Eclipse asking over and over to enable JDT Weaving [message #513725] |
Wed, 10 February 2010 18:41  |
So I want to enable JDT Weaving - in fact, as far as I knew it was enabled - but when I started Eclipse I got the prompt, so I clicked to enable it and restarted. However, it prompted me again, so I clicked to enable again and restarted again, after which... well, you get the idea.
I can't seem to get JDT Weaving enabled. I've tried it through the prompt and through Preferences, restarting immediately or in a bit, uninstalling and reinstalling the AJDT/weaving plugins - nothing seems to help. Any ideas?
Re: Eclipse asking over and over to enable JDT Weaving [message #529053 is a reply to message #528998] |
Thu, 22 April 2010 14:17  |
Hi Steve,
There are conflicts between org.aspectj.weaver and com.springsource.org.aspectj.weaver. The second one is only present if you are using STS. It is usually the case that when you enable JDT weaving all the steps above are done for you, but sometimes things don't work out well. This can be the case when there is an exception thrown on shutdown, preventing the IDEs state from being saved (the exception can be completely unrelated to AJDT).
It could be that when you disabled com.springsource.org.aspectj.weaver, org.aspectj.weaver was also disabled. And that is why you were seeing problems in your editor. It is sometimes hard to know exactly why this happened, but going through the manual steps to enable JDT weaving will fix things.
Re: Eclipse asking over and over to enable JDT Weaving [message #600853 is a reply to message #517172] |
Fri, 26 February 2010 13:22  |
I was just starting Eclipse to try this (sorry for the delay) and it told me JDT Weaving had been activated and did I want to index my projects. As to why it suddenly started working when all my previous attempts had failed... I got nothin'. :?
Thanks for the help, in any case, and I'll keep this in mind if it starts happening again. Glad it worked for you, Michael.
FUDForum. Page generated in 0.14082 seconds
