Home » Eclipse Projects » JavaServer Faces » JSF 2.0 Facelets content assist not working
JSF 2.0 Facelets content assist not working [message #515740] Sat, 20 February 2010 00:41 Go to next message
I, ve some trouble with JSF Facelets Tools Project.
I've installed the facelet plugin in eclipse gynamede and created a new Facelet Web Dynamic Project.
I did the login example.Everything works fine.But the problem is when i click <h: ctrl +spacebar the content assist is not coming in the pages.
A warning message
Can't find facelet tag library for uri http://java.sun.com/jsf/
core
Can't find facelet tag library for uri http://java.sun.com/jsf/html
facelets is shown in the following line:
<html xmlns="http://www.w3.org/1999/xhtml"
xmlns:ui="http://java.sun.com/jsf/facelets"
xmlns:h="http://java.sun.com/jsf/html"
xmlns:f="http://java.sun.com/jsf/core">
I followed the steps in the webinar session Building Facelets Applications with the JSF Tools for Eclipse.All the libraries are in place.
Anyone know the solution?
Re: JSF 2.0 Facelets content assist not working [message #516666 is a reply to message #515740] Wed, 24 February 2010 12:28 Go to previous messageGo to next message
Hi Jaya,
JSF 2.0 is not yet supported in JSF Tools. We are working on adding it for Helios. Stay tuned in this forum for updates. If you are an adopter, you can also search [JSF2.0] in the Eclipse bug database both in summary title and whiteboard field of WebTools->JSF Tools product bugs.
Cameron Bateman
JSF Tools Committer
Re: JSF 2.0 Facelets content assist not working [message #516667 is a reply to message #515740] Wed, 24 February 2010 12:31 Go to previous message
Note also that the Facelet incubator plugins are being folded into the main tooling as part of adding support for JSF 2.0. We will support the similar backward compatibility for Facelets 1.x as is supported in the runtime spec, but no further work will be done on the incubator plugins.
Previous Topic:Exception when using the JSF Facelets Tools Incubator
Next Topic:JSF 2.0 Facelets content assist not working
Current Time: Wed Jul 23 12:42:36 EDT 2025
Powered by FUDForum. Page generated in 0.08382 seconds
