Home » Modeling » Epsilon » Is it possible customize EMF Tree Editor programmatically ?
Is it possible customize EMF Tree Editor programmatically ? [message #515262] Thu, 18 February 2010 05:03 Go to next message
Hello!
I'm developing EMF editor and I have customized it manually, to do it
I have to modify over 30 java files, now I would want to do this customization
programmatically using only a file.
For GMF, I use EuGENia to customize editors, for EMF I know Epsilon Exeed but
It works with Reflective editors and I need to do it with Tree Editors and
I don't know any tool that let me this.
Does Anyone know a tool to customize EMF tree editor such as EuGENia for GMF?
Thanks, Regards
Álvaro
Re: Is it possible customize EMF Tree Editor programmatically ? [message #515264 is a reply to message #515262] Thu, 18 February 2010 05:10 Go to previous messageGo to next message
Hi Alvaro,
I'm not aware of any such tool, but I think it'd be straightforward to
follow an approach similar to what EuGENia does (i.e define some
task-specific @emf.xxx annotations) and then use an M2T language (e.g.
EGL - http://www.eclipse.org/gmt/epsilon/doc/egl/) to generate the
custom code.
Dimitris
ajimenezr wrote:
> Hello!
> I'm developing EMF editor and I have customized it manually, to do it I
> customization programmatically using only a file.
> Exeed but It works with Reflective editors and I need to do it with Tree
> Editors and
> GMF?
> Thanks, Regards
> Álvaro
Spread the word: http://www.eclipse.org/gmt/epsilon/spreadtheword
Follow Epsilon on Twitter: http://twitter.com/epsilonews
Re: Is it possible customize EMF Tree Editor programmatically ? [message #515950 is a reply to message #515264] Mon, 22 February 2010 05:33 Go to previous messageGo to next message
Hi Dimitris,
I'll develop your idea, so now I'm practising with EGL.
I want launch an EGL file which its target is the console but
I want to generate the same code to a file(output.txt).
I have seen examples that using severals EGL files to write to a file, eg.:
driver.egl:
for (i in Sequence{1..10}) {
var delegate : Template;
-- Pass parameters to the template
delegate := TemplateFactory.load('delegate.egl');
delegate.populate('foo', i);
delegate.store(i+'.txt', true);
delegate.egl:
[%=foo%]
but I would like do it using only one EGL file. It is possible?
Thanks for your help,
Álvaro
Re: Is it possible customize EMF Tree Editor programmatically ? [message #515984 is a reply to message #515950] Mon, 22 February 2010 06:52 Go to previous message
Hi Alvaro,
To store the output in a file, in the launch configuration you can
select the "Generate text to a file" option.
Dimitris
ajimenezr wrote:
> Hi Dimitris,
> I want launch an EGL file which its target is the console but I want to
> driver.egl:
> delegate.egl:
> [%=foo%]
> Álvaro
Re: Is it possible customize EMF Tree Editor programmatically ? [message #586553 is a reply to message #515264] Mon, 22 February 2010 05:33 Go to previous message
Hi Dimitris,
driver.egl:
delegate.egl:
[%=foo%]
Álvaro
Re: Is it possible customize EMF Tree Editor programmatically ? [message #586608 is a reply to message #586553] Mon, 22 February 2010 06:52 Go to previous message
Hi Alvaro,
Dimitris
ajimenezr wrote:
> Hi Dimitris,
> driver.egl:
> delegate.egl:
> [%=foo%]
> Álvaro
Previous Topic:Emfatic documentation ?
Next Topic:problem executing .eol with ant
Current Time: Thu Jul 24 22:47:20 EDT 2025
Powered by FUDForum. Page generated in 0.07409 seconds
