Home » Archived » B3 » Aggregator with version range support
Aggregator with version range support [message #517009] |
Thu, 25 February 2010 12:21  |
I'd like to discuss the algorithm how the aggregator should resolve IU requests. This post is rather long but I wanted to express in detail what the problem is all about. I will appreciate you spending some time on it and helping me find a solution.
Background:
Let's have following aggregation definition:
Contribution A (contributed by user A)
+ Mapped Repository R1
+ IU Request: id=org.eclipse.myframework; version>=1.0.0
Contribution B (contributed by user B)
+ Mapped Repository R2
+ IU Request: id=org.eclipse.something.different; version>=1.0.0
Repository R1 contains:
org.eclipse.myframework/0.9.0.v20070415
org.eclipse.myframework/1.0.0.v20080105
org.eclipse.myframework/1.1.0.v20091220 (this is what user A expects)
Repository R2 contains:
org.eclipse.myframework/1.2.0.beta_for_testing_only (this is what user A does not expect and does not want at all)
org.eclipse.something.different/2.5.1.v20100225 (this is what user B expects)
Now, what is the expected result? I think that a user would think probably like this:
The contribution "A" yields a version of "org.eclipse.myframework" that is the best from repository R1 and is not in conflict with any other contribution at the same time.
Since "org.eclipse.myframework" is not mapped in any other contribution, the natural resolution of it is "org.eclipse.myframework/1.1.0.v20091220".
The contribution "B" yields a version of "org.eclipse.something.different" that is the best from repository R1 and is not in conflict with any other contribution at the same time.
Since "org.eclipse.something.different" is not mapped in any other contribution, the natural resolution of it is "org.eclipse.something.different/2.5.1.v20100225".
The aggregated repository will contain:
OK?
However, the new aggregator (with version range support) will create an aggregated repository containing:
The reason why "1.2.0.beta_for_testing_only" was chosen is simple: We use a request accross all repositories, regardless where the IU was mapped.
In my view, this is bad.
That's why I tried to change the algorithm:
For each IU request
1) Resolve the request against its parent mapped repository (first level only, no dependencies) and get a set of matching resolutions
2) Create a modified IU request that defines the IU name and version enumeration (of matching resolutions) instead of the original version range
3) Provide the modified request to the global aggregated repository processing
This way, only IUs that are really present in appropriate mapped repository may be passed to the final resolution.
So far so good, but the problem is that the only implementation of IRequirement is the RequiredCapability which does not support version constraints different from version ranges.
As a proof of concept, I tried to hack this all so that the interim repository supports another implementation of IRequirement with more complex version constraints. It works as expected!
Finally, the questions to answer:
1) Do you think that this approach is nature/logical, i.e. is it how it should work?
2) If the answer to 1) is YES, then we need to think about how to do it without too much hacking (I can provide more details on what all I had to do and what I don't like on the "hacking solution")
Current b3 aggregator (available on the b3 update site) uses the "hacking solution" which should later be removed or replaced with something better. This is now there for testing purpose only.
The cleanest solution would be to suggest support for complex version constraints in any p2 repository, but I am afraid that it would be a big problem because of compatibility (old p2 clients would not be able to read all new p2 repos).
PS: Support for complex version constraints would allow us to implement what Henrik has mentioned in one of our discussions - "User wants to map versions from 1.0.0 to 2.0.0 but not 1.3.4 which is known to be buggy"
Thanks for your patience, comments, questions and ideas :-)
Best regards
Filip
Re: Aggregator with version range support [message #517083 is a reply to message #517009] |
Fri, 26 February 2010 02:01   |
Hi Filip,
Some comments inline.
On 02/25/2010 06:21 PM, Filip Hrbek wrote:
> Hello,
> Background:
> expects)
> probably like this:
> OK?
No, I don't think that's OK. If the user is unhappy with versions of the framework that is above 1.1.0, then that should
be stated in contribution A. If the range is open-ended, then A has explicitly declared that 1.2.0 is an OK replacement.
Which seems OK, given the circumstances.
Try another use-case:
Contribution A is exactly as in your example. Contribution B contains updates contains a limited subset of newer
versions of bundles also found in contribution A. This can easily happen if A is a release and the combination of A and
B is a service release.
In my view, this is good and indeed necessary.
> For each IU request
> processing
Why is the IU found in the same repository more "appropriate" then an IU found in another? I can see that for some
specific use-case that might be the case, but it's not a general truth.
> should work?
