Home » Eclipse Projects » JFace » [Databinding] Transform Boolean value bound to checkbox control into string and save it as a map val
[Databinding] Transform Boolean value bound to checkbox control into string and save it as a map val [message #516701] Wed, 24 February 2010 10:38 Go to next message
I have the following need:
params = new HashMap<String, String>();
final IMapProperty selfMap = Properties.selfMap(String.class,
String.class);
final IObservableMap observableParams = selfMap.observe(params);
final IObservableValue mapEntry = Observables
..observeMapEntry(observableParams, key);
Button button = new Button(parent, SWT.CHECK);
control = SWTObservables.observeSelection(button);
bindValue(control, mapEntry);
First of all, this setup does only saves something into the map if I
click the checkbox.
Furthermore I want not the Boolean value saved into the map but a
special String value when the Boolean is true and another one when its
false. Since I would not like to use a UpdateValueStrategy with a
converter is there another way to achieve the transformation from
Boolean -> String using some kind of DecoratedValue?
Phil
Re: [Databinding] Transform Boolean value bound to checkbox control into string and save it as a map [message #518429 is a reply to message #516701] Thu, 04 March 2010 00:56 Go to previous message
> String.class);
> click the checkbox.
Converters are the recommended approach here.
Matthew
Previous Topic:DataBinding DateTime?
Next Topic:Refresh TreeViewer with attached ViewerFilter
Current Time: Wed Jul 23 13:29:48 EDT 2025
Powered by FUDForum. Page generated in 0.25151 seconds
