Home » Archived » M2M (model-to-model transformation) » [ATL] Problem trying to transform uml programmatically (Uml Profile not recognized/found?)
[ATL] Problem trying to transform uml programmatically [message #514988] |
Wed, 17 February 2010 07:27  |
I am trying to programmatically transform an uml model to mp, and it seems that the uml profile associated with the uml model is not loaded with it because it is complaining about the line where the stereotypes are accessed. Do I have to specify where the UML profile file is and how?
The error message is:
org.eclipse.m2m.atl.engine.emfvm.VMException: Operation not found: IN!Package1:UML!Package.getValue(org.eclipse.m2m.atl.engine. emfvm.lib.OclUndefined,java.lang.String)
at __applyEcimMomToMIMType(ECIMtoMP.atl[47:13-47:86])
local variables: self=thisModule, link=org.eclipse.m2m.atl.engine.emfvm.lib.TransientLink@36ae36ae, s=IN!Package1:UML!Package, t=OUT!<unnamed>:MP!MimType, copyRightType=OUT!<unnamed>:MP!CopyrightType
at __exec__(ECIMtoMP.atl)
local variables: self=thisModule, e=org.eclipse.m2m.atl.engine.emfvm.lib.TransientLink@36ae36ae
at main(ECIMtoMP.atl)
Here is the code
// Initial Setup
ILauncher launcher = CoreService.getLauncher("EMF-specific VM");
ModelFactory factory = CoreService.createModelFactory(launcher.getDefaultModelFactoryName());
IInjector injector = CoreService.getInjector(factory.getDefaultInjectorName());
IExtractor extractor = CoreService.getExtractor(factory.getDefaultExtractorName());
//metamodels
final IReferenceModel umlMetamodel = factory.newReferenceModel();
injector.inject(umlMetamodel, "http://www.eclipse.org/uml2/2.1.0/UML");
final IReferenceModel mpMetaModel = factory.newReferenceModel();
injector.inject(mpMetaModel, "file:/C:/Mp.ecore");
// Creating models
IModel umlModel = factory.newModel(umlMetamodel);
IModel mpModel = factory.newModel(mpMetaModel);
//load the input-file
injector.inject(umlModel, inputFile.getFullPath().toString());
Map<String, Object> options = new HashMap<String, Object>();
options.put("allowInterModelReferences", "true");
options.put("profile", "true");
// Getting launcher
launcher.initialize(options);
// Launching
launcher.addInModel(umlModel,"IN","UML");
launcher.addOutModel(mpModel, "OUT", "MP");
launcher.addLibrary("HelperFunctions", launcher.loadModule(asmF));
launcher.launch(ILauncher.RUN_MODE,
new NullProgressMonitor(),
options,
asmA,
asmB,
asmC,
asmD,
asmE);
Thanks in advance!
[Updated on: Wed, 17 February 2010 07:29] by Moderator
Re: [ATL] Problem trying to transform uml programmatically [message #515006 is a reply to message #514988] |
Wed, 17 February 2010 03:38   |
--------------040208060101030308090605
Le 17/02/2010 13:27, Shaman_Mahmoudi a écrit :
I guess the problem is here:
You have to check before calling the method that the stereotype you give
as argument isn't null.
Anyway, the error message should be more explicit, I will take a look at
that.
William
java.lang.String)
> link=mailto:org.eclipse.m2m.atl.engine.emfvm.lib.TransientLink@36ae36ae,
> e=mailto:org.eclipse.m2m.atl.engine.emfvm.lib.TransientLink@36ae36ae
> Here is the code
> // Initial Setup
> CoreService.createModelFactory(launcher.getDefaultModelFacto ryName());
> //metamodels
> // Creating models
> options.put("","true");
> // Getting launcher
> // Launching
> launcher.launch(ILauncher.RUN_MODE, new NullProgressMonitor(), options,
> asmA,
> asmB,
> asmC,
> asmD,
> asmE);
> Thanks in advance!
Ne manquez pas notre prochaine formation ATL inter entreprises:
ATL - Paris - du 2 au 3 Décembre 2009
Pour plus de dates et pour le détail de cette formation:
http://www.obeo.fr/pages/formations/fr
Don't forget our next ATL training:
ATL - Paris - 2009 December from 2th to 3th
More dates and training program on:
name="william_piers.vcf"
filename="william_piers.vcf"
YmVnaW46dmNhcmQNCmZuOldpbGxpYW0gUGllcnMNCm46UGllcnM7V2lsbGlh bQ0Kb3JnOk9i
ZW8NCmFkcjoyIHJ1ZSBSb2JlcnQgU2NodW1hbm47O2xvdCAyNDtOQU5URVM7 OzQ0NDA4O0Zy
YW5jZQ0KZW1haWw7aW50ZXJuZXQ6d2lsbGlhbS5waWVyc0BvYmVvLmZyDQp0 aXRsZTpNREEg
Q29uc3VsdGFudA0KdGVsO3dvcms6KzMzICgwKTIgNTEgMTMgNTAgNTMNCnVy bDpodHRwOi8v
d3d3Lm9iZW8uZnINCnZlcnNpb246Mi4xDQplbmQ6dmNhcmQNCg0K
--------------040208060101030308090605--
Re: [ATL] Problem trying to transform uml programmatically [message #515280 is a reply to message #515012] |
Thu, 18 February 2010 05:57   |
I have tried to run it through an ant task, and I get the same errror message.