No. I think this is wrong. I think the right approach must be to consciously insert a rule that limits the dependency.
It should not be automatic.
- thomas
Re: Aggregator with version range support [message #517089 is a reply to message #517083] |
Thu, 25 February 2010 22:44   |
Hi Thomas,
thanks for your comments.
I understand what you mean. It is also very easy to implement what you suggest, but I have a different view on the problem.
I understand the "contribution" as a unit which someone is responsible for. When I talk about responsibility, I mean that the one who contributes also guarantees that only approved versions from his approved source may be included (new aggregator also shows these versions interactively in the mapping).
You are right that sometimes it would be good to include "service packs" above "releases". IMHO it should not be automatic though. I would rather see a little change in the model to achieve this - to allow map repositories as virtual composites:
+ Mapped Repository - Virtual Composite of [R1,R2]
This would be the conscious rule to add more available (approved) resolutions. The basic idea is "be strict by default, allow being less strict on user's conscious action".
I'd like to see more people contributing to this discussion to avoid an endless dialog of two hard-headed guys :-)
Filip
Thomas Hallgren wrote:
> Hi Filip,
>> Hello,
>> Background:
>> expects)
>> probably like this:
>> OK?
> framework that is above 1.1.0, then that should be stated in
> updates contains a limited subset of newer versions of bundles also
> the combination of A and B is a service release.
>> mapped.
>> For each IU request
>> range
>> processing
> found in another? I can see that for some specific use-case that might
>> should work?
> consciously insert a rule that limits the dependency. It should not be
> automatic.
> - thomas
Re: Aggregator with version range support [message #517100 is a reply to message #517089] |
Fri, 26 February 2010 04:08   |
Hi Filip,
What do you propose should happen if contribution A contains:
org.eclipse.myframework/1.1.0.alpha
and contribution B contains:
org.eclipse.myframework/1.1.0.final
What algorithm is used to determine the best one?
- thomas
On 02/26/2010 09:30 AM, Filip Hrbek wrote:
> Hi Thomas,
> Filip
>> Hi Filip,
>>> Hello,
>>> Background:
>>> expects)
>>> probably like this:
>>> OK?
>> the framework that is above 1.1.0, then that should be stated in
>>> mapped.
>>> For each IU request
>>> range
>>> processing
>> IU found in another? I can see that for some specific use-case that
>>> should work?
>> automatic.
>> - thomas
Re: Aggregator with version range support [message #517111 is a reply to message #517106] |
Fri, 26 February 2010 04:59   |
>>> Hi Filip,
>> If there is no intersection of resolutions from contributions A and B,
>> then this is a conflict.
> I assume the same scenario as you outlined in your first post. The only
> difference is that in B, it's not a beta, it's a final. And in A, it's
> just alphas.
> - thomas
Then yes, the "alpha" wins. If contributor "A" discovers that a better version is available, he should add the repo to his contribution.
If you really think that what I say breaks the p2 world, well, then our model is bad! We shouldn't map things from a mapped repository.
To make what you say intuitive, then a contribution should look like this:
Contribution A
+ Repository hints
+ Repo A
+ Repo B
+ Repo C
+ Mappings
+ IU a.b.c, version >=1.0.0
+ Everything from Repo B
The "Repository hints" would serve as possible sources that the contributor "recommends" to use for the final resolution. We could also remove current "Validation repositories" since it would not make sense any more (in my example, "Repo C" is actually a validation repository since nothing is mapped in contribution A).
With such a model, I could agree with you. Not with current model though since it is very confusing - one thinks he maps something within the resolution scope of the mapped repository but he may get unexpectedly something else.
Filip
Re: Aggregator with version range support [message #517115 is a reply to message #517111] |
Fri, 26 February 2010 00:26   |
I'm trying to map this to our current use cases. In Helios, each contribution is just a fragment of the final result
that has lot of dependencies not contained in that fragment. The contributors do this, well aware that when the
aggregation happens, everything will be there. The contribution inter-dependencies are very intentional.
Miles at MS first creates a big aggregation containing a lot of things from Galileo and other places. He then uses this
as a contribution when he creates the final aggregation together with other contributions that contains all in-house
developed features. He is well aware that the in-house contributions all have inter-dependencies and that they depend
heavily on the aggregation he created in the first step.
Not sure what you mean by that. How else can we map things?
> Contribution A
> + Repository hints
> + Repo A
> + Repo B
> + Repo C
> + Mappings
That assumes that all contributions are self sufficient. And sure, there are perhaps use-cases where this could be good.
