Home » Eclipse Projects » EclipseLink » NullPointerException on @VariableOneToOne(Getting NullPointerException on @VariableOneToOne annotation)
NullPointerException on @VariableOneToOne [message #514209] Fri, 12 February 2010 15:25 Go to next message
Using EclipseLink 2.0.0 with postgres. Running as a java app inside eclipse.
In a mapped entity I have a reference to interface. I tried mapping using the @VariableOneToOne annotation, but I get an exception when eclipseLink is processing that mapping. I also use the @JoinColumn annotation on this reference.
Here is my original code:
@VariableOneToOne(
discriminatorColumn=@DiscriminatorColumn(
name="resourceClass",
discriminatorType=DiscriminatorType.INTEGER
discriminatorClasses={
@DiscriminatorClass(discriminator="3", value=Role.class)
@JoinColumn(name="resourceId")
private RoleResource resource;
If I remove the @VariableOneToOne annotation, eclipseLink defaults a VariableOneToOne mapping for me. If I use the @VariableOneToOne annotation, even without any arguments, I get this exception:
Exception in thread "main" Local Exception Stack:
Exception [EclipseLink-30005] (Eclipse Persistence Services - 2.0.0.v20091127-r5931): org.eclipse.persistence.exceptions.PersistenceUnitLoadingExc eption
Exception Description: An exception was thrown while searching for persistence archives with ClassLoader: sun.misc.Launcher$AppClassLoader@11b86e7
Internal Exception: javax.persistence.PersistenceException: Exception [EclipseLink-28018] (Eclipse Persistence Services - 2.0.0.v20091127-r5931): org.eclipse.persistence.exceptions.EntityManagerSetupExcepti on
Exception Description: Predeployment of PersistenceUnit [bardDomain] failed.
Internal Exception: java.lang.NullPointerException
at org.eclipse.persistence.exceptions.PersistenceUnitLoadingExc eption.exceptionSearchingForPersistenceResources(Persistence UnitLoadingException.java:126)
at org.eclipse.persistence.jpa.PersistenceProvider.createEntity ManagerFactory(PersistenceProvider.java:133)
at org.eclipse.persistence.jpa.PersistenceProvider.createEntity ManagerFactory(PersistenceProvider.java:65)
at javax.persistence.Persistence.createEntityManagerFactory(Per sistence.java:78)
at javax.persistence.Persistence.createEntityManagerFactory(Per sistence.java:54)
at com.netapp.dfm.server.db.DomainEntityTest.buildSessionFactor y(DomainEntityTest.java:44)
at com.netapp.dfm.server.db.DomainEntityTest.getSessionFactory( DomainEntityTest.java:38)
at com.netapp.dfm.server.db.DomainEntityTest.getSession(DomainE ntityTest.java:33)
at com.netapp.dfm.server.db.DomainEntityTest.runTest(DomainEnti tyTest.java:25)
at com.netapp.dfm.server.db.DomainEntityTest.main(DomainEntityT est.java:21)
Caused by: javax.persistence.PersistenceException: Exception [EclipseLink-28018] (Eclipse Persistence Services - 2.0.0.v20091127-r5931): org.eclipse.persistence.exceptions.EntityManagerSetupExcepti on
at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl. predeploy(EntityManagerSetupImpl.java:986)
at org.eclipse.persistence.internal.jpa.deployment.JPAInitializ er.callPredeploy(JPAInitializer.java:88)
at org.eclipse.persistence.jpa.PersistenceProvider.createEntity ManagerFactory(PersistenceProvider.java:124)
... 8 more
Caused by: Exception [EclipseLink-28018] (Eclipse Persistence Services - 2.0.0.v20091127-r5931): org.eclipse.persistence.exceptions.EntityManagerSetupExcepti on
at org.eclipse.persistence.exceptions.EntityManagerSetupExcepti on.predeployFailed(EntityManagerSetupException.java:210)
... 11 more
at org.eclipse.persistence.internal.jpa.metadata.accessors.mapp ings.ObjectAccessor.getReferenceClass(ObjectAccessor.java:19 1)
at org.eclipse.persistence.internal.jpa.metadata.accessors.clas ses.ClassAccessor.addAccessor(ClassAccessor.java:200)
at org.eclipse.persistence.internal.jpa.metadata.accessors.clas ses.ClassAccessor.addAccessorFields(ClassAccessor.java:349)
