Home » Archived » Buckminster » RMap redirect breaks searchPath overlap
RMap redirect breaks searchPath overlap [message #515049] Wed, 17 February 2010 10:02 Go to next message
following construct:
A.rmap
<searchPath name="org.eclipse.ecf.osu">
</searchPath>
<locator
searchPathRef="org.eclipse.ecf.osu"
pattern="^org\.eclipse\.ecf(\..+)?" />
<redirect href="http://path/to/B.rmap
pattern=".*" />
B.rmap
<searchPath name="org.eclipse.ecf">
</searchPath>
<locator
searchPathRef="org.eclipse.ecf"
Unless I limit the scope of the first searchPathRef to exactly what is
supposed to be found in A, B is not called.
Bug?
Markus
Re: RMap redirect breaks searchPath overlap [message #515080 is a reply to message #515049] Wed, 17 February 2010 11:34 Go to previous messageGo to next message
Hi Markus!
If you don't have a pattern the locator will match everything.
The default behavior is to fail if it doesn't find anything.
By adding the pattern you only go there if you know it's supposed to find it there.
Alternatively you can add a failOnError="false" to the locator, then it will continue to your redirect if it doesn't find what it's looking for.
/John
Re: RMap redirect breaks searchPath overlap [message #515088 is a reply to message #515049] Wed, 17 February 2010 11:47 Go to previous messageGo to next message
A locator hit is finite unless you specify failOnError='false'.
Thomas Hallgren
Re: RMap redirect breaks searchPath overlap [message #515143 is a reply to message #515088] Wed, 17 February 2010 15:52 Go to previous messageGo to next message
Sorry, what I meant was that I expect Bucky to try the locator in A
first and if it does not produce a match try locator B instead. However
Bucky appears to try A, fails to produce a match an never tries B.
Markus
Re: RMap redirect breaks searchPath overlap [message #515157 is a reply to message #515143] Wed, 17 February 2010 12:12 Go to previous messageGo to next message
That's what I meant. Buckminster chooses a SearchPath based on a locator. If that SearchPath fails to produce a match,
the whole resolution fails. That's the intended behavior. You can change this behavior and tell Buckminster to continue
with the next matching locator by setting failOnError="false" on the locator that led to failure.
- thomas
Re: RMap redirect breaks searchPath overlap [message #515243 is a reply to message #515157] Thu, 18 February 2010 04:33 Go to previous message
> locator. If that SearchPath fails to produce a match, the whole
> behavior and tell Buckminster to continue with the next matching locator
Thanks, I guess I got lost in translation. :-o
Markus
Previous Topic:generator.lastRevision.format question
Next Topic:Get Maven component from SVN
Current Time: Thu Jul 31 03:27:51 EDT 2025
Powered by FUDForum. Page generated in 0.08889 seconds
