Dialog based application? [message #515935] |
Mon, 22 February 2010 04:47  |
Hello all,
I am currently working on my first RCP project. However, the requirements I'm supposed to meet seem not quite to fit the offerings of RCP, so I am experiencing some difficulties.
I'm supposed to create a small dialog-based application which should be usable both as a separate program and as a plug-in for other RCP applications. (In the separate case, though, it should ideally look like just another dialog box spawned by the program that called it, which will most probably be a Windows application using MFC.)
Here's what I'm wondering about right now, and I'd be grateful for some advice:
1. When running as a separate program, I want to have just the dialog - no workbench window (at least not visible). Can I do this by setting its initial size to (0, 0) in the window advisor? Or is there a better way after all?
2. What would be the best way to open the dialog automatically on startup? The advisor's postWindowOpen() method?
3. How can I programmatically terminate the application?
4. I need to allow the passing of data to my program (eg. a filename). I know how to do this via command-line arguments, which is fine for the separate program case, but how do I do it for a plug-in?
By the way, if you think that Eclipse RCP is the wrong tool for this job after all, so do I... but it's a company policy that all Java applications should use it.
Thanks in advance,
Ulrich
Re: Dialog based application? [message #534244 is a reply to message #534055] |
Tue, 18 May 2010 08:55   |
--------------050205000605010904010007
laurieaw@us.ibm.com wrote:
> I have the same issue as this initial post and have a couple of followup
> questions:
> 1) You wrote:
> If it's a dialog, what about focusing on JFace+SWT (instead of full
> RCP)? JFace+SWT(+3 other jars) would allow you to launch a dialog from
> a java program.
> The advantage I see to using RCP is the packaging. This builds an
> executable that can be shipped. If I don't use RCP then I would need to
> determine how to build a deployable executable. Not impossible just
> curious if this a good use for RCP.
It depends on the cost you are willing to pay. If you don't need to run
the workbench, an RCP app that includes JFace, SWT, and enough of the
core.runtime to run includes 14 plugins, and runs almost 6 Meg. A Java
app including SWT+JFace and the few other bundles they need is about 3.5
Meg.
> 2) You wrote:
> For a more complex option you can write a "container" that generates all
> of your content. Use the container in your JFace+SWT to get dialog
> only, and host the container in a view when added to your RCP app.
> Can you elaborate on this some more and any known example of writing a
> container? I am stuck on how to launch my dialog from a view when I just
> want the dialog shown and not the workbench.
It depends. I've attached a small RCP app that only launches a dialog
and then exits.
It's not clear what requirements you are trying to satisfy. Isn't an
app that's a dialog basically an app with one window, one perspective,
and one view? Why would you want to launch an SWT dialog over an
Workbench Window with one view in it? Or is it that you'd like to have
a JFace dialog that you could launch from a minimal RCP app as well as
by command from an eclipse based IDE?
As for the container reference, by that I just mean creating a class,
MyContents, that takes the parent composite and whatever else is needed
to create contents on that composite.
Then MyContents could be instantiated in a JFace dialog or in the
createPartControl(*) of a view easily.
