Home » Language IDEs » C / C++ IDE (CDT) » Add variable to memory monitor
Add variable to memory monitor [message #516710] Wed, 24 February 2010 16:29 Go to next message
I've read this help page on using the Memory Monitor Window, but I am still getting errors adding structure members to the memory window. http:// help.eclipse.org/help33/index.jsp?topic=/org.eclipse.cdt.doc .user/tasks/cdt_t_memory.htm
I can add an array or local variable to the memory window with out a problem. I get an error when trying to add a pointer inside a structure.
typedef struct _page_data_
   INT16U data_len;
   INT8U  addr;
   INT8U  page;
   INT8U  *data;
}COMPACT_PAGE_DATA;
COMPACT_PAGE_DATA *tool;
When I try to add tool->data to the memory window I get the following error.
Add Memory Monitor Failed.
Expression 'tool->data' evaluated to invalid address value: 0x201fa180
Address 0x201fa180 is the address that 'data' points to, it is where the data I want to see is located!
If I add '&tool->data' to the memory monitor, I get the location where the tool->data pointer is stored
Re: Add variable to memory monitor [message #517502 is a reply to message #516710] Sun, 28 February 2010 15:10 Go to previous messageGo to next message
> http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. cdt.doc.user/tasks/cdt_t_memory.htm
> INT16U data_len;
> INT8U addr;
> INT8U page;
> INT8U *data;
> }COMPACT_PAGE_DATA;
> error.
Have you tried *(tool->data)
Re: Add variable to memory monitor [message #517635 is a reply to message #517502] Mon, 01 March 2010 10:15 Go to previous message
When I try *(tool->data) I get the following error.
Expression '*(tool->data)' evaluated to invalid address value: 80 'P'.
Previous Topic:Bulid 32bit binaries on 64bit Linux using 64bit CDT and GCC toolchain
Next Topic:Issues with SWT plugin while installing CDT
Current Time: Tue Jul 29 13:00:46 EDT 2025
Powered by FUDForum. Page generated in 0.25131 seconds