If I run it through the atls own run configuration, it works just fine.
In the ant task, I superimposed all the atl files to one single one due to that superimpose is not currently supported in the officially released ATL.
module ECIMtoMP;
create OUT : MP from IN : UML, INPROFILE : UML;
uses HelperFunctions;
and the ant task:
<project name="TransformNow" default="uml2mp" basedir=".">
<property name="atl.launcher" value="EMF-specific VM"/>
<target name="uml2mp">
<atl.loadModel name="UML" metamodel="MOF" nsURI="http://www.eclipse.org/uml2/2.1.0/UML" />
<atl.loadModel name="MP" metamodel="MOF" path=C:/ATLPROJECT/Mp.ecore" />
<atl.loadModel name="myUML" metamodel="UML" path="C:/ATLPROJECT/myUMLModel.uml" />
<atl.loadModel name="myProfile" metamodel="UML" path="C:/ATLPROJECT/ECIM_Base_Profile.profile.uml" />
<atl.launch path="C:/ATLPROJECT/ECIMtoMP.asm">
<option name="allowInterModelReferences" value="true"/>
<option name="profile" value="true"/>
<option name="supportUML2Stereotypes" value="true"/>
<inmodel name="INPROFILE" model="myProfile"/>
<inmodel name="IN" model="myUML"/>
<outmodel name="OUT" model="myMP" metamodel="MP"/>
<library name="HelperFunctions" path="C:/ATLPROJECT/HelperFunctions.asm" />
</atl.launch >
</target>
</project>
And the error message:
BUILD FAILED
C:\ATLPROJECT\run.xml:9: Operation not found: IN!Package1:UML!Package.getValue(org.eclipse.m2m.atl.engine. emfvm.lib.OclUndefined,java.lang.String)
Total time: 2 seconds
Looking through the code for the ant task, it is more or less doing the model loading, and launching the transformation in the same way I am trying to do.
And here somebody else is experiencing the same issue, http://www.eclipse.org/forums/index.php?t=msg&&th=15 3944&goto=495233#msg_495233
[Updated on: Thu, 18 February 2010 08:05] by Moderator
Re: [ATL] Problem trying to transform uml programmatically [message #520245 is a reply to message #515379] |
Thu, 11 March 2010 11:50  |
Ok, I thought everything was fine unti I started to retrieve the modules and libraries from bundles instead of from workspace. I do not get any error messages, but the transformation is not done correctly. It seems that the asm files have to be in the workspace to work properly.
I have tried these two approaches and neither works:
libraries.put("HelperFunctions", (new FileInputStream("C:\\Users\\qmahsha\\IBM\\rationalsdp\\workspace\\M2M\\ATL\\HelperFunctions.asm")));
libraries.put("HelperFunctions", bundleM2M.getEntry("/ATL/HelperFunctions.asm").openStream());
However, in the first example, if I change the workspace dir to the current running worskpace, it will work. But if the file is retrieved outside workspace, it will not work.
Ohh I see that the problem exists for the provided run configuration ATL Transformation launcher aswell. It is not possible to set the library file to something which is not in the workspace.
When I try to load from a bundle, I get this error when transforming:
org.eclipse.m2m.atl.engine.emfvm.VMException: Operation not found: thisModule.isReadOnly(org.eclipse.uml2.uml.internal.impl.Cla ssImpl,java.lang.String)
at __applyEcimMoClassToClassType(MOClassMappingRules.atl[131:15 -131:50])
local variables: self=thisModule, link=org.eclipse.m2m.atl.engine.emfvm.lib.TransientLink@52405240, s=IN!Class1:UML!Class, t=OUT!<unnamed>:MP!ClassType, stereotype='ECIM Base Profile::EcimMoClass', visibleSet=Set {'<unknown>!EXPERIMENTAL:UML!EnumerationLiteral', '<unknown>!CURRENT:UML!EnumerationLiteral', '<unknown>!DEPRECATED:UML!EnumerationLiteral'}
local variables:
[Updated on: Fri, 12 March 2010 06:29] by Moderator
Current Time: Fri Jul 18 11:57:44 EDT 2025
Powered by FUDForum. Page generated in 0.04782 seconds
