Home » Eclipse Projects » Rich Client Platform (RCP) » Iterate expression with two or more equals
Iterate expression with two or more equals [message #515945] Mon, 22 February 2010 05:15 Go to next message
Originally posted by: 6lackbird.dev.gmail.com
How to write the condition for checking two or more expressions to iterate?
Option when inside iterate registered only one equals everything works
<enablement>
<with variable="accessRights">
<iterate ifEmpty="false" operator="or">
<equals value="viewer"/>
</iterate>
</with>
</enablement>
but worth only add one more condition, the test fails
<enablement>
<equals value="editor"/>
</iterate>
</with>
</enablement>
Re: Iterate expression with two or more equals [message #516012 is a reply to message #515945] Mon, 22 February 2010 08:34 Go to previous messageGo to next message
operator="or" applies to how the values of each iteration are combined.
The iterate children are combined using "and", so you would need to
add <or> around your 2 equals.
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: Iterate expression with two or more equals [message #516053 is a reply to message #516012] Mon, 22 February 2010 10:41 Go to previous messageGo to next message
Paul Webster пишет:
> The iterate children are combined using "and", so you would need to add
> PW
so this is not working
<or>
</or>
<or>
</or>
</iterate>
</with>
Could you show your variant?
Re: Iterate expression with two or more equals [message #516139 is a reply to message #516053] Mon, 22 February 2010 10:12 Go to previous messageGo to next message
> <or>
> </or>
> <or>
> </or>
> </iterate>
> </with>
That's ANDing 2 ORs. you want to OR 2 EQUALS:
<or>
</or>
</iterate>
</with>
This expression says if ANY item in the collection is either a viewer or
editor.
Remove the operator="or" if you want: if ALL items in the collection are
either a viewer or editor.
PW
Paul Webster
Re: Iterate expression with two or more equals [message #516311 is a reply to message #516139] Tue, 23 February 2010 10:03 Go to previous message
thanks
Previous Topic:How to add my problem entries to problemview
Next Topic:FormText with tooltip?
Current Time: Fri Jul 18 18:47:23 EDT 2025
Powered by FUDForum. Page generated in 0.08962 seconds
