Home » Archived » M2M (model-to-model transformation) » [ATL] How to Clone/Copy source elements to multiple target elements
[ATL] How to Clone/Copy source elements to multiple target elements [message #516524] Wed, 24 February 2010 05:58 Go to next message
Hi all,
In my ATL transformation I have a location class that contains a set of invariant expressions. I would like to transform the model in such a way that the new invariant set in the target model contains all the source invariant expressions AND a copy of each of the expressions. So {exp1} must be transformed to {exp1,exp1}.
Currently I've tried to transform the source to target expressions using match rules and tried to create the extra/copied expressions using lazy rules. This unfortunately didn't work.
What happens is that the lazy rule Number2 is executed first, whereafter the match rule Number1 is not executed once, but twice. Does anyone have an explanation for this? I know that it can be solved by placing the Number1 rule above the Location rule. So it probably is the case that the expression created by the lazy rule is seen as a source element by the matched rule.
I currently use both match and lazy rules. Does anybody know a better way to create the two instances in the target model? What I would like to have is just one match rule, and then something of a cloning rule/action, but I don't know if this is possible.
Any help would be greatly appreciated.
Tim
--copy location
rule Location{
from s : cif!Location
to t : cif!Location(
invariant <- s.invariant->union(s.invariant->collect(inv| inv.getExpression()))
--copy number
rule Number1{
from s : cif!Number
to t : cif!Number(
value <- s.value + 'new',
type <- s.type
--copy nat type
rule NatType1{
from s : cif!NatType
to t : cif!NatType()
helper context cif!Number def: getExpression() : cif!Expression =
thisModule.Number(self);
--copy number
lazy rule Number2{
from s : cif!Number
to t : cif!Number(
value <- s.value,
type <- s.type.getStaticType()
helper context cif!NatType def: getStaticType(): cif!StaticType =
thisModule.NatType(self);
--copy nat type
lazy rule NatType2{
Re: [ATL] How to Clone/Copy source elements to multiple target elements [message #516621 is a reply to message #516524] Wed, 24 February 2010 10:39 Go to previous messageGo to next message
You can use multiple target elements in each rule and use resolveTemp to get both target elements instead of just the first one.
I'm afraid it's the only available solution in a declarative way.
That would be :
--copy location
rule Location{
invariant <- s.invariant->collect(e | Sequence{thisModule.resolveTemp(e,'t'),thisModule.resolveTem p(e,'copy')})- >flatten()
--copy number
rule Number1{
from s : cif!Number
to t : cif!Number(
value <- s.value,
type <- s.type
copy : cif!Number(
type <- thisModule.resolveTemp(s.type,'copy')
--copy nat type
rule NatType1{
to t : cif!NatType(),
copy : cif!NatType(),
You could also use called rules.
Re: [ATL] How to Clone/Copy source elements to multiple target elements [message #516836 is a reply to message #516524] Thu, 25 February 2010 05:29 Go to previous message
You could even write your transformation in the normal way and write a custom HOT to generate the 'copy' version of your transformation Smile
Previous Topic:[M2M] How to transform UML2 model to EMF model
Next Topic:[ATL] The simpliest ATL-Sample doesnt launch
Current Time: Sun Jul 27 09:35:22 EDT 2025
Powered by FUDForum. Page generated in 0.03592 seconds
