Home » Modeling » EMF » [EMF + Teneo + EAV]: How to customize table names used in EAV schema?
[EMF + Teneo + EAV]: How to customize table names used in EAV schema? [message #516696] Wed, 24 February 2010 15:05 Go to next message
Our project is using Teneo EAV schema. Now everytime a new HbSessionDatastore gets created, I need to append different appendixes to the table names used in eav schema. E.g.
For HbSessionDataStore1, I want "eaveobject" table to be named as "eaveobject_store1". And for HbSessionDataStore2, I want "eaveobject" table to be named as "eaveobject_store2".
Is there any easy way to achieve this? I tried to (1) extending Hibernate DefaultNamingStrategy (2) extending Teneo's SQLNameStrategy extensionpoint. But these two seems to have no effect on table names used in EAV schema.
Another way I can use is to modify eav schema's eav.hbm.xml, and for each new HbSessionDatastore, use PersistenceOptions.EAV_MAPPING_FILE option to point to the newly updated mapping xml. But is there any easier way that I missed here?
Thanks in advance!
Re: [EMF + Teneo + EAV]: How to customize table names used in EAV schema? [message #516857 is a reply to message #516696] Thu, 25 February 2010 01:46 Go to previous messageGo to next message
Hi tr,
Hmm, within Teneo there is currently no other way than overriding the hbm file used here. But maybe Hibernate offers
some configuration options:
You could try to use the hibernate catalog/schema properties. With these you can define prefixes which are prepended to
table names by hibernate.
Another way (although seems more hackish) is to use an interceptor, see here for an example:
http://java.dzone.com/articles/hibernate-dynamic-table-routi n
Note that when using an interceptor that you have to extend the EMFInterceptor class (provided by Teneo) and declare
that class using the Teneo extension mechanism:
http://wiki.eclipse.org/Teneo/Hibernate/Extensions
Let me know if one of the above strategies helps.
gr. Martin
tr wrote:
> used in EAV schema.
> Thanks in advance!
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [EMF + Teneo + EAV]: How to customize table names used in EAV schema? [message #516915 is a reply to message #516857] Thu, 25 February 2010 09:14 Go to previous messageGo to next message
Dear Martin,
The first approach will point to different schemas, e.g. if I set 'schema="ppp"'. It will point me to "ppp.eaveobject" instead of "ppp_eaveobject" table. This approach works for Oracle. But for SQLServer we like everything to be under "dbo". And MySQL doesn't even have real schema support.
The second approach is actually a little hacky... If we want to go that way, I might just override your PersistenceFileProvider extension point, in its getFileContent() function, do something like:
if it's "eav.hbm.xml", then modify the table attribute and append some content.
Also there is a third cleaner approach. Is it possible/difficult to allow PersistenceOptions.SQL_TABLE_NAME_PREFIX to take effect for EAV schema? Right now it doesn't affect EAV table names. But one reason I could think of, is that some companies have strict policies on what should be their database table's prefix. Now they would want their table names to be prefixed, no matter traditional schema or EAV schema.
Tiger
Re: [EMF + Teneo + EAV]: How to customize table names used in EAV schema? [message #516953 is a reply to message #516915] Thu, 25 February 2010 10:05 Go to previous messageGo to next message
Hi Tiger,
Yes having the option seems to be the cleanest approach from a usability point of view. I hope to find an implementation
of this option also which is as clean. Can you enter a bugzilla for this then we can discuss it further there?
gr. Martin
tr wrote:
> Dear Martin,
> in its getFileContent() function, do something like: if it's
> Thanks
> Tiger
The Netherlands
Re: [EMF + Teneo + EAV]: How to customize table names used in EAV schema? [message #516960 is a reply to message #516953] Thu, 25 February 2010 10:45 Go to previous message
Yes, Martin,
I just logged a new ticket at https://bugs.eclipse.org/bugs/show_bug.cgi?id=303919
T
Previous Topic:how to use constraints defined by the ecore meta-model in EMF Validation Framework
Next Topic:Multiple Serializations
Current Time: Sun Jul 20 21:24:02 EDT 2025
Powered by FUDForum. Page generated in 0.04773 seconds
