Home » Eclipse Projects » GEF » GEF Editor with Palette and Toolbar
GEF Editor with Palette and Toolbar [message #516314] |
Tue, 23 February 2010 05:20  |
Hi, has anyone created a GEF editor with both a flyout palette and a
toolbar? I need to create a graphical editor that supports zoom in and out,
and contains a toolbar that does not zoom. I have tried creating an editor
that extends GraphicalEditorWithFlyoutPalette, and I have overridden the
createGraphicalViewer method. In createGraphicalViewer, I have attached a
toolbar to the parent Composite. I also used a ScalableRootEditPart.
However, I am running into different issues because of the palette. Any
suggestions or reference(s) to example(s) would be greatly appreciated.
Thanks alot - Barry
Re: GEF Editor with Palette and Toolbar [message #516410 is a reply to message #516388] |
Tue, 23 February 2010 15:35   |
On 23/02/2010 20:13, Barry Dresdner wrote:
> Ah, excellent question/suggestion.
> Our UI team in their infinite wisdom prefers a toolbar within the editor
> along with a palette.
> We can actually get a GEF editor working with the toolbar as long as it
> doesn't have the palette (extends GraphicalEditor)
> Once we add the palette (extends GraphicalEditorWithFlyoutPalette), then we
> run into major issues.
> Most likely a layout issue or a problem with where the toolbar is added.
> thanks
> "Phillipus"<p.beauvoir@dadabeatnik.com> wrote in message
> news:hm1b9s$v99$1@build.eclipse.org...
>>> out,
>>> editor
>>> a
>>> Thanks alot - Barry
>> Where is the toolbar? Why not put it on the main toolbat area of you app?
Yes, I'm not a fan of localised toolbars. Sounds like you need to
experiment with the toolbar's parent.
Re: GEF Editor with Palette and Toolbar [message #516411 is a reply to message #516410] |
Tue, 23 February 2010 11:04   |
Yes. That's what we are doing. I was just hoping someone may have done
this already and can provide a little insight to help speed things along.
thanks
"Phillipus" <p.beauvoir@dadabeatnik.com> wrote in message
news:hm1e5o$mab$1@build.eclipse.org...
>> we
>> thanks
>>>> out,
>>>> editor
>>>> the
>>>> attached
>>>> a
>>>> Any
>>>> Thanks alot - Barry
>>> app?
Re: GEF Editor with Palette and Toolbar [message #516454 is a reply to message #516411] |
Tue, 23 February 2010 23:23   |
Quote: | Override createPartControl of your editor..
public void createPartControl(Composite parent)
Composite c = new Composite(parent, SWT.None);
c.setLayout(new GridLayout(1, true));
ToolBar tb = new ToolBar(c, SWT.None);
tb.setLayoutData(new org.eclipse.swt.layout.GridData(
org.eclipse.swt.layout.GridData.FILL_HORIZONTAL));
ToolItem ti1 = new ToolItem(tb, SWT.PUSH);
ti1.setText("Tool item 1");
ToolItem ti2 = new ToolItem(tb, SWT.PUSH);
ti2.setText("Tool item 2");
ToolItem ti3 = new ToolItem(tb, SWT.PUSH);
ti3.setText("Tool item 3");
ToolItem ti4 = new ToolItem(tb, SWT.PUSH);
ti4.setText("Tool item 4");
Composite composite = new Composite(c, SWT.None);
composite.setLayoutData(new GridData(GridData.FILL_BOTH));
composite.setLayout(new FillLayout());
super.createPartControl(composite);
is it this you want or somthing else...
i did this on shapes example and it worked...
[Updated on: Tue, 23 February 2010 23:25] by Moderator
Re: GEF Editor with Palette and Toolbar [message #516595 is a reply to message #516454] |
Wed, 24 February 2010 04:18  |
Hi Vijay,
That is exactly what I needed!
It is simple and works beautifully with the palette.
thank you very much,
Barry
"vijay" <vijay.rajonline@gmail.com> wrote in message
news:hm29kp$lf2$1@build.eclipse.org...
> @Override
> Regards,
> Vijay
Current Time: Sat Jul 26 23:13:49 EDT 2025
Powered by FUDForum. Page generated in 0.08921 seconds
