TPTP profiling timeout error [message #516750] |
Wed, 24 February 2010 19:03  |
I've seen some discussion on this error, but not sure why I still get it.
I just downloaded a new Eclipse and used Update Manager to install
the Test and Performance. From Eclipse's "About.." menu, here is
what I have:
Eclipse IDE for Java Developers
Build id: 20090920-1017
Instrument Core UI Feature
Version: 4.2.300.v200906091631-7977A88s733L394I3533
Build id: TPTP-4.6.1-200909160100
Version: 1.2.1.20090918-0703
Eclipse Platform
Version: 3.5.1.R35x_v20090910-9gEeG1_FthkNDSP2odXdThaOu9GFDPn83DGB7
Build id: M20090917-0800
I'm running Eclipse on a 64bit Linux machine. I have never run TPTP
before, but it seems easy enough to do it. I have a simple test Java
program and set my filter is set to include just that class and I am profiling
it within Eclipse. But I get the following error. What gives?
org.eclipse.core.runtime.CoreException
A time-out occurred while attempting to launch the process
org.eclipse.core.runtime.CoreException: A time-out occurred while attempting to launch the process
at org.eclipse.tptp.trace.ui.internal.launcher.core.LauncherUti lity.createCoreException(LauncherUtility.java:124)
at org.eclipse.tptp.trace.ui.internal.launcher.core.LauncherUti lity.createCoreException(LauncherUtility.java:132)
at org.eclipse.tptp.platform.jvmti.client.internal.launcher.TID elegateHelper.handleError(TIDelegateHelper.java:655)
at org.eclipse.tptp.platform.jvmti.client.internal.launcher.TID elegateHelper.launchProcess(TIDelegateHelper.java:571)
at org.eclipse.tptp.platform.jvmti.client.internal.launcher.TID elegateHelper.launch(TIDelegateHelper.java:348)
at org.eclipse.tptp.platform.jvmti.client.internal.launcher.TIJ avaLauncherDelegate.launch(TIJavaLauncherDelegate.java:37)
at org.eclipse.tptp.trace.ui.internal.launcher.core.LauncherUti lity.delegateInit(LauncherUtility.java:1164)
at org.eclipse.tptp.trace.ui.provisional.launcher.PrimaryLaunch Delegate.run(PrimaryLaunchDelegate.java:195)
at java.lang.Thread.run(Thread.java:619)
Re: TPTP profiling timeout error [message #516973 is a reply to message #516750] |
Thu, 25 February 2010 11:19   |
Hi Cate,
Does the application launch in Run mode? Could you try go to
Preferences>Agent Controller>Host, select 'localhost' and click 'Test
Connection' to ensure there is an Agent Controller running on the local
system (assuming you are running the application locally) for profile.
If the connection failed, exit Eclipse, and check to make sure there is no
dangling java nor ACServer process running on the system, kill them
otherwise, and relaunch Eclipse and try profile again.
Eugene
"Cate" <remotexiang@hotmail.com> wrote in message
news:hm4ep8$f25$1@build.eclipse.org...
> what I have:
> Instrument Core UI Feature Version:
> Eclipse Platform
> profiling
FUDForum. Page generated in 0.05969 seconds
