Home » Language IDEs » Objectteams » eclipse update OTDT failed(eclipse update OTDT failed)
eclipse update OTDT failed [message #516871] |
Thu, 25 February 2010 07:18  |
what's happen when update in eclipse 3.6 ?
An error occurred while collecting items to be installed
session context was:(profile=SDKProfile, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
No repository found containing: osgi.bundle,org.objectteams.jdt.ui.adaptor,1.4.0.20100127193 0
No repository found containing: osgi.bundle,org.objectteams.otdt,1.4.0.201001271930
No repository found containing: osgi.bundle,org.objectteams.otdt.compiler.adaptor,1.4.0.2010 01271930
No repository found containing: osgi.bundle,org.objectteams.otdt.debug.adaptor,1.4.0.2010012 71930
No repository found containing: osgi.bundle,org.objectteams.otdt.debug.ui,1.3.2.200909280002
No repository found containing: osgi.bundle,org.objectteams.otdt.metrics,1.3.2.200909280002
No repository found containing: osgi.bundle,org.objectteams.otdt.pde.ui,1.4.0.201001271930
No repository found containing: osgi.bundle,org.objectteams.otdt.refactoring.adaptor,1.4.0.2 01001271930
No repository found containing: osgi.bundle,org.objectteams.otdt.samples,1.4.0.201001271930
No repository found containing: osgi.bundle,org.objectteams.otdt.ui,1.4.0.201001271930
No repository found containing: osgi.bundle,org.objectteams.otdt.ui.help,1.4.0.201001280200
No repository found containing: osgi.bundle,org.objectteams.otequinox.runtime,1.4.0.20100127 1930
No repository found containing: osgi.bundle,org.objectteams.runtime,1.3.2.200909280002
Re: eclipse update OTDT failed [message #517213 is a reply to message #517074] |
Fri, 26 February 2010 10:44  |
Jarn Tang wrote on Fri, 26 February 2010 00:08 | Dear Stephan
Thanks for your reply 。you are right ,I have an Eclipse 3.6 M5 installed, however it's normal when use eclipse 3.5 to install. So the network didn't problem.
It could still happen, that network connection failed just once and
perhaps p2 has cached incomplete information.
Those things are very difficult to debug.
Jarn Tang wrote on Fri, 26 February 2010 00:08 | I will try to install with zip.
Jarn Tang
Please let me know if the problem persists.
In that case I would need some more details of what exactly
you tried, in order to understand what is going on.
cheers,
Stephan
Re: eclipse update OTDT failed [message #569110 is a reply to message #516902] |
Dear Stephan
Thanks for your reply 。you are right ,I have an Eclipse 3.6 M5 installed, however it's normal when use eclipse 3.5 to install. So the network didn't problem.I will try to install with zip.
Jarn Tang
Re: eclipse update OTDT failed [message #569198 is a reply to message #569110] |
> Dear Stephan
> Jarn Tang
cheers,
Stephan
Current Time: Sat Jul 26 11:09:08 EDT 2025
Powered by FUDForum. Page generated in 0.26666 seconds