I haven't seen them yet though. On the contrary, the use-cases at hand always have contributions that depend on other
contributions.
> something else.
Really? I have never made that assumption. We create a verified aggregation and of course everything is verified in
scope of the aggregation. I think you put too much weight on the contribution concept.
- thomas
Re: Aggregator with version range support [message #517125 is a reply to message #517120] |
Fri, 26 February 2010 01:06   |
Hi guys,
Sorry for jumping into this discussion so late, but you truly are hard-
headed guys and are exchanging arguments at such a fast pace that I've
hardly had time to catch up ;-)
Now here's my point of view, but before you read on, please note two things:
* I'm a hard-headed guy myself ;-)
* I have no practical experience with the aggregator (yet), and my
theoretical knowledge of it is, of course, not as deep as yours.
That said, here's my use-case, and I think it supports Filip's position:
We're pulling in everything from the Galileo release site. This includes
Xtext 0.7.x. We also require one additional artifact (org.antlr) from the p2
repo hosted at itemis. This repo happens to include a 0.8.x version of
Xtext. I absolutely do *not* want that 0.8.x version to end up in my result.
Especially not if this leads to the 0.7.x version being excluded in the
result, because then I end up with a completely inconsistent repository.
(Since Xtext 0.8 requires EMF 2.6, which is not contained in Galileo).
Now if I understand you guys correctly, Thomas would argue that I would have
to explicitly exclude the 0.8.x version when fetching from the Galileo repo.
There is, however, no need to do that, because I assume the Galileo repo to
never, ever contain that version. It's only as a side-effect from pulling
org.antlr that this ends up in my result. But I could never foresee this
effect when maintaining the contribution from Galileo.
Achim
>>> this:
>>> Contribution A
>>> + Repository hints
>>> + Repo A
>>> + Repo B
>>> + Repo C
>>> + Mappings
>> are perhaps use-cases where this could be good. I haven't seen them yet
>> that depend on other contributions.
> No, you are missing the point. The contributions may transitively depend
> on other contributions of course. I just want to express what you say with
> the model - just to avoid confusion. I am still convinced that if you map
> IUs by choosing them from a mapped repository, you naturally expect to get
> them within the scope of that repository. The result must either follow
> this rule, or the model must be changed somehow (I provided a draft of a
> suggestion above).
> What my contribution depends on does not have to be included in my
> "repository hints" at all.
> Filip
Re: Aggregator with version range support [message #517134 is a reply to message #517125] |
Fri, 26 February 2010 01:30   |
Hi Achim,
you don't have to apologize for jumping into our discussion, you are welcome of course!
I am hard-headed but I am able listen to others and finally change my mind, but I prefer listening to more than one guy (Thomas - it does not mean that I don't listen to you of course). It always yields better results.
I think that your use-case exactly reflects my concern. Thomas probably knows other use-cases.
Our goal is to provide mechanisms for all of them of course. I am not against adding more options to the aggregator that would allow a user to do what he really wants.
All I want is
* to have a model that reflects reality
* to have a model that reflects user's natural thinking
* to have an engine that works in conformance with the model (not doing unexpected things)
* to have reasonable default settings (i.e. for use-cases that are fine to most users)
* to allow customization of the behavior by setting specific options/flags/rules...
I am sure we will find a solution. Again, the more opinions I collect now the better the solution will be.
Filip
Achim Demelt wrote:
> Hi guys,
> Cheers,
> Achim
Re: Aggregator with version range support [message #517139 is a reply to message #517125] |
Fri, 26 February 2010 06:29   |
On 02/26/2010 11:58 AM, Achim Demelt wrote:
> Hi guys,
Good point. You don't own the Galileo contribution. So there are three solutions to this problem:
1. The most likely one is that there is no problem. If EMF 2.6 isn't included, then the planner will give up on XText
0.8.0 and try something else. If no solution at all can be found given all input, it will give up. It will _never_
create something that is inconsistent.
2. Your aggregation fails since no resolution is possible so you (the aggregator maintainer) sees that a contribution
has a problem and report this to the contributor. The contributor must then address this problem. Perhaps by adding an
upper limit to a bundle requirement. This is what currently happens on a day to day basis when problems occur in Helios.
3. Your aggregation fails and you add a rule that is above all contributions that says "In the final result, I don't
want Xtext of higher version then 0.7.x". This rule is propagated as a constraint to the planner. This possibility does
not yet exist, but I wouldn't be adverse to adding it.
