NoClassDefFoundError in Activator [message #515592] |
Fri, 19 February 2010 08:48  |
I have a problem that sounds simple, but I was not able to solve it:
two of my plug-ins have activators where the start-Method creates an IWorkbenchListener and adds it to the workbench. This is the code:
public void start( BundleContext context ) throws Exception
super.start( context );
IWorkbench workbench = PlatformUI.getWorkbench();
workbench.addWorkbenchListener( new IWorkbenchListener()
public boolean preShutdown( IWorkbench workbench, boolean forced )
if( jobManagers.isEmpty() )
return true;
Shell shell = PlatformUI.getWorkbench().getActiveWorkbenchWindow().getShel l();
String dialogBoxTitle = "Question";
String question = "There are still meshing jobs running. Still close the application?";
boolean close = MessageDialog.openQuestion( shell, dialogBoxTitle, question );
return close;
public void postShutdown( IWorkbench workbench )
// Do nothing.
It works perfectly. But since both plug-ins do the same I have created another plug-in containing an class CommonActivator with the start method as pasted above. Both of my plug-ins depend now on this common plug-in and their activator is derived from CommonActivator.
This works well as long as I start my application from eclipse. But as soon as I export the product, the plug-ins having an activator derived from CommonActivator can not be started anymore. I get an error message, that the class org/eclipse/ui/IWorkbenchListener was not found.
This mentioned class is in the plug-in org.eclipse.ui.workbench. My plug-ins depend on org.eclipse.ui which in turn depends on org.eclipse.ui.workbench. So I don't see why this class cannot be found. Is there someone who can tell me what I am doing wrong? Thank you very much!!!
Benjamin
This is the error message:
bbihler@pescara:~/Desktop/ModelManager$ ./ModelManager
!SESSION 2010-02-19 14:42:26.265 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_12
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=de_DE
Command-line arguments: -os linux -ws gtk -arch x86_64 -consoleLog
!ENTRY org.eclipse.osgi 4 0 2010-02-19 14:42:35.259
!MESSAGE An error occurred while automatically activating bundle com.twt.improver (77).
!STACK 0
org.osgi.framework.BundleException: The activator com.twt.improver.activators.ImproverActivator for bundle com.twt.improver is invalid
at org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:157)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:751)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:352)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:280)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:408)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:449)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:211)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass (BundleLoader.java:381)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal(BundleLoader.java:457)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:410)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:398)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:105)
at java.lang.ClassLoader.loadClass(ClassLoader.java:252)
at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(Bund leLoader.java:326)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:231)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1193)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:160)
at org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:874)
at org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
at org.eclipse.ui.internal.handlers.HandlerProxy.loadHandler(Ha ndlerProxy.java:351)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(Handle rProxy.java:287)
at org.eclipse.core.commands.Command.executeWithChecks(Command. java:476)
at org.eclipse.core.commands.ParameterizedCommand.executeWithCh ecks(ParameterizedCommand.java:508)
at org.eclipse.ui.internal.handlers.HandlerService.executeComma nd(HandlerService.java:169)
at org.eclipse.ui.internal.handlers.SlaveHandlerService.execute Command(SlaveHandlerService.java:241)
at org.eclipse.ui.menus.CommandContributionItem.handleWidgetSel ection(CommandContributionItem.java:770)
at org.eclipse.ui.menus.CommandContributionItem.access$10(Comma ndContributionItem.java:756)
at org.eclipse.ui.menus.CommandContributionItem$5.handleEvent(C ommandContributionItem.java:746)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1176)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3493)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3112)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
at com.twt.modelmanager.gui.Application.start(Application.java: 130)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
Caused by: java.lang.NoClassDefFoundError: org/eclipse/ui/IWorkbenchListener
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Class.java:23 89)
at java.lang.Class.getConstructor0(Class.java:2699)
at java.lang.Class.newInstance0(Class.java:326)
at java.lang.Class.newInstance(Class.java:308)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:152)
... 54 more
Caused by: java.lang.ClassNotFoundException: org.eclipse.ui.IWorkbenchListener
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal(BundleLoader.java:494)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:320 )
... 60 more
Root exception:
... 60 more
!ENTRY org.eclipse.ui 4 4 2010-02-19 14:42:35.277
!MESSAGE The proxied handler for 'com.twt.improver.handlers.ImproveHandler' could not be loaded
!ENTRY org.eclipse.ui 4 0 2010-02-19 14:42:35.283
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in com.twt.improver was unable to load class com.twt.improver.handlers.ImproveHandler.
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .throwException(RegistryStrategyOSGI.java:180)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:162)
Caused by: org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter $TerminatingClassNotFoundException: An error occurred while automatically activating bundle com.twt.improver (77).
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:125)
... 37 more
Caused by: org.osgi.framework.BundleException: The activator com.twt.improver.activators.ImproverActivator for bundle com.twt.improver is invalid
... 49 more
... 54 more
... 60 more
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2010-02-19 14:42:35.287
!MESSAGE Plug-in com.twt.improver was unable to load class com.twt.improver.handlers.ImproveHandler.
!STACK 0
... 49 more
... 54 more
... 60 more
!ENTRY org.eclipse.ui 4 4 2010-02-19 14:42:35.299
!MESSAGE Failed to execute item com.twt.improver.commands.startImprove
!STACK 1
... 37 more
... 49 more
... 54 more
... 60 more
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2010-02-19 14:42:35.301
!STACK 0
... 49 more
... 54 more
... 60 more
Re: NoClassDefFoundError in Activator [message #533855 is a reply to message #515625] |
Mon, 17 May 2010 05:56  |
Just for the archive:
I had always removed the ".qualifier" from the version string of my plug-ins, since I did not know what it is good for. Now I know what it is good for: it causes the current time stamp to be added to the version information of a plug-in when it is exported.
Back to my problem:
Even if I change the code of my plug-in, the application seems to use somehow the old plug-in in its cache if I have not changed the version string.
There are two ways to solve that.
1. Start the application with the option -clean.
2. Add ".qualifier" to the version string of each plug-in. In this case the current time stamp is added to the plug-ins version and the framework realizes that the plug-in has changed even though I have forgotten to increase the version number.
Now everything works fine and I do not have to start my application with -clean the first time after releasing a new version.
FUDForum. Page generated in 0.04640 seconds