Later,
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Content-Type: application/zip;
name="dialogProj.zip"
Content-Disposition: inline;
filename="dialogProj.zip"
UEsDBBQACAAIANdCsjwAAAAAAAAAAAAAAAAWAAAAei5leC5kaWFsb2cvLmNs YXNzcGF0aJWQ
wWoCMRCGz/UpltydrZfiYVcpZQsV1KJbryUmwzptOomTROrb60KlRWiht/mH bz5+ppp+frji
gBLJc61GcKsKZOMtcVerl/ZxOFbTyaAyTscYdNpNBjffATnJsXgntrUynlXR L2vlpQM0jkJE
eLMJnM5sdmcjzFbN68Ny0d4/LZpVec0RJxTWDixucweZvi5RYJ00Wy12M2+P AcuZPuh1MxzB
nSr/2yhYBOMFQXCfSdA+u9wRxz9MUczF1I+/gz6nkNOF3RL3bFX++N4JUEsH CElK+7bOAAAA
cQEAAFBLAwQUAAgACADXQrI8AAAAAAAAAAAAAAAAFAAAAHouZXguZGlhbG9n Ly5wcm9qZWN0
vZJBSwMxEIXP9leUvZvorYd0C7Z4U4TqD4jJmKYkk5BkS+mvd3Y3LW5FEARv 7715kw+SiNXR
u/kBUrYBl809u2vmgCpoi2bZvL0+3i6aVTsTMYU9qLKBrJKNhcrt7Eag9NCe GByZttIFI/iQ
0EQF7wFLK/hZUVgPyb3mX817Z53eRlBkqlvTmkTdB5UTkmGgnI0Z2F4XpkIi IQ9y6EO6wGlB
JtP11DxaPvGCXxN+g4wa2JNE+wG5PPwbcat24OWfeTWoV0yo0iUYq6P+Bn5x nbH4PAx77lD6
oT95DbxeOUvCXV598o8+AVBLBwhNG50r6AAAAIQCAABQSwMEFAAIAAgA10Ky PAAAAAAAAAAA
AAAAADAAAAB6LmV4LmRpYWxvZy8uc2V0dGluZ3Mvb3JnLmVjbGlwc2UuamR0 LmNvcmUucHJl
ZnOVj7EKwjAYhPc+RcA9tEW0FLqIDgqCQ18gptcSSf6EP6nQt7eKzq3LDcfd cd+mHSGuahJF
JfKqLst6uxenYyvKvMgzz4OEtiZEyEeXpPaMWVwwFiwD+7uFk6DRnTtQMr0B N2D2vFDVvsMA
kknxgHSzKvWeXVPIXfYrBUYPBmlE+QRH46kpVs4asoZwiXyYEt5mA1Lz124l kYoRnP5kin5k
jQ/D0ksXrFH0Db8AUEsHCL5Zs7OsAAAAgwEAAFBLAwQUAAgACADqQrI8AAAA AAAAAAAAAAAA
IAAAAHouZXguZGlhbG9nL01FVEEtSU5GL01BTklGRVNULk1GdZDBTsMwDIbv fYpoZ2ptIO2Q
aQcmekEaQkzinqVuZZQmzHHKuqen0GVik5Bv/j7bf7I1nhqMUr4jRwpeqwXM i03ytcNye4YX
dp/Ji+lQqycyLrS5txu6fXBkJ3YCPEL9K6wi+dahjBvWwgnzwN+TYx2ScdQQ cuaPVqg3Evhq
G1zaxRseEjGWk69V4BbQOvqMCDYwAicv1OFdcYXil6z204l+irCePcAS5rMb 8aMxFv9Rc8hz
hro6ok0yCpXviYPv0ItWz6Y3u6pcwPLmUaP4+vNZg1bOnIbiG1BLBwh6yHA+ 2QAAAIgBAABQ
