Home » Archived » AMW » How to install AMW under Eclipse 3.5.1
icon5.gif  How to install AMW under Eclipse 3.5.1 [message #516930] Thu, 25 February 2010 09:35 Go to next message
Good Day!
I have a simple question.
I try to install the AMW under Eclipse 3.5.1
I downloaded the zip file as described and copied the directories under Eclipse\plugins.
After that I thought i can just press new\project\ other... and find something like "AMW-Project". But I saw nothing in the Menu like "AMW".
What did I wrong?
Thank you in advance.
Alexey
[Updated on: Thu, 25 February 2010 09:38] by Moderator
Re: How to install AMW under Eclipse 3.5.1 [message #517304 is a reply to message #516930] Fri, 26 February 2010 16:45 Go to previous messageGo to next message
We do not have a binary version that works with Eclipse 3.5.x.
The current version has been compiled with Eclipse 3.4.2.
And you need as well to install a ATL+AM3 version for developers.
Otherwise, you may download a bundle with all the required plug-ins (AMW included) in the link below:
http://docatlanmod.emn.fr/Eclipse_Bundles/AMMA_Prototype/AMM APrototypeEclipse.zip
Once installed, you will have a menu "Model weaver"..
Marcos.
Re: How to install AMW under Eclipse 3.5.1 [message #517624 is a reply to message #517304] Mon, 01 March 2010 09:59 Go to previous messageGo to next message
Gracias!
Re: How to install AMW under Eclipse 3.5.1 [message #517625 is a reply to message #517304] Mon, 01 March 2010 10:00 Go to previous messageGo to next message
Hallo, Marcos!
The Link you gave me doesnt work!
Thanx
Alexey
Maybe you mean this one?
[Updated on: Mon, 01 March 2010 10:41] by Moderator
Re: How to install AMW under Eclipse 3.5.1 [message #517719 is a reply to message #517625] Mon, 01 March 2010 15:14 Go to previous messageGo to next message
Yes, this one. It was a bad copy and paste Smile.
Marcos.
Re: How to install AMW under Eclipse 3.5.1 [message #517888 is a reply to message #517719] Tue, 02 March 2010 08:10 Go to previous messageGo to next message
Thank you very much, Marcos, the THING ist installed!
Now, could you please advise me some AMW-Samples (with sources)? The ones I found on the AMW-Page seem to be very old.
Thank you!
Alexey
Re: How to install AMW under Eclipse 3.5.1 [message #518282 is a reply to message #517888] Wed, 03 March 2010 11:40 Go to previous message
hi,
You can use any of the examples, depending on what you are planning to do... For instance, the 4 following use cases cover different issues.
1. Traceability of model transformations
2. Model migration illustrated by a simple metamodel
3. Automatic model matching
Marcos.
Previous Topic:Which use case to choose?
Next Topic:AMW Ecore metamodel
Current Time: Sat Jul 26 02:49:43 EDT 2025
Powered by FUDForum. Page generated in 0.04109 seconds
