Home » Language IDEs » C / C++ IDE (CDT) » Install problem on Debian Linux
Install problem on Debian Linux [message #4819] Thu, 13 December 2001 12:37 Go to next message
Yes I know that Debian is probably not a supported environment, but
I have a rather basic problem which I thought someone might know the
answer to.
Having unziped cdt into the plugin directory, I then changed to
com.ibm.dstore.core and typed "make dev". Nothing happened, it
just hing. So I got inquisitive and tried "make -d dev" and it
got as far as reading the makefile, but no further. I am running
GNU Make 3.79.1 if that makes a difference, and have rebuild
X Free, KDE and the kernel on this box, so it should be set up
right.
Re: Install problem on Debian Linux [message #4890 is a reply to message #4819] Thu, 13 December 2001 13:14 Go to previous messageGo to next message
Hmm..haven't seen this before..
Can you append a script of 'make -d dev' here (or to eclipsc@ca.ibm.com if
it
is very large) and maybe also 'make -p dev'. I am using GNU make 3.79.1
and have built successfully on RH 7.1 and win2000 (under cygwin).
"David Goodenough" <david.goodenough@btconnect.com> wrote in message
news:9vaq1n$ntb$1@rogue.oti.com...
> answer to.
> right.
SOLVED Re: Install problem on Debian Linux [message #4958 is a reply to message #4890] Thu, 13 December 2001 13:09 Go to previous messageGo to next message
> it
>> answer to.
>> right.
Fixed it, my fault. I was using the wrong Java (1.1.8) rather than
1.3 as it was the default in my path. When I overrode the path it
worked happily.
Re: SOLVED Re: Install problem on Debian Linux [message #5164 is a reply to message #4958] Thu, 13 December 2001 16:01 Go to previous message
Since our build has a Java version dependency, it would make sense
for us to check the Java version and tell you if it is wrong.
We'll add this to our suggestions list.
Brian Thomson
> worked happily.
Previous Topic:Where to report bugs? Here's one...
Next Topic:What's with the text editor?
Current Time: Sat Oct 25 05:20:29 EDT 2025
Powered by FUDForum. Page generated in 0.03875 seconds
