Home » Eclipse Projects » Rich Client Platform (RCP) » Enable "Save As" command
Enable "Save As" command [message #515203] Thu, 18 February 2010 02:12 Go to next message
I have added a 'SAVE AS" command in my RCP application using
'org.eclipse.ui.file.saveAs'. I can see this as a menu item in my app, but
its always disabled. I have implemented the 'isSaveAsAllowed' method to
return true in my editor, but still the 'save as' command is not enabled.
Any ideas on what is going wrong? Am I missing something here?
Thanks and Regards
Mustufa Kasidwala
Re: Enable "Save As" command [message #515213 is a reply to message #515203] Thu, 18 February 2010 03:25 Go to previous message
On 18/02/10 12:42 PM, Mustufa Kasidwala wrote:
Did you register the save as action in your ActionBarAdvisor?
- Prakash
Platform UI Team, IBM
www.eclipse-tips.com
Re: Enable "Save As" command [message #515215 is a reply to message #515213] Wed, 17 February 2010 22:44 Go to previous message
Ah...
No I didn't...I just added it and tried, it worked properly now. Thanks.
But why do we need to do this? when I have already added the command in
plugin.xml, why is it required to register it as an action?
Thanks and Regards
Mustufa Kasidwala
"Prakash G.R." <grprakash@gmail.com> wrote in message
news:hlitil$hkp$1@build.eclipse.org...
>> Hi,
>> but
> - Prakash
Re: Enable "Save As" command [message #515224 is a reply to message #515215] Wed, 17 February 2010 23:10 Go to previous message
On 18/02/10 2:07 PM, Mustufa Kasidwala wrote:
> Ah...
https://bugs.eclipse.org/bugs/show_bug.cgi?id=270007
- Prakash
Previous Topic:Build Eclipse RCP Application using Apache Ant scripts?
Next Topic:How to register a context menu for a MultipageEditorPart?
Current Time: Wed Jul 23 11:26:14 EDT 2025
Powered by FUDForum. Page generated in 0.35974 seconds
