Home » Eclipse Projects » Remote Application Platform (RAP) » Apache httpd problem
Apache httpd problem [message #515799] Sat, 20 February 2010 20:22 Go to next message
Hi all
I have a RAP application running on a tomcat server on port 8080. The
application has a branding servlet called 'home'.
There is also an Apache Httpd server running on port 80 that redirects
requests (via mod_proxy and mod_rewrite) to the RAP servlet.
My problem is the following:
After two Browser refresh (F5 in Firefox) the theme I have declared for
the branding servlet is gone and never appears again.
This doesnt happen if I access the servlet via Tomcat.
Can anyone help me?
P.S.: I had problems deleting sessionStore cookie in that httpd+tomcat
configuration. I implemented a Filter to delete the cookie.
Thanks.
Gustavo
Re: Apache httpd problem [message #515978 is a reply to message #515799] Mon, 22 February 2010 06:41 Go to previous messageGo to next message
Gustavo,
I can't help you much with Apache + Tomcat. However, did you try to run
the scenario without your filter?
HTH
Rüdiger
On 21.02.2010 02:22, Gustavo wrote:
> Hi all
> Can anyone help me?
> Thanks.
> Gustavo
Re: Apache httpd problem [message #517348 is a reply to message #515978] Fri, 26 February 2010 22:08 Go to previous messageGo to next message
Hi Rüdiger
I have tried that but the sessionStore cookie problem always shows a
"Session expired" message. I believe its related to a cookie problem,
any hint about it?
Thanks!
Gustavo
Rüdiger Herrmann wrote:
> Gustavo,
> HTH
> Rüdiger
>> Hi all
>> Can anyone help me?
>> Thanks.
>> Gustavo
Re: Apache httpd problem [message #517349 is a reply to message #515978] Fri, 26 February 2010 22:13 Go to previous messageGo to next message
Hi Rüdiger
any hint about it?
Thanks!
Gustavo
> Gustavo,
> HTH
> Rüdiger
>> Hi all
>> Can anyone help me?
>> Thanks.
>> Gustavo
Re: Apache httpd problem [message #517350 is a reply to message #517349] Fri, 26 February 2010 22:46 Go to previous messageGo to next message
Hi Rüdiger
(Sorry for the duplicated message before)
I have observed the following:
The first request to the branding servlet looks like this when I access
through Apache:
http://mydomain.org/home ;jsessionid=1AE9F6FA1EA04A9F913F0ED125053CA4?nocache=1267240 977790&1117249428=591%2C14&1209758426=582%2C14&5 63911256=1278%2C62&
startup=view&uiRoot=w1&w1.bounds.height=274&w1.b ounds.width=1278&w4t_ajaxEnabled=true&w4t_height=274 &w4t_scriptEnabled=true&w4t_survey=true&w4t_widt h=1278
and directly through Tomcat:
http://localhost:8080/myservlet/home?nocache=1267240870224&a mp;1117249428=591%2C14&1209758426=582%2C14&563911256 =1278%2C62&
and using Firebug the response from the first request is:
At the first time:
org.eclipse.swt.EventUtil.suspendEventHandling();var req =
org.eclipse.swt.Request.getInstance();req.setRequestCounter( "0"
);qx.theme.manager.Meta.getInstance().setTheme(
org.eclipse.swt.theme.Custom_1
);org.eclipse.swt.Request.getInstance().setTimeoutPage(
"<html><head><title>Session timed out</title></head><body><p>The server
session timed out.</p><p>Please click <a {HREF_URL}>here</a> to restart
the session.</p></body></html>" );....
At the second time after two F5 refresh I lose my theme:
org.eclipse.swt.Request.getInstance();req.setRequestCounter( "3"
org.eclipse.swt.theme.Default
The difference in the response object could shed some light on the problem:
org.eclipse.swt.theme.Custom_1 )
org.eclipse.swt.theme.Default )
In my filter I check if the sessionStore cookie is present and if the
jsessionid is not. If true I invalidate the sessionStore cookie and add
it to the response object, that way I dont get the "session expired"
message.
This strange behaviour only happens when I access the branding servlet
trough Apache Httpd and not Tomcat.
Gustavo
Gustavo wrote:
> Hi Rüdiger
> any hint about it?
> Thanks!
> Gustavo
>> Gustavo,
>> run the scenario without your filter?
>> HTH
>> Rüdiger
>>> Hi all
>>> Can anyone help me?
>>> Thanks.
>>> Gustavo
Re: Apache httpd problem [message #517361 is a reply to message #517350] Fri, 26 February 2010 22:38 Go to previous messageGo to next message
Hi Gustavo,
it looks like your application is based on RAP 1.2. Can you try it with
RAP 1.3M5 or CVS HEAD?
Best,
Ivan
On 2/27/2010 5:46 AM, Gustavo wrote:
> Hi Rüdiger
> access through Apache:
> At the first time:
> server session timed out.</p><p>Please click <a {HREF_URL}>here</a> to
> restart the session.</p></body></html>" );....
> problem:
> add it to the response object, that way I dont get the "session
> expired" message.
> Thanks
> Gustavo
> Gustavo wrote:
>> Hi Rüdiger
>> any hint about it?
>> Thanks!
>> Gustavo
>>> Gustavo,
>>> HTH
>>> Rüdiger
>>>> Hi all
>>>> for
>>>> Can anyone help me?
>>>> Thanks.
>>>> Gustavo
Re: Apache httpd problem [message #517442 is a reply to message #517361] Sat, 27 February 2010 21:11 Go to previous message
Hi Ivan
I switched to 1.3 M5 and it worked! Although, I had to keep my filter
and set maxAge property to -1 for jsessionid and settingstore cookies so
they get deleted at every browser refresh.
Thanks!!
Gustavo
Ivan Furnadjiev wrote:
> Hi Gustavo,
> Best,
> Ivan
>> Hi Rüdiger
>> At the first time:
>> problem:
>> expired" message.
>> Thanks
>> Gustavo
>> Gustavo wrote:
>>> Hi Rüdiger
>>> any hint about it?
>>> Thanks!
>>> Gustavo
>>>> Gustavo,
>>>> HTH
>>>> Rüdiger
>>>>> Hi all
>>>>> for
>>>>> Can anyone help me?
>>>>> Thanks.
>>>>> Gustavo
Previous Topic:View PDF, CHM files within a RAP Application
Next Topic:Urgent: How to use IApplication support???
Current Time: Sat Jul 19 00:21:47 EDT 2025
Powered by FUDForum. Page generated in 0.30427 seconds