SwMEFAAIAAgAKUOyPAAAAAAAAAAAAAAAACsAAAB6LmV4LmRpYWxvZy9iaW4v ei9leC9kaWFs
b2cvQWN0aXZhdG9yLmNsYXNzhZJdTxNBFIbfs9126VKgfFsBRYSkmNBN9BI1 UVBDskETsLdk
uh2WwWWn2c5iw6/y48LEC3+AP8p4dtqUxABmszNnZt7zzHtO5vefn78APMWm B4eweBXIQdBV
ItFx8Coy6lIYnXlwCfVzcSmCRKRx8L5zLiPjoULY0Fkc6H6sgtNMXMjPOvsU vM7TbiLH2YTq
h/Dju4PDk4N9wlx4zTkymUrjXcLUnk77RqSmLZJcTmCSMHnVkoPW0Amh0kvy WKWE5fBGh8yo
PFepMi8JpeZ2m+Du6a70UcJcDdOYIcyEKpWH+UVHZseik8jCio5E0haZKtaj TdecqT6hzHYy
Q9hqhrdWyKaNHJjd4jr/zSCSPaO4Dg/3CfPXVY5PqiCs1lDDFMGLhsncwf9f wK76Rvf4llia
fXkq8oQTG83tW5vhH+k8i+RbVZQ0PT5pFa7wiH2U+C/DQQMeJjiu8iNw4PPH 9jh2eY/bxmOd
V894Jp7LT35g9quVzvPo8wwssHiRR3CqFfGqQBCWsMyKeyNcw6JecORY1Hes /ItaZeGaRS0N
RSNUEa3hgXXx8C4o3QDdZOHWndAq1m1T6lZN9sz9hpUvY1LF7u5YimNr27DR 479QSwcIP4vm
Fc0BAABAAwAAUEsDBBQACAAIAP1DsjwAAAAAAAAAAAAAAAAtAAAAei5leC5k aWFsb2cvYmlu
L3ovZXgvZGlhbG9nL0FwcGxpY2F0aW9uLmNsYXNzlVJdT9NQGH7O6NYxKh8D Nj7UOUDdBqOK
ejVjgoDJYmEXkCnemK47GQdrW9dOhjf+JfViSyTxB/ijjO/pllmJJHLR857z 9un7fPT8/PX9
B4AtPFERY8h+0nlXbwrTdlv6tufZwjID4ToqFIbpU/Ojqdum09JrjVNuBSoS DGtuu6Vzyxae
z3X+oSMct6ubnqdXI98zJJ4KRwTPGMYKxTqDsuM2eQpjmNCgIskwZQiHH3Te N3j7yGzYnCFt
uJZp1822kOdhUwlOhM+waFwhtMIQ9wOzHTBsF4z/kbbjOgHvBpWicdkezUrt dS3uSZivYo5h
9g9m9EZFhiEXpfLPAv1MNFs88PVd4Xu2eZ7CPCZULDLMRZXvn++GmxQWsCyT uMmw8rfu6LDD
E27blWJdwm9ryOEOw6TPg+e2a72rOTWPU9JK4c0AsaJhFWvUcMM+BV+VMu5p uC8TV5skzfX5
OOIoaihhnXp7r6tHb2svyWkkjiol1OJtykO1BmkxlK8V7pCNgmDIX2lvmBWh E4N8GDLGv+Ii
hOIHrkc/6NDttC3+QsjLMR1h3pTykQf5pidOd1xWumq0jtNJp8qoxkt9pL7S JgaN1kTYTOIG
rdoAgElMUaXxmCFUmvYKnWbDMZ9prEJ19QLzx31k9y+wcMz6WDooKz3cKveQ f7XRw91vKHwZ
kSwRjRwvaWZofIYIlml8jk6SuDQYOSSWuw2UiTJJqE1SHiNcGg/wMPS0NfK0 Hsqk57KfbMQP
G/l5FKIe/wZQSwcIbhjY9TwCAAADBAAAUEsDBBQACAAIAJNDsjwAAAAAAAAA AAAAAAAqAAAA
ei5leC5kaWFsb2cvYmluL3ovZXgvZGlhbG9nL015RGlhbG9nLmNsYXNzjVFd TxNBFD231G67