- thomas
Re: Aggregator with version range support [message #517146 is a reply to message #517139] |
Fri, 26 February 2010 06:47   |
Yes, Thomas is right here. The aggregator always yields consistent result, or it fails.
If EMF 2.6 is not available in any of mapped repositories, it will choose xtext 0.7.x.
But if EMF 2.6 is found somewhere else, you may get 0.8.x which you don't want for some reason.
In that case, you must add a version constraint to your contribution.
I think that limiting the scope of resolution for selected mapping (which does not have to be the default) would be better than adding an explicit constraint.
It should be up to each user how he wants the aggregator to behave.
We must talk about changing the model which still does not reflect the reality - that's the biggest issue here.
Filip
>> would have
>> repo.
>> repo to
> included, then the planner will give up on XText 0.8.0 and try something
> up. It will _never_ create something that is inconsistent.
Re: Aggregator with version range support [message #517155 is a reply to message #517142] |
Fri, 26 February 2010 02:14   |
Henrik, what do you think of the model?
That's what makes me worried the most. It does not reflect what the engine finally does.
I think we should concentrate on this issue now.
If you didn't want to go through all the posts, here's the summary:
- user specifies a mapped repository
- user selects a mapped UI *from* this repository (in the UI, it is a *child node* of that mapped repository)
- user specifies a version range (which may be open)
- user can check interactively which versions from that repository match his request
- user runs the aggregation
I think that user expects that the aggregation will contain one of the versions he had seen in the interactive checklist. What a surprise if there's something else?
I have suggested a change to that model so that we would avoid this confusion (see former posts).
In addition to this, I think that optional limiting of the resolution scope for explicitly added IUs would be helpful too, as well as introducing more complex version constraints than version ranges (which is another big issue).
Filip
Henrik Lindberg wrote:
> +1
> finally a description of the problem/solution that I understood the
> implications of.
> The next issue is how to make user understand what went wrong and how to
> fix it.
> - henrik
>> will give up. It will _never_ create something that is inconsistent.
>> aggregator maintainer) sees that a contribution has a problem and
>> problem. Perhaps by adding an upper limit to a bundle requirement.
>> occur in Helios.
>> contributions that says "In the final result, I don't want Xtext of
>> the planner. This possibility does not yet exist, but I wouldn't be
>> - thomas
Re: Aggregator with version range support [message #517160 is a reply to message #517155] |
Fri, 26 February 2010 02:36   |
I did read all of the posts on this subject.
It is just that I have not used the aggregator enough to have a good
feel for what would be intuitive.
When picking something from a repository, what does it mean?
a) pick things matching this requirement, and then use all available
repositories to satisfy all dependencies.
b) pick things matching this requirement from this repository, and then
use all available respositories *but* this repository to satisfy the
dependencies.
b) is good for "OMG there is all sorts of crap in there in addition to
the few things I actually do need".
When using b) it is easy to to create a non valid result, because the
thing picked from the problem repo needs more stuff not in other
repositories. The user would then need to add those explicitly until a
valid result is obtained (or gives up because of conflicts).
I can see option b) as a flag on a repo - "only pick the explicitly
requested IUs".
A question - as a user I would assume that if I request A with a range,
(from one repo, as I perceive it as a user), and there exists A's in
this range in that repo, that they are indeed included in the final
result even if there are newer versions of A in other repositories that
are mapped with other rules. Is this true?
- henrik
> his request
> Filip
>> +1
>> implications of.
>> fix it.
>> - henrik
>>> occur in Helios.
>>> - thomas
Re: Aggregator with version range support [message #517174 is a reply to message #517168] |
Fri, 26 February 2010 03:46   |
>> Nope. The planner consider all repositories as one source of input. It
>> never considers what individual repository a specific requirement
>> originated from. It will create a plan where all requirement ranges
>> are fulfilled but the actual IU's included can stem from any repository.
> ...and this it the issue!
> What Henrik stated is IMHO intuitive from the user's perspective (unless
> the user is familiar with all our discussions :-) ).
> I want to change the model at least so that a user wouldn't think that
> it would work like this. Ideally, I would add more options to change the
> behavior as needed.
> Question (to move forward):
> Is the model I suggested better or worse than current? If it is bad, why?
I think its worse because it doesn't really solve the problem. The contribution can not be the scope of resolution so
adding more repositories at that level doesn't help. The final solution may have chosen IUs from other repositories
regardless.
The validation repository needs to stay because it validates the final aggregation, not each contribution.
