Home » Eclipse Projects » Remote Application Platform (RAP) » Where did ThemeManager.getThemeAdapter(Class) disappeared from M5?
Where did ThemeManager.getThemeAdapter(Class) disappeared from M5? [message #516533] Wed, 24 February 2010 06:20 Go to next message
can somebody tell me where did org.eclipse.rwt.internal.theme.ThemeManager..getThemeAdapter (Class) disappeared from M5?
In M4 is still there.
You will probably tell me that I should not use a class from an internal package. All right, I'd do it, if you tell me how can I obtain the border width of a button in the current theme Smile . Meaning a way to replace:
ThemeManager themeMgr = ThemeManager.getInstance();
IControlThemeAdapter buttonThemeAdapter = ( IControlThemeAdapter)themeMgr.getThemeAdapter( Button.class );
int border = buttonThemeAdapter.getBorderWidth( this );
Re: Where did ThemeManager.getThemeAdapter(Class) disappeared from M5? [message #516558 is a reply to message #516533] Wed, 24 February 2010 06:59 Go to previous messageGo to next message
Replace your code with the following:
IControlThemeAdapter themeAdapter =
( IControlThemeAdapter )control.getAdapter( IThemeAdapter.class );
HTH
Rüdiger
On 24.02.2010 12:20, Bogdan B. wrote:
> disappeared from M5? In M4 is still there.
> border width of a button in the current theme :) . Meaning a way to
> replace:
Re: Where did ThemeManager.getThemeAdapter(Class) disappeared from M5? [message #516562 is a reply to message #516533] Wed, 24 February 2010 07:06 Go to previous messageGo to next message
.... or if you don't have an instance of a button ( like in the Upload
widget from sandbox ) create your own theme adapter - see
Upload#getButtonBorder() and UploadThemeAdapter.
HTH,
Ivan
On 2/24/2010 1:20 PM, Bogdan B. wrote:
> obtain the border width of a button in the current theme :) .
Re: Where did ThemeManager.getThemeAdapter(Class) disappeared from M5? [message #516569 is a reply to message #516558] Wed, 24 February 2010 07:33 Go to previous messageGo to next message
Sorry, I only saw now Ivan's post. I'll try it, please ignore the following!
Thank you!
Could you give me a hint please of what should I do if I needed this code inside a RAP custom widget and I have no instance of a "control"?
Rüdiger Herrmann wrote on Wed, 24 February 2010 06:59
[Updated on: Wed, 24 February 2010 07:35] by Moderator
Re: Where did ThemeManager.getThemeAdapter(Class) disappeared from M5? [message #516623 is a reply to message #516569] Wed, 24 February 2010 10:30 Go to previous messageGo to next message
Hi Bogdan,
see my comment below.. :-)
Best,
Ivan
On 2/24/2010 2:33 PM, Bogdan B. wrote:
> Thank you!
Re: Where did ThemeManager.getThemeAdapter(Class) disappeared from M5? [message #516883 is a reply to message #516562] Thu, 25 February 2010 08:10 Go to previous message
Thank you, Ivan, this is exactly what I needed! Smile
Ivan Furnadjiev wrote on Wed, 24 February 2010 07:06
Previous Topic:IFontProvider NOT workiing
Next Topic:RAP and Jetty 7
Current Time: Sun Aug 31 06:46:40 EDT 2025
Powered by FUDForum. Page generated in 0.03535 seconds