lIKlFKsiBfygSpzE1xoSgyGaLL60acKTmW6v2yHLbrM7CPqr9EUSSIzP/ijC zG4lPoiwD7Pn
3j1zztl7f1+c/QTwCk8dFAiNr4JPxEjJMA7E3pe3GXBQJLTjJBDsh2qSsjj4 JH2e0lKRswil
1ypSepuwvun9zU6PtThWo4B1KnpjDsNuZ0Ao7sQjdjGDShV3UCLMeyriD0eH Q076chgyoe7F
vgwHMlG2njaLeqxSQtP7V9QuYXYiE450ZkRYvSEJYcFPWGrO778xmLB7ff6d +HASp0pzt/Mf
TqSTOOzan1usYgF3HSwR1m7UdLBMWLmO5skhhy6aaNmB3Sc8u03M951BGQ8J 5Xeq3R9zwlbh
URWraBOclHWfTzRhadM7kJ+lCGUUiJ5OVBRkWyrl0yRs3MKLQD7B7cVHic+7 ym5r7s9mXlp5
rIHMUOxTMMis3ZyOqbZNXTDv0vMXpyh/z7675nSz7pxh1jBrUDNnoWp6yFAN 80ajaKc81fpo
KuvRslr1X2jsnaO5vzVzinv1Bz+wsvXtSr6WEeuoYBHLaGQW7fzylUXLhF43 0hVjsWGQDf44
U3hyCVBLBwhIQFr6wAEAAD0DAABQSwMEFAAIAAgA6kKyPAAAAAAAAAAAAAAA ABwAAAB6LmV4
LmRpYWxvZy9idWlsZC5wcm9wZXJ0aWVzK84vLUpO1dNTsFUoLkrW58ovLSko LQHzkzLz9LmA
hF5mXnJOaUpqMVDM1zXEUdfTz01fJ4ZLARXoYQoV5JSmA/VX5OZwAQBQSwcI VCxpykcAAABo
AAAAUEsDBBQACAAIAF1EsjwAAAAAAAAAAAAAAAAaAAAAei5leC5kaWFsb2cv ZGlhbG9nLnBy
b2R1Y3SVVE2P0zAQvfdXWBbXuFt2QT0kWyGhSkhFHFgkrq4zcb044+CPNgXx 37FD0gYJbc0l
kd88v/nwzJSbvtXkCNYpgxVdsTtKAIWpFcqKfnnaFmu6eVyUm66GK+2evUno ouysqYPwBHkL
FR1PlKi6oj8Y9KxWXBvJLgbedVoJ7geVOUPVK0qCgy1wHyy4ijZcO4hSKHSo YccDikP0X1Fv
A9DonBBSCoONkh9QpbsVraHhQftoTcblxTqy9Sjyzko3UBIYY5OWtwNWGEde /fTcSvDMuF+k
OM2AUwK4FYcrlE4RRH2FUEcgenZGw87Icjl3MDk9jv6+tu7hriXx39+vH9py efwX7yMXkeqi
A/8Jt8o6/3SwwGtSvDdWMhBadQ6YO3mm0INFrpngdm+QuZZrvTXo3aSdxP6U 5+9yDFing1Q4
K85wHt5z7kkYmz5ty7F2dJlJj6Gh9+cOMm88m32uuA3oVZsrPLJTBl3sxb3S yp+ZBamct2dK
GstlG2Mde+2mKHwPCk3PYnfnk1P5DObzOwsN2DibkFGU6dIlp5s3nhsuMlI1 TqrbrNiJWSQm
/TemFYae9eu3eYWfbY2REEdsatvZUgh2WDN5vTz1D+HBm89p0MYQyDB1OziC rmjcjf/7vC8L
vs4QHCr+skyxmnSmnXdNfjEsoLR9Hxe/AVBLBwjvOu58+gEAAO0FAABQSwME FAAIAAgAeUSy
PAAAAAAAAAAAAAAAABYAAAB6LmV4LmRpYWxvZy9wbHVnaW4ueG1slVLBToUw ELzzFWTvr/ii
Bw8U4sWjJ/2APtjgJqVt2kJ4fr1FKqXPaOKeYGdndnagbpdRljNaR1pxOLM7 KFF1uic1cHh7