I think the current model is fine given the requirements. We really don't want to add more things then necessary to each
contribution. The biggest problem I see, is that we have no way of visualizing that the planner might choose an IU that
is different from what the user has in his view. The user needs to be made aware of that this can happen during
authoring (the tool should make him aware that his selection isn't necessarily resolved from the current repository) and
also when the planner induced change occur (as warning or info markers once the planning has completed).
- thomas
Re: Aggregator with version range support [message #517177 is a reply to message #517174] |
Fri, 26 February 2010 08:55   |
> contribution can not be the scope of resolution so adding more
> chosen IUs from other repositories regardless.
1) It does not have to be the scope by default but it would be interesting to have such an option (perhaps in future).
The scope (if requested) would only affect the first level, i.e. the components the user is explicitly mapping.
2) If it is *not* the resolution scope (which we talk about as the default right now), then we can't
have the selected IUs *under* the mapped repository because it is confusing. That is why I moved the
repository hints away from the mapping requests - just to make it clear.
The reason why I named the node *hints* is to make it clear that it's nothing more than a hint, i.e. which repositories
to store to the global heap of available repositories.
If the validation repository belongs to the aggregation root, why don't all mapped repositories belong there?
If they don't mean the resolution scope for mapped IUs, they should also be placed in the aggregator root
since they affect the final aggregation, not the individual mappings.
However, I think that even the validation repositories should be moved under the contribution anyway.
If someone knows that his contribution needs another repository for validation, he can freely contribute
a repository hint for validation.
> don't want to add more things then necessary to each contribution. The
> planner might choose an IU that is different from what the user has in
> necessarily resolved from the current repository) and also when the
If we change the model so that user understands that he does not choose from the mapped repository, then
I can see a simple solution. We already have an interactive list of available versions in the UI. All we need to do
is to show *all* versions from *all* repositories (not only those from contribution's hints) and also show
which repository the resolved IU comes from. Then the user is not confused - he can see all potentially valid matches of
his selection before the (long running) verification is run.
Filip
Re: Aggregator with version range support [message #517184 is a reply to message #517180] |
Fri, 26 February 2010 09:26   |
> A contributor typically contributes repositories. He optionally filters
> what should be contributed from those repositories by adding mappings.
> No mappings == everything. So of course all contributed repositories are
> listed in their respective contributions.
Of course I agree with this, although "no mappings = everything" is not
intuitive enough for me. Btw., it does not mean "everything from this repo"
since you may actually finally map something else (newer versions from other
repositories).
I came to the conclusion that all repos should
be under aggregator root using your argument - that it does not create the
resolution scope.
> The aggregator manager decides what contributions to aggregate and how
> to validate that aggregation. The validation has nothing to do with each
> contribution. The contributions are neither self sufficient and not
> validated. Validation is on the aggregation as a whole and thus, cannot
> be in a contribution.
Really? Why?
I can imagine a context menu action that validates a contribution or a set of
selected contributions. This would be a good base for the aggregator manager
if the indivitual contributions were pre-validated by contribution owners.
I think that the contributor owner can imagine what repositores he needs to validate
his contribution, and can add them as repository hints. Duplicate entries don't matter,
they finally share the same resource. And, it does not prevent us from keeping
global validation repositories as an option.
Taking all your arguments into account, I still think that having the mapped IUs
under the mapper repository *is confusing* and needs to be refactored.
Filip
Re: Aggregator with version range support [message #517222 is a reply to message #517197] |
Fri, 26 February 2010 10:56   |
OK, we need a conclusion, I don't like conclusionless discussions:
1) I removed the hack that was implementing what I though was natural
2) Now it works as it worked before (although it needs a lot of testing since not everything could be done with version ranges in the same way as with fixed versions)
3) I am very unsatisfied with the model-to-reality relationship, I think we did a bad job here.
I still think we could refactor the model without much effort if we spent some more time on discussions with more people. I don't think it's wise to create
software with only two use-cases in one's mind - it's not professional.
I wish you a nice weekend.
Good news is that we suppose to have a functional b3 aggregator (both integrated in Eclipse IDE and standalone headless application) which will be capable of
converting old helios build files into new b3 aggregator files and running the build of the Helios release.
Filip
> Filip,
> I think it all comes back to the requirements and the current use-cases.
> 1. In Helios and Galileo:
> 1a. each contributor is responsible for providing their update site(s)
> as input.
> 1b. each contributor is responsible for the integrity of the content of
> the contributed repositories.
