[Xpand] Regression when migrating from 0.7.0 to 0.8.0M5 [message #515986] |
Mon, 22 February 2010 07:02  |
Dear all,
I have hit a regression when going to 0.8.0M5 - luckily I have been able to solve it in my case, but I would appreciate any comments about whether it reflects a deliberate change or not.
Consider the following extension, which uses the XSD of XSD as a metamodel:
extension myQName;
create xmlschema::Attribute this a2( xmlschema::SimpleType t ):
this.setType( t.qnameFromType() )
The extension "myQName.ext" is:
extension org::eclipse::xtend::typesystem::xsd::lib::qname;
type::QName qnameFromType ( xmlschema::SimpleType t ):
createQName( ( (xmlschema::SchemaType) t.eRootContainer).targetNamespace , t.name)
In 0.7.0 no errors are flagged, and workflows containing this run fine. In 0.8.0M5 there is an error at the "this.setType" line that reads:
Quote: | Couldn't find operation 'setType(javax::xml::namespace::QName)' for type 'xmlschema::Attribute'
In this particular case, this error can be removed by deleting the return type from the definition of qnameFromType:
(although I have no idea what I would have had to do if the extension was a recursive one.) I then get a different error at the "this.setType" line:
Quote: | Couldn't find operation 'qnameFromType()' for type 'xmlschema::SimpleType'
This can be got around by changing this:
to this:
this.setType( qnameFromType(t) )
and everything works.
Is this a genuine regression, or is the original form of my code wrong in some way that has been cleaned up in 0.8.0? If so, where do I look for information about this? I haven't managed to find any release notes for the 0.8.0 sequence, and the list of bugs fixed for 0.8.0 in bugzilla doesn't seem to contain anything relevant.
Peter.
Re: [Xpand] Regression when migrating from 0.7.0 to 0.8.0M5 [message #516089 is a reply to message #515986] |
Mon, 22 February 2010 08:18   |
Hi Peter,
this sounds pretty strange.
Could you please file a bugzilla?
Sven
Peter Keller schrieb:
> Dear all,
> http://www.w3.org/2001/XMLSchema.xsd as a metamodel:
> extension myQName;
> Quote:
> line:
> Quote:
> to this:
> Regards,
> Peter.
Need professional support for Xtext and EMF?
Go to: http://xtext.itemis.com
Twitter : @svenefftinge
Blog : blog.efftinge.de
FUDForum. Page generated in 0.05927 seconds