fT49QtsUdYudJOMwjd6zhy/EyGkg1RRlWda4eFQrvL5tRT0H6s+QOkaT8hy0 HVgUZZ22yOyk
PI3IhDGSOuGDjIMm8upDN0mF6oQNXoUkf+XggmuJXqvTIPVFSMhG/btFEeyM glSOzOToIpGD
txPuO9e1wVQ2uW6UwjkOHwwX1pOQemBPyVzGrgJ9v6A6nLDFVe15/Rmfsbqf Ov+PCCPjEF/s
ZLcc/OTn5N8rlBIjJh/HC0PPoPXX25A2RtjwEh7gFp2FnH4RrL4VU25x7Gdm RcDi3/cJUEsH
CHcW0O4aAQAAyAIAAFBLAwQUAAgACAApQ7I8AAAAAAAAAAAAAAAAKgAAAHou ZXguZGlhbG9n
L3NyYy96L2V4L2RpYWxvZy9BY3RpdmF0b3IuamF2Ya1SXUvDQBB8zv2KRX1o C03wOQhWK1KR
Wvx4lutlmx5e78Ldplal/91N0qa2IoL4FLjMzM7sTiHVi8wR3mNcxZmWxuWp EHpROE/gfB67
kOt45uUCX51/iS9KmxkcKNJLSc6nv0IvnSVcEYsmvZ6AHjzOEeSWD8rIEEAx yDsTgPhnYcq8
ry0YPUNQb8og0xJRlFOj1YbQGgCeb3CBlgIceIMPIaIkqQduNUdDEW2EAkni z0xbaeCBvLY5
TG6frkfj59EQzuDoy0qOUkiSk/HduD++feifnuyEw1x6zEBblrMKWd1X03Er v3NTWdA2FRFz
eRPRZhUcPZAvFUOqt6T11zI7XU4SrauZDa1jne3fyKXMnOrWL+cBsT4BKqOL gHGp42ZePJiy
PO/7aTSpH47ZmKfOb/fq7ptZOp1Bw9yD1Zer4Hw5714DXK0UFqSdrTxHjQde Js11SP81hCv+
mIGJf4pgS2PaCE2Ge6TS26a134oADebc16CfMMlhH3eFyZGGOJOloaYB0Uap LRJbWYtPUEsH
CCrN71COAQAAwQMAAFBLAwQUAAgACAD9Q7I8AAAAAAAAAAAAAAAALAAAAHou ZXguZGlhbG9n
L3NyYy96L2V4L2RpYWxvZy9BcHBsaWNhdGlvbi5qYXZhlVDLasMwEDxbX7FH +6J8gCn0kRxC
KT60h96KIi+2GkWrSuvYacm/17FVSMFQelqYx+7seKX3qkH4lDjI2ihLTSmE OXgKDBQaidoa
H1HiR2ccDVJ5L7d33lujFRty5X/ED+QYB170xJ5lb+oGOcq1id6q05+65xat HfP6bjeeAG1V
jHB1D0a/xQM6jnCdA76EyG6rI4ZgahRZ8le7d9QMkVXgfCE36HkWwG2gPsJm 0OjTwixLqaFO
8wYc9pDQvChHydNpPXUMc9VJ8oPmrrN20s20jMj3lvS+cpVHl3Po8JqmC5iA 6Yi8TIo4gwG5
C+7X43Lzun15qx5H+rxYwZFMPRZAPi+mn1YrcMStcQ0wQU3QYsDJfBbfUEsH CNjdEV4XAQAA
PAIAAFBLAwQUAAgACACTQ7I8AAAAAAAAAAAAAAAAKQAAAHouZXguZGlhbG9n L3NyYy96L2V4
L2RpYWxvZy9NeURpYWxvZy5qYXZhjZHPSgMxEMbPyVMMPW1B8gJFUFTwoO2h C57T7Oc2Gjdh
knWr0nc37EYrqLS3+fPLN/NNgjbPugW9K+xUY7Xz7UJK+xI8J/LcKhhnQ4R6 etQGhYjqupB/
gHFIav1Q/9sbbNMiRXXlcz/ahBPILrF3R7k7vcFxar2Fy5QM/cZZQ8bpGOn+ bXJE2CV0TaSS