> 1c. each contributor might select specific roots (features) to be mapped
> if he doesn't want the whole thing included. The selection he makes here
> is of course limited to what he provides.
> 1d. the aggregation manager never edits a contribution. He merely
> aggregates them with some validation (the platform) and disable/enable
> contributions as he see fit based on their ability to provide functional
> input.
> For this use-case, since each contributor only deals with his own
> contribution, there cannot be any confusion caused by having the mapped
> IU's in the contribution.
> 2. For Morgan Stanley
> 2a. One person is creating the aggregation.
> 2b. He builds one single contribution with everything in it since he is
> the sole contributor and owner of the whole process. No need for
> additional email contacts for "blame" email, nor to spread the
> responsibility.
> For this use-case, since there is only one contribution, there cannot be
> any confusion caused by having the mapped IU's in that contribution.
> The scenario you describe attempts to solve a use-case that sits
> somewhere in between the Eclipse release train use-case and the MS
> use-case where the contributor is not limited to his own contribution
> and/or the aggregator manager uses multiple contributions and is
> concerned with what each contribution contains. I don't understand why
> we need this. What problem is it you are trying to solve?
> If there was an easy way to refactor the model and resolve the issue
> once and for all, I would be all for that. But I can't see how we can do
> that without disrupting the above use-cases. And doing it just to
> satisfy a use-case that currently only exists in theory is not something
> I think we are prepared to spend resources on.
> - thomas
Re: Aggregator with version range support [message #517246 is a reply to message #517222] |
Fri, 26 February 2010 06:42   |
I must admit that I could not follow all of your arguments due to a lack of
in-depth aggregator knowledge. But I have the feeling that you really
*should* continue this discussion at another time, maybe over a beer at
EclipseCon. And, yes, include as many people (and as much beer) as it takes
to find a solution that leaves noone with bad feelings.
One more thing from my side: p2 tends to do things in a way that is
incomprehensible to the layman, and this includes many talented software
engineers who just didn't have the good fortune to study the p2 code base
themselves. It would be a shame if the aggregator acquired a similar
reputation.
Achim
> with fixed versions) 3) I am very unsatisfied with the model-to-reality
> create software with only two use-cases in one's mind - it's not
> professional.
> be capable of converting old helios build files into new b3 aggregator
> Filip
>> Filip,
>> as input.
>> input.
>> responsibility.
>> - thomas
Re: Aggregator with version range support [message #517297 is a reply to message #517246] |
Fri, 26 February 2010 15:21   |
Thanks Achim. You deserve a diplomacy badge ;) i must confess that I
don't get the arguments presented either. And even worse, I don't think
I even understand the problem except that there is a case that is
confusing for a user...
I think it is important to go back to the beginning and look at how a
user is making statements, what the user think they mean, and what they
really mean. Mixing this with implementation detail makes my head
explode...
- henrik
> lack of
> at
> takes
> software
> base
> reputation.
> Cheers,
> Achim
> > natural
> > testing
> > way as
> > model-to-reality
> > spent
> > wise to
> > professional.
> > (both
> > will
> > aggregator
> > Filip
> >> Filip,
> > > use-cases.
> > > site(s)
> >> as input.
> > > content of
> > > mapped
> > > here
> > > disable/enable
> > > functional
> >> input.
> > > mapped
> > > he is
> >> responsibility.
> > > cannot be
> > > contribution.
> > > contribution
> > > why
> > > issue
> > > can do
> > > something
> >> - thomas
- henrik
Re: Aggregator with version range support [message #517338 is a reply to message #517330] |
Fri, 26 February 2010 14:56   |
Well, what I want to know is still not clear.
I understand that:
- a request to include A [fromA1, toA1] does not mean that some other
request of A [fromA2, toA2 > toA1] is restricted.
- a request to include A [some range] is not tied to a particular repository
What I wonder what the resulting repository will contain if there are
many versions of A that comply. Say that fromA1 < fromA2, and toA1 > toA2.
If I have these requests in my map, I may have different desires:
a) I want all versions i.e. fromA1 (the smallest requested) to toA1 (the
largest requested).
b) I want the latest version that complies with all requests.
I would desire a) if I want to include all "old version" (in stated
range), and desire b) if I just want a slimmed repository.
This was my question - what does the aggregator mirror if I add the two
requests to A?
- henrik
On 2/27/10 12:19 AM, Thomas Hallgren wrote:
> On 02/26/2010 09:21 PM, Henrik Lindberg wrote:
>> That is not what i asked. I asked if it only picked the latest.
