Home » Language IDEs » Java Development Tools (JDT) » Best Practices re JUnit
Best Practices re JUnit [message #515394] Thu, 18 February 2010 11:32 Go to next message
I would like some advice on the best way to organize my JUnit test classes in Eclipse 3.5.1. Should a given JUnit test class be in the same package as the class that it is testing? Or should it be in a different package within the same project? Should it be in the same project as the one being tested or perhaps in a separate project?
I'm not having any trouble writing and executing my JUnit tests; I'm just not sure about the best way to organize them within Eclipse.
Rhino
Re: Best Practices re JUnit [message #515547 is a reply to message #515394] Fri, 19 February 2010 05:42 Go to previous messageGo to next message
In Eclipse we use separate projects because it gives a clear separation
and makes building the (runtime) product easier.
Dani
> Rhino
Re: Best Practices re JUnit [message #515593 is a reply to message #515547] Fri, 19 February 2010 08:50 Go to previous messageGo to next message
Thank you for that information, Dani.
What do you do about package names for test cases? For example, if the package being tested is com.foo.baz, does the package for the test cases have the same name or does it get a different name, something like com.foo.baz.test?
Rhino
Re: Best Practices re JUnit [message #515601 is a reply to message #515593] Fri, 19 February 2010 08:52 Go to previous messageGo to next message
See http://wiki.eclipse.org/Naming_Conventions
Dani
> Rhino
Re: Best Practices re JUnit [message #515605 is a reply to message #515601] Fri, 19 February 2010 09:16 Go to previous message
I see! So my test package would be com.foo.tests.baz and it would be in its own project.
Thank you very much, Dani!
Rhino
Previous Topic:How to highlight reconciliation error in the texteditor
Next Topic:Viewing MANIFEST files for JARs in my build path
Current Time: Sat Jul 19 01:29:46 EDT 2025
Powered by FUDForum. Page generated in 0.10977 seconds
