[EMF Compare] OPTION_DISTINCT_METAMODELS XML files [message #514775] |
Tue, 16 February 2010 10:35  |
Originally posted by: mugbi83.googlemail.com
I have an other question concerning EMF Compare and the option
"OPTION_DISTINCT_METAMODELS"
I am trying to compare two XML models (in a standalone version) that
look like this
<modrep:SchoolType xmlns:modrep="http://qe.informatik.uibk.ac.a/modrep">
<student name="Franz"/>
<student name="Otto"/>
<teacher name="Ludwig" teaches="Franz" Age="45.2" name2="Peter"/>
<teacher name="Ruth" teaches="Franz Otto" Age="35.1" name2="Gruber"/>
</modrep:SchoolType>
compared with
<teacher name="Ludwig" teaches="Franz" Age="45.2"/>
<teacher name="Ruth" teaches="Franz Otto" Age="35.1"/>
Both models have different Ecore metamodels which are used to load them
into EObjects (name2 attribute added).
Since the metamodels are different I used the option
"OPTION_DISTINCT_METAMODELS". Without that option it actually works but
EMF Compare claims that the teachers were removed (the ones with name2)
and the ones without name2 were added. It does not recognize that just
an attribute changed ( was added).
When I used the option for distinct metamodels I just get an error that
name2 is no feature(The feature name2 does not exist in TeacherType.)
thrown by the function "checkForDiffs(current, match);".
Did I misunderstand the idea of the distinct metamodel option? Does
somebody have a hint on how to solve that problem?
Thank you very much
Philipp
Re: [EMF Compare] OPTION_DISTINCT_METAMODELS XML files [message #514987 is a reply to message #514934] |
Wed, 17 February 2010 07:16  |
hi
Thank you very much for your response.
Here is my bug report:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=303052
I hope that it contains all the important information.
regards
Philipp
Am 2010-02-17 10:10, schrieb Laurent Goubet:
> Hi Philip,
> The "distinct metamodels" option was first intended to be used to avoid
> strict equality tests on the compared elements' metaclasses. We still
> compare these elements content though, and that means comparing A.name2
> to B.name2 ... In your case, there is no such thing as B.name2, thus the
> failure.
> This is not in our roadmap for Helios, could you raise a bug to track
> this issue so we might see if we wish this included it in a future release?
> Laurent Goubet
> Obeo
Re: [EMF Compare] OPTION_DISTINCT_METAMODELS XML files [message #622167 is a reply to message #514775] |
Wed, 17 February 2010 04:10  |
--------------090802040107050700070401
Hi Philip,
failure.
Laurent Goubet
Obeo
Philipp Kalb wrote:
> Hi
> look like this
> compared with
> Thank you very much
> Philipp
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
begin:vcard
fn:Laurent Goubet
n:Goubet;Laurent
org:<a href="http://www.obeo.fr">Obeo</a>
email;internet:laurent.goubet@obeo.fr
url:http://www.obeo.fr
version:2.1
end:vcard
--------------090802040107050700070401--
Re: [EMF Compare] OPTION_DISTINCT_METAMODELS XML files [message #622168 is a reply to message #514934] |
hi
regards
Philipp
> Hi Philip,
> failure.
> Laurent Goubet
> Obeo
FUDForum. Page generated in 0.03953 seconds