at org.eclipse.persistence.internal.jpa.metadata.accessors.clas ses.ClassAccessor.addAccessors(ClassAccessor.java:322)
at org.eclipse.persistence.internal.jpa.metadata.accessors.clas ses.EntityAccessor.preProcess(EntityAccessor.java:657)
at org.eclipse.persistence.internal.jpa.metadata.accessors.clas ses.EntityAccessor.preProcess(EntityAccessor.java:593)
at org.eclipse.persistence.internal.jpa.metadata.MetadataProjec t.processStage1(MetadataProject.java:1296)
at org.eclipse.persistence.internal.jpa.metadata.MetadataProces sor.processORMMetadata(MetadataProcessor.java:460)
at org.eclipse.persistence.internal.jpa.deployment.PersistenceU nitProcessor.processORMetadata(PersistenceUnitProcessor.java :390)
at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl. predeploy(EntityManagerSetupImpl.java:940)
... 10 more
Thanks for any help.
Greg
Re: NullPointerException on @VariableOneToOne [message #515139 is a reply to message #514209] Wed, 17 February 2010 15:56 Go to previous messageGo to next message
Hello Greg,
When defining the @VariableOneToOne annotation, it looks like you need to also set the targetInterface ie;
@VariableOneToOne(
targetInterface=RoleResource.class
Please feel free to file a bug to get a better error message (or even to have the default be used instead).
Best Regards,
Chris
Re: NullPointerException on @VariableOneToOne [message #515316 is a reply to message #515139] Thu, 18 February 2010 08:33 Go to previous messageGo to next message
Thanks Chris. You were correct. Adding the specification of "targetInterface" resolved the NullPointerException. I also agree with your suggestion that the default interface type should be used if not specified, or at least issue a more helpful message.
Now that the NullPointerException is resolved, I hit a second issue. I created the class discriminator column as a numeric type:
resourceClass INTEGER,
and specified as such in the @VariableOneToOne:
but am syntactically forced to specify the actual discriminator values as Strings, like this:
Specifically, when I try this:
@DiscriminatorClass(discriminator=3, value=Role.class)
I get a compile error "Type mismatch: cannot convert from int to String"
and so eclipseLink actually uses a string value in the SQL insert statement, causing an error:
Call: INSERT IGNORE INTO ROLECAPABILITY (ID, ENTITYVERSION, operationId, ownerId, resourceId, resourceClass) VALUES (?, ?, ?, ?, ?, ?)
bind => [8, 1, 6, 7, 7, 3]
Internal Exception: org.postgresql.util.PSQLException: ERROR: column "resourceclass" is of type integer but expression is of type character varying
Is DiscriminatorType.INTEGER not supported by eclipseLink?
Greg
Re: NullPointerException on @VariableOneToOne [message #515697 is a reply to message #515316] Fri, 19 February 2010 14:47 Go to previous messageGo to next message
Please file a bug for this issue and vote for it. The only workaround I can think of is to map this using EclipseLink native code in a customizer. you could adapt the patch from 261368 (which is closely related) and apply it to the DiscriminatorClassMetadata.process method where it seems to be adding in the string discriminator instead of converting it if neccessary.
Best Regards,
Chris
Re: NullPointerException on @VariableOneToOne [message #515701 is a reply to message #515697] Fri, 19 February 2010 14:57 Go to previous message
Chris,
Thanks for the specific suggestions. You have been very helpful. I will create a couple of bugs for these issues. Not sure yet how I will work around the issue. Maybe I just use a string discriminator column.
Greg
Previous Topic:eclipselink dynamic weaving not working from remote computer
Next Topic:Problem with deleting an object with a many-to-many mapping
Current Time: Sat Jul 26 10:40:53 EDT 2025
Powered by FUDForum. Page generated in 0.24063 seconds
