Home » Modeling » Epsilon » Problem with euGENia
icon9.gif  Problem with euGENia [message #515009] Wed, 17 February 2010 08:46 Go to next message
hi
i'm doing the tutorial of euGENia but when i try to generate mfgraph, gmftool
i get this message : The chosen operation is not currently available.
and when i try to add emf file from wizard
"The selected wizard could not be started.
Plug-in org.eclipse.epsilon.util.emf was unable to load class org.eclipse.epsilon.util.emf.NewEmfModelWizard.
Bad version number in .class file"
Re: Problem with euGENia [message #515018 is a reply to message #515009] Wed, 17 February 2010 08:47 Go to previous messageGo to next message
Hi Zied,
Which version of Java are you using? If you're not using 1.6 I'd suggest
upgrading and giving this another go.
Dimitris
Zied wrote:
> hi
> gmftool
> and when i try to add emf file from wizard i get this message :
Spread the word: http://www.eclipse.org/gmt/epsilon/spreadtheword
Follow Epsilon on Twitter: http://twitter.com/epsilonews
Re: Problem with euGENia [message #515033 is a reply to message #515018] Wed, 17 February 2010 09:27 Go to previous messageGo to next message
hi Dimitrios,
i'm using java 5 i will try to upgrade
thanks Smile
Re: Problem with euGENia [message #515219 is a reply to message #515033] Thu, 18 February 2010 03:50 Go to previous messageGo to next message
hi Dimitrios,
thanks again
euGENia works perfectly with java 6 Smile
now I have completed the tutorial of flowchart.
Re: Problem with euGENia [message #515231 is a reply to message #515219] Thu, 18 February 2010 04:18 Go to previous message
Great!
Dimitris
Zied wrote:
> hi Dimitrios,
> thanks again euGENia works perfectly with java 6 :) now I have
Re: Problem with euGENia [message #586377 is a reply to message #515009] Wed, 17 February 2010 08:47 Go to previous message
Hi Zied,
Dimitris
Zied wrote:
> hi
> gmftool
Re: Problem with euGENia [message #586389 is a reply to message #515018] Wed, 17 February 2010 09:27 Go to previous message
hi Dimitrios,
Re: Problem with euGENia [message #586409 is a reply to message #586389] Thu, 18 February 2010 03:50 Go to previous message
hi Dimitrios,
thanks again
Re: Problem with euGENia [message #586417 is a reply to message #586409] Thu, 18 February 2010 04:18 Go to previous message
Great!
Dimitris
Zied wrote:
> hi Dimitrios,
Previous Topic:Problem with euGENia
Next Topic:Is it possible customize EMF Tree Editor programmatically ?
Current Time: Sun Jul 27 01:47:23 EDT 2025
Powered by FUDForum. Page generated in 0.09418 seconds
