Home » Eclipse Projects » JFace » Model refactoring and data Binding
Model refactoring and data Binding [message #515432] |
Thu, 18 February 2010 13:20  |
I wanted to refactor my model:
several nodes have a bunch of fields that are equivalent:
public interface Book extends EObject {
World getWorld();
Project getProject();
EList<Actor> getActor();
EList<Chapter> getChapter();
EList<Location> getLocation();
EList<Item> getItem();
String getTitle();
boolean isUnused();
TimeEvent getTime();
String getDesc();
String getContent();
Chronology getChronology();
Image getImage();
public interface Chapter extends EObject {
Book getBook();
EList<Scene> getScene();
boolean isSectionStart();
String getTitle();
boolean isUnused();
String getDesc();
Image getImage();
public interface Item extends EObject {
Actor getOwner();
String getTitle();
boolean isUnused();
String getDesc();
Image getImage();
.... etc. etc.
I wanted to refactor like this:
public interface IBase extends EObject {
String getTitle();
boolean isUnused();
String getDesc();
Image getImage();
public interface Book extends IBase {
World getWorld();
public interface Chapter extends IBase {
Book getBook();
public interface Item extends IBase {
Actor getOwner();
EMF is happy and generates the right code, but Databinding isn't!
I had things like:
protected DataBindingContext initDataBindings() {
DataBindingContext bindingContext = new DataBindingContext();
IObservableValue txtTitleObserveTextObserveWidget =
SWTObservables.observeText(txtTitle, SWT.Modify);
IObservableValue bookTitleObserveValue =
EMFObservables.observeDetailValue(Realm.getDefault(), observableChapter,
Literals.CHAPTER__TITLE);
bindingContext.bindValue(txtTitleObserveTextObserveWidget,
bookTitleObserveValue, null, null);
IObservableValue txtDescObserveTextObserveWidget =
SWTObservables.observeText(txtDesc, SWT.Modify);
IObservableValue bookDescObserveValue =
Literals.CHAPTER__DESC);
bindingContext.bindValue(txtDescObserveTextObserveWidget,
bookDescObserveValue, null, null);
ObservableListContentProvider listContentProvider = new
ObservableListContentProvider();
tViewer.setContentProvider(listContentProvider);
IObservableMap[] observeMaps =
EMFObservables.observeMaps(listContentProvider.getKnownEleme nts(), new
EStructuralFeature[]{Literals.SCENE__TITLE, Literals.SCENE__GOAL,
Literals.SCENE__DESC});
tViewer.setLabelProvider(new
ObservableMapLabelProvider(observeMaps));
IObservableList bookChapterObserveList =
EMFObservables.observeDetailList(Realm.getDefault(), observableChapter,
Literals.CHAPTER__SCENE);
tViewer.setInput(bookChapterObserveList);
return bindingContext;
This has errors because Literals.CHAPTER__TITLE, Literals.CHAPTER__DESC,
Literals.SCENE__TITLE, Literals.SCENE__DESC do not exist anymore.
I tried changing the above to:
Literals.IBASE__TITLE);
Literals.IBASE__DESC);
EStructuralFeature[]{Literals.IBASE__TITLE, Literals.SCENE__GOAL,
Literals.IBASE__DESC});
It compiles, but it does not run:
org.eclipse.core.runtime.AssertionFailedException: unknown saveable:
org.eclipse.ui.internal.DefaultSaveable@1a73d30 from part:
org.eclipse.ui.internal.ErrorEditorPart@1a73d30
at org.eclipse.ui.internal.SaveablesList.logWarning(SaveablesLi st.java:187)
at org.eclipse.ui.internal.SaveablesList.addModel(SaveablesList .java:117)
at org.eclipse.ui.internal.SaveablesList.addModels(SaveablesLis t.java:289)
at org.eclipse.ui.internal.SaveablesList.postOpen(SaveablesList .java:684)
at org.eclipse.ui.internal.PartList.partOpened(PartList.java:23 4)
at org.eclipse.ui.internal.PartList.access$0(PartList.java:210)
I'm not surprised it doesn't run. Some information is lost in the
translation (.e.g.: the oserveMaps() cannot know if it should observe a
BOOK__TITLE or a SCENE_TITLE), but I can' see how add it back.
Any suggestion is VERY welcome.
Mauro
P.S.: which is the right group for this kind of questions? Should I keep
cross-posting?
Cheers!
Mauro
Re: Model refactoring and data Binding [message #515433 is a reply to message #515432] |
Thu, 18 February 2010 13:33   |
Sorry but the exception you show doesn't has any Databinding in it.
Tom
Am 18.02.10 19:20, schrieb Mauro Condarelli:
> World getWorld();
> String getTitle();
> boolean isUnused();
> String getDesc();
> Image getImage();
> Book getBook();
> String getTitle();
> boolean isUnused();
> String getDesc();
> Image getImage();
> Actor getOwner();
> String getTitle();
> boolean isUnused();
> String getDesc();
> Image getImage();
> ... etc. etc.
> String getTitle();
> boolean isUnused();
> String getDesc();
> Image getImage();
> World getWorld();
> Book getBook();
> Actor getOwner();
> I had things like:
> at
> at
> at
> at
> Regards
> Mauro
> cross-posting?
> Cheers!
> Mauro
Re: Model refactoring and data Binding [message #515450 is a reply to message #515449] |
Thu, 18 February 2010 14:29  |
Tom Schindl wrote:
> Your problem is as said NOT databinding but the serialized model can't
> be loaded.
> Tom
You are *SO* right.
I was trying to load the old model with the new code.
Shame on me.
Loading the right file cured the problem.
Mauro
Current Time: Sun Jul 27 12:59:01 EDT 2025
Powered by FUDForum. Page generated in 0.05661 seconds
