Home » Modeling » GMF (Graphical Modeling Framework) » Synchronize semantic and notation information on editor start
Synchronize semantic and notation information on editor start [message #515207] Thu, 18 February 2010 03:23 Go to next message
Hi@all,
when I use the generated EMF tree-based Editor to add an element to the semantic model and then start the GMF-editor the newly created element is not show in the diagram. However, when I add a new element to the diagram, a new View will be created for the previously created semantic element. So the appropriate action seems to be there. But unfortunately did not find it.
How can I invoke this action on diagram start? Or is this even a bug?
Maybe some else faced this problem before, but unfortunately I could find a solution anywhere.
Thank in advance.
Martin
Re: Synchronize semantic and notation information on editor start [message #515348 is a reply to message #515207] Thu, 18 February 2010 09:35 Go to previous messageGo to next message
Hi Martin,
Does this effect happend only after a fresh workbench restart and is
gone, when you used the gmf editor at least once before editing the
model with the emf editor?
If yes:
override the getFactoryHint(IAdaptable elementAdapter) within your
specific CanonicalEditPolicys
* @generated
protected String getFactoryHint(IAdaptable elementAdapter) {
CanonicalElementAdapter element =
(CanonicalElementAdapter) elementAdapter;
int visualID = YourVisualIDRegistry.getNodeVisualID(
(View) getHost().getModel(),
(EObject) element.getRealObject());
return YourVisualIDRegistry.getType(visualID);
or better customimze the template:
templates/gmf/xpt/diagram/updater/containerBaseCanonicalMeth ods.xpt
«IMPORT 'http://www.eclipse.org/gmf/2009/GenModel
«IMPORT 'http://www.eclipse.org/emf/2002/GenModel
«EXTENSION xpt::diagram::updater::Utils»
«DEFINE getDefaultFactoryHint FOR gmfgen::GenContainerBase-»
«EXPAND xpt::Common::generatedMemberComment»
protected String getDefaultFactoryHint() {
return null;
protected String getFactoryHint(org.eclipse.core.runtime.IAdaptable
elementAdapter) {
CanonicalElementAdapter element = (CanonicalElementAdapter)
elementAdapter;
int visualID =
«EXPAND
xpt::editor::VisualIDRegistry::getNodeVisualIDMethodCall FOR
getDiagram()»((org.eclipse.gmf.runtime.notation.View)
getHost().getModel(), (org.eclipse.emf.ecore.EObject)
return «EXPAND typeMethodCall FOR getDiagram()»(visualID);
«ENDDEFINE»
«DEFINE typeMethodCall FOR
gmfgen::GenDiagram»«getVisualIDRegistryQualifiedClassName( )».getType«ENDDEFINE»
Cheers
Sven
Re: Synchronize semantic and notation information on editor start [message #515411 is a reply to message #515348] Thu, 18 February 2010 12:23 Go to previous message
Hi Sven,
thanks for the quick response.
And yes, that was the problem and overriding the factoryHint solved it ;)
Thanks again.
Martin
Sven Krause schrieb:
> Hi Martin,
> If yes:
> * @generated
> @Override
> return null;
> @Override
> elementAdapter) {
> elementAdapter;
> int visualID =
> «EXPAND
> «ENDDEFINE»
> Cheers
> Sven
Previous Topic:Why PropertySheetPage doesn't work for my GMF plugin?
Next Topic:Disable UUIDs?
Current Time: Sun Jul 20 20:01:55 EDT 2025
Powered by FUDForum. Page generated in 0.03812 seconds