>> - henrik
> I'm reading your question again and I come up with the same answer :-)
> But let me try and rephrase:
> The fact that there are newer versions of A in other repositories, and
> still within the requested range, might well mean that these newer
> versions are chosen. The planner will pick the best solution possible
> for A in scope of the aggregation as a whole. No consideration
> whatsoever is given to in which source repositories an IU is found.
> OK?
> - thomas
>>>> that are mapped with other rules. Is this true?
>>> repository.
>>> - thomas
Re: Aggregator with version range support [message #517370 is a reply to message #517338] |
Sat, 27 February 2010 04:59   |
If there are two requests:
A [fromA1, toA1]
A [fromA2, toA2]
where fromA1 > fromA2 and toA1 > toA2
then the planner will choose a version that matches the range [fromA1, toA2], i.e. both original request must be satisfied.
If no such a match is found, the aggregation fails.
In addition to this, it does not matter where the chosen match comes from, i.e. if A [fromA1, toA1] was defined "from repo X"
where the highest version of A is Vx, then the aggregator may choose version Vy from repo Y if Vy > Vx && Vy <= toA2.
That's why I don't like the "graphical picture" of the thing in the UI, where user might think that he gets only things from
the repository's resolution scope.
Filip
> I understand that:
> repository
> largest requested).
> requests to A?
> - henrik
>>> - henrik
>> OK?
>> - thomas
>>>>> range,
>>>> repository.
>>>> - thomas
Re: Aggregator with version range support [message #517403 is a reply to message #517370] |
Sat, 27 February 2010 10:08   |
Boy, this is a tough question to answer...
When aggregating - what do I get in my aggregated (mirrored) result:
Only one version of A, or several?
Can I get serveral?
- henrik
> A [fromA1, toA1]
> A [fromA2, toA2]
> Filip
>> I understand that:
>> repository
>> toA2.
>> (the largest requested).
>> two requests to A?
>> - henrik
>>>> - henrik
>>> OK?
>>> - thomas
>>>>>> range,
>>>>> repository.
>>>>> - thomas
Re: Aggregator with version range support [message #596327 is a reply to message #517009] |
Hi Filip,
> Hello,
> Background:
> expects)
> probably like this:
> OK?
> For each IU request
> processing
> should work?
- thomas
Re: Aggregator with version range support [message #596335 is a reply to message #517083] |
Fri, 26 February 2010 03:30   |
Hi Thomas,
Filip
> Hi Filip,
>> Hello,
>> Background:
>> expects)
>> probably like this:
>> OK?
>> mapped.
>> For each IU request
>> range
>> processing
>> should work?
> automatic.
> - thomas
Re: Aggregator with version range support [message #596342 is a reply to message #596335] |
Hi Filip,
- thomas
> Hi Thomas,
> Filip
>> Hi Filip,
>>> Hello,
>>> Background:
>>> expects)
>>> probably like this:
>>> OK?
>>> mapped.
>>> For each IU request
>>> range
>>> processing
>>> should work?
>> automatic.
>> - thomas
Re: Aggregator with version range support [message #596368 is a reply to message #517106] |
>>> Hi Filip,
> just alphas.
> - thomas
Contribution A
+ Repository hints
+ Repo A
+ Repo B
+ Repo C
+ Mappings
Filip
Re: Aggregator with version range support [message #596375 is a reply to message #517111] |
Fri, 26 February 2010 05:21   |
> Contribution A
> + Repository hints
> + Repo A
> + Repo B
> + Repo C
> + Mappings
contributions.
> something else.
- thomas
Re: Aggregator with version range support [message #597942 is a reply to message #517120] |
Fri, 26 February 2010 05:58   |
Hi guys,
Achim
>>> this:
>>> Contribution A
>>> + Repository hints
>>> + Repo A
>>> + Repo B
>>> + Repo C
>>> + Mappings
> suggestion above).
> Filip
Re: Aggregator with version range support [message #597953 is a reply to message #597942] |
Fri, 26 February 2010 06:16   |
Hi Achim,
All I want is
Filip
Achim Demelt wrote:
> Hi guys,
> Cheers,
> Achim
Re: Aggregator with version range support [message #597959 is a reply to message #597942] |
> Hi guys,
- thomas
Re: Aggregator with version range support [message #597972 is a reply to message #517139] |
Filip
>> would have
>> repo.
