Home » Modeling » Epsilon » problem executing .eol with ant
problem executing .eol with ant [message #515970] Mon, 22 February 2010 06:34 Go to next message
hi all
i tried to run an .eol file from ant (as shown in the epsilon book, page 165), but it seems it could not find the epsilon.eol task.
autocompletion of 'epsilon.eol' works in the editor, so i'm not sure what's the problem.
my .ant file:
<project name="MyProject" default="main">
<target name="main">
<epsilon.eol src="test.eol"/>
</target>
</project>
error message:
BUILD FAILED
C:\workspace\test\build.xml:3: Problem: failed to create task or type epsilon.eol
Cause: The name is undefined.
thx for your help
marco
[Updated on: Mon, 22 February 2010 06:37] by Moderator
Re: problem executing .eol with ant [message #515973 is a reply to message #515970] Mon, 22 February 2010 01:46 Go to previous messageGo to next message
Hi Marco,
You need to select the "Run in the same JRE as the workspace" option
under the JRE tab of your launch configuration (see
http://eclipse.org/gmt/epsilon/doc/workflow/)
Dimitris
Marco.Kranz@fokus.fraunhofer.de wrote:
> hi all
> what's the problem.
> my .ant file:
> </target>
> </project>
> error message:
> BUILD FAILED
> epsilon.eol
> thx for your help
> marco
Spread the word: http://www.eclipse.org/gmt/epsilon/spreadtheword
Follow Epsilon on Twitter: http://twitter.com/epsilonews
Re: problem executing .eol with ant [message #516004 is a reply to message #515973] Mon, 22 February 2010 08:10 Go to previous messageGo to next message
thanks dimitris
now i have another question, that is...
if i want to work on an ecore file within my .eol file, do i have
to load this model via 'epsilon.loadmodel', or can i just use it?
(they're both in the same folder)
i get
EXCEPTION: Type 'Ecore!EPackage' not found...
but maybe it's just that i try to access the .ecore in the wrong way?
i'm not sure
thanks again...
marco
[Updated on: Mon, 22 February 2010 08:10] by Moderator
Re: problem executing .eol with ant [message #516007 is a reply to message #516004] Mon, 22 February 2010 08:19 Go to previous messageGo to next message
Hi Marco,
Yes. You need to load it first. Here's an example:
<project default="main">
<epsilon.emf.loadModel
name = "Ecore"
modelfile="foo.ecore"
metamodeluri="http://www.eclipse.org/emf/2002/Ecore"
read="true"
store="false"/>
<epsilon.eol>
EClass.all.size().println();
<model ref="Ecore"/>
</epsilon.eol>
</target>
</project>
Dimitris
> thanks dimitris
> i get
> i'm not sure
> thnaks again...
> marco
Re: problem executing .eol with ant [message #516008 is a reply to message #516007] Mon, 22 February 2010 08:32 Go to previous messageGo to next message
great, that worked!
thanks alot dimitris!
Re: problem executing .eol with ant [message #586580 is a reply to message #515970] Mon, 22 February 2010 06:42 Go to previous messageGo to next message
Hi Marco,
Dimitris
> hi all
> what's the problem.
> my .ant file:
> </target>
> </project>
> error message:
> BUILD FAILED
> epsilon.eol
> thx for your help
> marco
Re: problem executing .eol with ant [message #586618 is a reply to message #586580] Mon, 22 February 2010 08:10 Go to previous messageGo to next message
thanks dimitris
i get
i'm not sure
thnaks again...
marco
Re: problem executing .eol with ant [message #586627 is a reply to message #586618] Mon, 22 February 2010 08:19 Go to previous messageGo to next message
Hi Marco,
name = "Ecore"
read="true"
store="false"/>
<epsilon.eol>
</epsilon.eol>
</target>
</project>
Dimitris
> thanks dimitris
> i get
> i'm not sure
> thnaks again...
> marco
Re: problem executing .eol with ant [message #586641 is a reply to message #516007] Mon, 22 February 2010 08:32 Go to previous message
great, that worked!
Previous Topic: Is it possible customize EMF Tree Editor programmatically ?
Next Topic:[n] Multiplicity problem in EMFATIC file
Current Time: Fri Jul 25 08:28:35 EDT 2025
Powered by FUDForum. Page generated in 0.30734 seconds