fkgpCviFVKMABc3o0hjPMyZE7AO4+lleSLGXQoqL1SuYbYOsxT7BJDRUTJFh 6IRJ+jLH1fdd
yohJ/VA1dE4HaE7jXPVLpjzOO4gOA423qcwZ5a9Ry9XyZq4iUp3tVrNbS/UW jNlIM1LPHZlx
e7mXn1BLBwhDhL2W/QAAACICAABQSwECFAAUAAgACADXQrI8SUr7ts4AAABx AQAAFgAAAAAA
AAAAAAAAAAAAAAAAei5leC5kaWFsb2cvLmNsYXNzcGF0aFBLAQIUABQACAAI ANdCsjxNG50r
6AAAAIQCAAAUAAAAAAAAAAAAAAAAABIBAAB6LmV4LmRpYWxvZy8ucHJvamVj dFBLAQIUABQA
CAAIANdCsjy+WbOzrAAAAIMBAAAwAAAAAAAAAAAAAAAAADwCAAB6LmV4LmRp YWxvZy8uc2V0
dGluZ3Mvb3JnLmVjbGlwc2UuamR0LmNvcmUucHJlZnNQSwECFAAUAAgACADq QrI8eshwPtkA
AACIAQAAIAAAAAAAAAAAAAAAAABGAwAAei5leC5kaWFsb2cvTUVUQS1JTkYv TUFOSUZFU1Qu
TUZQSwECFAAUAAgACAApQ7I8P4vmFc0BAABAAwAAKwAAAAAAAAAAAAAAAABt BAAAei5leC5k
aWFsb2cvYmluL3ovZXgvZGlhbG9nL0FjdGl2YXRvci5jbGFzc1BLAQIUABQA CAAIAP1Dsjxu
GNj1PAIAAAMEAAAtAAAAAAAAAAAAAAAAAJMGAAB6LmV4LmRpYWxvZy9iaW4v ei9leC9kaWFs
b2cvQXBwbGljYXRpb24uY2xhc3NQSwECFAAUAAgACACTQ7I8SEBa+sABAAA9 AwAAKgAAAAAA
AAAAAAAAAAAqCQAAei5leC5kaWFsb2cvYmluL3ovZXgvZGlhbG9nL015RGlh bG9nLmNsYXNz
UEsBAhQAFAAIAAgA6kKyPFQsacpHAAAAaAAAABwAAAAAAAAAAAAAAAAAQgsA AHouZXguZGlh
bG9nL2J1aWxkLnByb3BlcnRpZXNQSwECFAAUAAgACABdRLI87zrufPoBAADt BQAAGgAAAAAA
AAAAAAAAAADTCwAAei5leC5kaWFsb2cvZGlhbG9nLnByb2R1Y3RQSwECFAAU AAgACAB5RLI8
dxbQ7hoBAADIAgAAFgAAAAAAAAAAAAAAAAAVDgAAei5leC5kaWFsb2cvcGx1 Z2luLnhtbFBL
AQIUABQACAAIAClDsjwqze9QjgEAAMEDAAAqAAAAAAAAAAAAAAAAAHMPAAB6 LmV4LmRpYWxv
Zy9zcmMvei9leC9kaWFsb2cvQWN0aXZhdG9yLmphdmFQSwECFAAUAAgACAD9 Q7I82N0RXhcB
AAA8AgAALAAAAAAAAAAAAAAAAABZEQAAei5leC5kaWFsb2cvc3JjL3ovZXgv ZGlhbG9nL0Fw
cGxpY2F0aW9uLmphdmFQSwECFAAUAAgACACTQ7I8Q4S9lv0AAAAiAgAAKQAA AAAAAAAAAAAA
AADKEgAAei5leC5kaWFsb2cvc3JjL3ovZXgvZGlhbG9nL015RGlhbG9nLmph dmFQSwUGAAAA
AA0ADQAdBAAAHhQAAAAA
--------------050205000605010904010007--
FUDForum. Page generated in 0.05360 seconds
