Home » Modeling » Epsilon » [EUGENIA] Questions about examples.friends
[EUGENIA] Questions about examples.friends [message #514719] |
Tue, 16 February 2010 08:03  |
Hi Dimitris,
I have a problem with the friends example. I am using the pre-packaged
Eclipse Galileo Modeling distribution.
I downloaded the two zip archive(s) of friends example (friends and
friends.figure) from this page:
http://eclipse.org/gmt/epsilon/examples/index.php?example=or g.eclipse.epsilon.eugenia.examples.friends
After importing them on Eclipse, I generated ALL and generated Diagram
Code.
My first problem was that the generated friends.diagram project had
errors because it did not find the figures package. I solved it adding
the friends.figure project to the friends.diagram Java build path.
Afther that, I run other Eclipse instance. When I create a new friends
diagram, the editor opens but it does not allow to draw a person,
however it presents a pop-up with this error:
An error has occurred. See error log for more details.
figures/PersonFigure
I imagine that I forgot any step of the process... moreover I do not
know whether the code generator uses the mirrored.gmfgraph file
in.figure/models folder. What is the aim of that file ?
Thank you in advance.
Joaquín
Re: [EUGENIA] Questions about examples.friends [message #514727 is a reply to message #514719] |
Tue, 16 February 2010 08:20   |
Hi Joaquin,
Could you please try deleting the .gmfgen model and re-generating it? Re
the mirrored.gmfgraph, you can ignore it.
Please let me know if re-generating the .gmfgen fixes the problem. If
not, I'll have a closer look at this.
Dimitris
Joaquín Cañadas wrote:
> Hi Dimitris,
> Code.
> Joaquín
Spread the word: http://www.eclipse.org/gmt/epsilon/spreadtheword
Follow Epsilon on Twitter: http://twitter.com/epsilonews
Re: [EUGENIA] Questions about examples.friends [message #514980 is a reply to message #514727] |
Wed, 17 February 2010 06:49   |
Hi Dimitris,
I tryed deleting the .gmfgen model and re-generating it, but the problem
is not solved.
I also tryed deleting the .genmodel too, and regenerating all again, but
nothing.
The other example , flowchart, works fine. However, I am testing the
friends example because of the use of images.
Joaquín
Dimitris Kolovos escribió:
> Hi Joaquin,
> Re the mirrored.gmfgraph, you can ignore it.
> Cheers,
> Dimitris
>> Hi Dimitris,
>> pre-packaged Eclipse Galileo Modeling distribution.
>> Diagram Code.
>> adding the friends.figure project to the friends.diagram Java build
>> path.
>> friends diagram, the editor opens but it does not allow to draw a
>> person, however it presents a pop-up with this error:
>> Joaquín
Re: [EUGENIA] Questions about examples.friends [message #515131 is a reply to message #514980] |
Wed, 17 February 2010 15:33   |
Hello again,
I tried downloading the friends example from the SVN repository and it
works fine. But it works only when I also check out the project
generated from the .gmfgen
(org.eclipse.epsilon.eugenia.examples.friends.diagram). I mean, when I
generate the diagram code from the .gmfgen model I have a error in the
generated class friends.diagram.edit.parts.PersonEditPart.java, because
- the import figures cannot be resolved
- PersonFigure cannot be resolved
However, when I check out the diagram project instead of generating it,
the error is not presented. ¿Any suggestion? Adding the friends.figure
project to the friends.diagram Java build path solves the compilation
error, however when the new Eclipse instance is launched and the editor
is used, an error fires because it cannot find the figures/PersonFigure
Joaquín
(I am using java1.6)
Joaquín Cañadas escribió:
> Hi Dimitris,
> problem is not solved.
> but nothing.
> Regards
> Joaquín
>> Hi Joaquin,
>> Cheers,
>> Dimitris
>>> Hi Dimitris,
>>> Diagram Code.
>>> path.
