:27:36.687 -----------------------------------------------
Framework arguments: -application org.eclipse.buckminster.cmdline.headless install http://download.eclipse.org/tools/buckminster/headless-3.5/ org.eclipse.buckminster.aggregator.engine.feature
Command-line arguments: -application org.eclipse.buckminster.cmdline.headless install http://download.eclipse.org/tools/buckminster/headless-3.5/ org.eclipse.buckminster.aggregator.engine.feature -consoleLog
Somehow the default application is not copied into the executable or some ini file, but I'm to much of a p2/osgi newbie to resolve this.
Re: "Unable to acquire application service" on Mac OS X [message #545181 is a reply to message #540557] |
Tue, 06 July 2010 20:31  |
Scott,
I just tried this and was able to resolve. Make sure that you delete the buckminster directory before attempting to do this. Also, don't make my initial mistake -- the p2 arguments go on the original director call, not the install -- buckminster won't complain about those because it fails with the first issue before it gets there.
Scott Anderson wrote on Wed, 16 June 2010 10:14 | I'm experiencing this as well using buckminster headless 3.6...
Here is error log
!SESSION 2010-06-16 10:10:09.857 -----------------------------------------------
BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=en_US
Framework arguments: import -Dxxx.home=/Volumes/Secure/src/xxx /Volumes/Secure/src/xxx/projects/xxxx.site/site.cquery
Command-line arguments: -data /Volumes/Secure/src/xxx/dist/workspace import -Dxx=/Volumes/Secure/src/xx /Volumes/Secure/src/xx/projects/xxx.site/site.cquery
!ENTRY org.eclipse.osgi 4 0 2010-06-16 10:10:10.622
!STACK 1
java.lang.IllegalStateException: Unable to acquire application service. Ensure that the org.eclipse.core.runtime bundle is resolved and started (see config.ini).
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:74)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
Current Time: Sun Jul 27 14:08:30 EDT 2025
Powered by FUDForum. Page generated in 0.25453 seconds
