Home » Eclipse Projects » JFace » [Databinding] binding to sub objects
[Databinding] binding to sub objects [message #516376] Tue, 23 February 2010 14:07 Go to next message
Is it possible to bind a tableviewer to a model and its sub objects, for example using properties?
eg: my model consists of
public class Person {
public String name;
public List<Address> addresses;
public class Address {
public String postcode;
I would like my tableviewer to display column 1 Persons name, column 2 first address postcode, column 3 second address postcode etc etc.
Re: [Databinding] binding to sub objects [message #516475 is a reply to message #516376] Wed, 24 February 2010 02:29 Go to previous messageGo to next message
Hi Matt,
if addresses is implemented by WritableList you could use a ComputedValue
and get the first/second/etc. element from the list. if you have multiple
persons you would need a ComputedMap. The writable list is needed to
automatically update the computed value/map upon changes in the list.
Enrico
"Matt Biggs" <zebbedi@gmail.com> schrieb im Newsbeitrag
news:hm191f$ine$1@build.eclipse.org...
> public String name;
Re: [Databinding] binding to sub objects [message #516557 is a reply to message #516376] Wed, 24 February 2010 07:00 Go to previous message
Hi Enrico,
Do you have a very quick example of this? Im still struggling with the concept of hooking it all up together.
cheers
Previous Topic:ControlDecoration on table items
Next Topic:DataBinding DateTime?
Current Time: Fri Jul 18 21:19:35 EDT 2025
Powered by FUDForum. Page generated in 1.05878 seconds