>>> Joaquín
Re: [EUGENIA] Questions about examples.friends [message #515142 is a reply to message #515131] |
Wed, 17 February 2010 16:08   |
Hi Joaquin,
I'm afraid I can't reproduce this - and I must admit I'm running low on
suggestions on how to proceed. Perhaps a screen sharing session via
Yuuguu might help...
Dimitris
> Hello again,
> Joaquín
>> Hi Dimitris,
>> but nothing.
>> Regards
>> Joaquín
>>> Hi Joaquin,
>>> Cheers,
>>> Dimitris
>>>> Hi Dimitris,
>>>> Diagram Code.
>>>> path.
>>>> Joaquín
Re: [EUGENIA] Questions about examples.friends [message #515538 is a reply to message #515142] |
Fri, 19 February 2010 05:08   |
Hi Dimitris,
I fixed the problem. I added the file FixGMFGen.eol to the
examples.friends project, similarly to the FixGMFGen.eol file of the
examples.flowchart project.
I addapted the code of the file FixGMFGen.eol:
var genPlugin = GmfGen!GenPlugin.all.first();
genPlugin.requiredPlugins.add('org.eclipse.epsilon.eugenia.e xamples.friends.figures');
Now, the diagram project does not have any compilation errors, and the
graphical editor works fine.
Joaquín
> Hi Joaquin,
> on suggestions on how to proceed. Perhaps a screen sharing session via
> Cheers,
> Dimitris
>> Hello again,
>> it works fine. But it works only when I also check out the project
>> I generate the diagram code from the .gmfgen model I have a error in
>> the generated class friends.diagram.edit.parts.PersonEditPart.java,
>> because
>> it, the error is not presented. ¿Any suggestion? Adding the
>> friends.figure project to the friends.diagram Java build path solves
>> the compilation error, however when the new Eclipse instance is
>> launched and the editor is used, an error fires because it cannot
>> Joaquín
>>> Hi Dimitris,
>>> but nothing.
>>> Regards
>>> Joaquín
>>>> Hi Joaquin,
>>>> it? Re the mirrored.gmfgraph, you can ignore it.
>>>> If not, I'll have a closer look at this.
>>>> Cheers,
>>>> Dimitris
>>>>> Hi Dimitris,
>>>>> and friends.figure) from this page:
>>>>> Diagram Code.
>>>>> had errors because it did not find the figures package. I solved
>>>>> it adding the friends.figure project to the friends.diagram Java
>>>>> build path.
>>>>> not know whether the code generator uses the mirrored.gmfgraph
>>>>> file in.figure/models folder. What is the aim of that file ?
>>>>> Joaquín
Re: [EUGENIA] Questions about examples.friends [message #515549 is a reply to message #515538] |
Fri, 19 February 2010 05:42  |
Hi Joaquin,
Glad you got this fixed! However, in principle this should have the same
effect as adding the dependency manually - so I'm still not sure why you
were encountering this behaviour in the first place...
Dimitris
> Hi Dimitris, I fixed the problem. I added the file FixGMFGen.eol to
> the examples.friends project, similarly to the FixGMFGen.eol file of
> the examples.flowchart project. I addapted the code of the file
> FixGMFGen.eol:
> the graphical editor works fine. Regards Joaquín
>> Hi Joaquin,
>> low on suggestions on how to proceed. Perhaps a screen sharing
>> session via Yuuguu might help...
>> Cheers, Dimitris
>>> Hello again, I tried downloading the friends example from the SVN
>>> repository and it works fine. But it works only when I also check
>>> out the project generated from the .gmfgen
>>> when I generate the diagram code from the .gmfgen model I have a
>>> error in the generated class
>>> friends.diagram.edit.parts.PersonEditPart.java, because - the
>>> import figures cannot be resolved - PersonFigure cannot be
>>> resolved However, when I check out the diagram project instead of
>>> generating it, the error is not presented. ¿Any suggestion?
