Home » Eclipse Projects » EGit / JGit » Jgit checkout/commit example.
Jgit checkout/commit example. [message #514720] Tue, 16 February 2010 08:19 Go to next message
Is there an example of how to commit a file and checkout a revision of a file using jgit anywhere?
Re: Jgit checkout/commit example. [message #515015 is a reply to message #514720] Wed, 17 February 2010 08:56 Go to previous messageGo to next message
I managed to checkout a file. Now I have to figure out how to commit a file.
This is the code I used for checkout. It's just a test and probably not the best way of doing it...
repo = new Repository(new File(gitFolder()));
public void checkout(String file, String toDir) throws IOException {
	RevWalk rw = new RevWalk(repo);
	ObjectId objHead = repo.resolve("HEAD");
        RevCommit commitHead = rw.parseCommit(objHead);
        Tree tree = repo.mapTree(commitHead.getTree());
        TreeEntry fileTreeEntry = getFile(file.split("/"), 0, tree);
        ObjectLoader loader = repo.openBlob(fileTreeEntry.getId());
        // Write content
        byte[] bytes = loader.getBytes();
        File outFile = new File(toDir + "/" + fileTreeEntry.getName());
        FileChannel channel = new FileOutputStream(outFile).getChannel();
	ByteBuffer buffer = ByteBuffer.wrap(bytes);
	channel.write(buffer);
	channel.close();
private TreeEntry getFile(String[] path, int pathPos, Tree tree) throws IOException {
	if (path.length == 0 && pathPos > path.length) { return null; }
	boolean isFile = path.length == pathPos + 1;
	for(TreeEntry entry : tree.members()) {
		if (path[pathPos].equals(entry.getName())) {
			if (isFile) {
				return entry;
			} else {
				return getFile(path, ++pathPos, repo.mapTree(entry.getId()));
	return null;
Re: Jgit checkout/commit example. [message #515312 is a reply to message #515015] Thu, 18 February 2010 08:19 Go to previous messageGo to next message
I managed to commit a file using this code.
(With help from : https://kerneltrap.org/mailarchive/git/2009/2/4/4899784/thre ad )
public void commit(String file, PersonIdent person, String commitMessage) throws IOException {
		// Example source: https://kerneltrap.org/mailarchive/git/2009/2/4/4899784/thread
		Ref oldHEAD = repo.getAllRefs().get(Constants.HEAD);
		GitIndex index = new GitIndex(repo);
		index.add(new File(workingDirectory), new File(workingDirectory + "/" + file));
		index.write();
		ObjectId objectId = index.writeTree();
		Tree tree = repo.mapTree(objectId);
		final Commit commit = new Commit(repo);
		commit.setAuthor(person);
		commit.setCommitter(person);
		commit.setMessage(commitMessage);
		commit.setTree(tree);
		commit.setParentIds(new ObjectId[] { oldHEAD.getObjectId() });
		commit.commit();
		ObjectWriter writer = new ObjectWriter(repo);
		commit.setCommitId(writer.writeCommit(commit));
		final RefUpdate ru = repo.updateRef(Constants.HEAD);
		ru.setNewObjectId(commit.getCommitId());
		ru.setRefLogMessage(commitMessage, false);
		if (oldHEAD != null) {
			// commit has parents
			ru.setExpectedOldObjectId(oldHEAD.getObjectId());
		} else {
			// commit has no parents
		ru.update();
Re: Jgit checkout/commit example. [message #536531 is a reply to message #515312] Fri, 28 May 2010 11:14 Go to previous messageGo to next message
Thanks a lot for posting this. It's really hard to find any examples of JGit code!
Re: Jgit checkout/commit example. [message #541353 is a reply to message #514720] Sun, 20 June 2010 08:04 Go to previous messageGo to next message
Thanks a lot for the code... I needed some version control system based on java for a cms project. I have modified this source a little bit, but I'm not sure, if I got it the right way. I needed the whole path to be created when checking out so the part:
became:
File outFile = new File(toDir + "/" + file);
outFile.getParentFile().mkdirs();
Also I needed to the ability to check out a specific revision (not only the last one), so I made up the following:
	public void checkout(final String file, final String toDir, final Integer commitTime) throws IOException {
		Repository repo = new Repository(this.frepo);
		rw.markStart(rw.parseCommit(objHead));
		rw.setTreeFilter(AndTreeFilter.create(PathFilter.create(file), TreeFilter.ANY_DIFF));
		for (RevCommit c : rw) {
			if (c.getCommitTime() == commitTime) {
				Tree tree = repo.mapTree(c.getTree());
				TreeEntry fileTreeEntry = this.getFile(file.split("/"), 0, tree, repo);
				// Write content
				channel.close();
Is there a better way to do it? And another question, eclipse marks GitIndex as deprecated. What else should be used instead?
Thanks in advance!
Anthyon
Re: Jgit checkout/commit example. [message #638651 is a reply to message #541353] Thu, 11 November 2010 19:09 Go to previous message
This will aid you well:
http://wiki.eclipse.org/JGit/User_Guide#API
There are good example codes in the so called Porcelain API implementation (eg. CommitCommand)
Previous Topic:Problem installing eGit (0.7.1) on Windows Eclipse 3.5
Next Topic:ExtensionPoint for CommitDialog?
Current Time: Sun Jul 27 13:58:34 EDT 2025
Powered by FUDForum. Page generated in 1.04145 seconds