>> repo to
Re: Aggregator with version range support [message #597980 is a reply to message #517142] |
Fri, 26 February 2010 07:10   |
Filip
> +1
> implications of.
> fix it.
> - henrik
>> occur in Helios.
>> - thomas
Re: Aggregator with version range support [message #597984 is a reply to message #597980] |
Fri, 26 February 2010 07:30   |
dependencies.
requested IUs".
- henrik
> his request
> Filip
>> +1
>> implications of.
>> fix it.
>> - henrik
>>> occur in Helios.
>>> - thomas
Re: Aggregator with version range support [message #598003 is a reply to message #517168] |
Fri, 26 February 2010 08:31   |
> behavior as needed.
regardless.
- thomas
Re: Aggregator with version range support [message #598014 is a reply to message #598003] |
Filip
Re: Aggregator with version range support [message #598030 is a reply to message #517180] |
repositories).
resolution scope.
Really? Why?
Filip
Re: Aggregator with version range support [message #598038 is a reply to message #517197] |
Filip
> Filip,
> as input.
> input.
> responsibility.
> - thomas
Re: Aggregator with version range support [message #600172 is a reply to message #517222] |
Fri, 26 February 2010 11:34   |
reputation.
Achim
> professional.
> Filip
>> Filip,
>> as input.
>> input.
>> responsibility.
>> - thomas
Re: Aggregator with version range support [message #600179 is a reply to message #600172] |
explode...
- henrik
> lack of
> at
> takes
> software
> base
> reputation.
> Cheers,
> Achim
> > natural
> > testing
> > way as
> > model-to-reality
> > spent
> > wise to
> > professional.
> > (both
> > will
> > aggregator
> > Filip
> >> Filip,
> > > use-cases.
> > > site(s)
> >> as input.
> > > content of
> > > mapped
> > > here
> > > disable/enable
> > > functional
> >> input.
> > > mapped
> > > he is
> >> responsibility.
> > > cannot be
> > > contribution.
> > > contribution
> > > why
> > > issue
> > > can do
> > > something
> >> - thomas
- henrik
Re: Aggregator with version range support [message #600200 is a reply to message #517330] |
Fri, 26 February 2010 19:49   |
I understand that:
largest requested).
requests to A?
- henrik
>> - henrik
> OK?
> - thomas
>>> repository.
>>> - thomas
Re: Aggregator with version range support [message #600223 is a reply to message #600200] |
A [fromA1, toA1]
A [fromA2, toA2]
Filip
> I understand that:
> repository
> largest requested).
> requests to A?
> - henrik
>>> - henrik
>> OK?
>> - thomas
>>>>> range,
>>>> repository.
>>>> - thomas
Re: Aggregator with version range support [message #600245 is a reply to message #517370] |
Can I get serveral?
- henrik
> A [fromA1, toA1]
> A [fromA2, toA2]
> Filip
>> I understand that:
>> repository
>> toA2.
>> two requests to A?
>> - henrik
>>>> - henrik
>>> OK?
>>> - thomas
>>>>>> range,
>>>>> repository.
>>>>> - thomas
Re: Aggregator with version range support [message #600272 is a reply to message #517422] |
Sat, 27 February 2010 12:58  |
On 02/27/2010 06:29 PM, Henrik Lindberg wrote:
> Thanks.
> I noticed there is an enhancement request to enable including multiple
> versions. I assume that is valid when creating repositories to be used
> in development (you want all to be included because you don't know what
> people are building against).
> Can you explain how that is acheived?
We can accomplish this by using a target consisting of one shared artifact repository and a composite meta-data
repository. Each aggregation run will then add one new child repository to the composite. This child is 100% verified
(using the planner) but when all children are brought together using the composite, there will no longer be a guarantee
that everything is consistent.
This is very similar to how many repositories at eclipse.org are constituted today. Platform, Galileo, and Helios
included. The only difference is that they don't currently utilize a shared artifact repository.
In a typical scenario this will always work since the composite contains permutations of the same aggregation where each
permutation introduces new components or new versions of old components. The planner will then satisfy an install from
the last permutation when installing "the latest" or when upgrading.
The problem that can arise is when you install earlier versions and those versions have requirements that are too
loosely specified. When that happens, the client will be forced to install from a selected repository instead of from
the composite. Creating the validation utility capable of detecting such problems while spending a reasonable amount of
time and CPU is challenging but I don't think it is impossible.
- thomas
Current Time: Mon Jul 28 03:35:59 EDT 2025
Powered by FUDForum. Page generated in 0.90034 seconds