>>> Adding the friends.figure project to the friends.diagram Java
>>> build path solves the compilation error, however when the new
>>> Eclipse instance is launched and the editor is used, an error
>>> Joaquín (I am using java1.6)
>>>> Hi Dimitris, I tryed deleting the .gmfgen model and
>>>> re-generating it, but the problem is not solved. I also tryed
>>>> nothing.
>>>> testing the friends example because of the use of images.
>>>> Regards Joaquín
>>>>> Hi Joaquin,
>>>>> re-generating it? Re the mirrored.gmfgraph, you can ignore
>>>>> it.
>>>>> problem. If not, I'll have a closer look at this.
>>>>> Cheers, Dimitris
>>>>>> Hi Dimitris,
>>>>>> pre-packaged Eclipse Galileo Modeling distribution. I
>>>>>> (friends and friends.figure) from this page:
>>>>>> generated Diagram Code. My first problem was that the
>>>>>> generated friends.diagram project had errors because it did
>>>>>> not find the figures package. I solved it adding the
>>>>>> path.
>>>>>> new friends diagram, the editor opens but it does not allow
>>>>>> to draw a person, however it presents a pop-up with this
>>>>>> error: An error has occurred. See error log for more
>>>>>> details. figures/PersonFigure
>>>>>> I do not know whether the code generator uses the
>>>>>> mirrored.gmfgraph file in.figure/models folder. What is the
>>>>>> aim of that file ?
>>>>>> Thank you in advance. Joaquín
Re: [EUGENIA] Questions about examples.friends [message #586334 is a reply to message #514719] |
Hi Joaquin,
Dimitris
> Hi Dimitris,
> Code.
> Joaquín
Re: [EUGENIA] Questions about examples.friends [message #586363 is a reply to message #514727] |
Hi Dimitris,
is not solved.
nothing.
Joaquín
> Hi Joaquin,
> Cheers,
> Dimitris
>> Hi Dimitris,
>> Diagram Code.
>> path.
>> Joaquín
Re: [EUGENIA] Questions about examples.friends [message #586394 is a reply to message #514980] |
Hello again,
Joaquín
> Hi Dimitris,
> but nothing.
> Regards
> Joaquín
>> Hi Joaquin,
>> Cheers,
>> Dimitris
>>> Hi Dimitris,
>>> Diagram Code.
>>> path.
>>> Joaquín
Re: [EUGENIA] Questions about examples.friends [message #586400 is a reply to message #515131] |
Hi Joaquin,
Dimitris
> Hello again,
> Joaquín
>> Hi Dimitris,
>> but nothing.
>> Regards
>> Joaquín
>>> Hi Joaquin,
>>> Cheers,
>>> Dimitris
>>>> Hi Dimitris,
>>>> Diagram Code.
>>>> path.
>>>> Joaquín
Re: [EUGENIA] Questions about examples.friends [message #586453 is a reply to message #515142] |
Hi Dimitris,
Joaquín
> Hi Joaquin,
> Cheers,
> Dimitris
>> Hello again,
>> because
>> Joaquín
>>> Hi Dimitris,
>>> but nothing.
>>> Regards
>>> Joaquín
>>>> Hi Joaquin,
>>>> Cheers,
>>>> Dimitris
>>>>> Hi Dimitris,
>>>>> Diagram Code.
>>>>> build path.
>>>>> Joaquín
Re: [EUGENIA] Questions about examples.friends [message #586461 is a reply to message #515538] |
Hi Joaquin,
Dimitris
> FixGMFGen.eol:
>> Hi Joaquin,
>> Cheers, Dimitris
>>>> nothing.
>>>> Regards Joaquín
>>>>> Hi Joaquin,
>>>>> it.
>>>>> Cheers, Dimitris
>>>>>> Hi Dimitris,
>>>>>> path.
>>>>>> aim of that file ?
Current Time: Sun Jul 20 20:02:05 EDT 2025
Powered by FUDForum. Page generated in 0.06138 seconds
