TableViewer and RGB [message #514959] |
Wed, 17 February 2010 05:43  |
how can I show in a TableViewer RGB Color like in the ColorCellEditor? The Viewer shows only the String, but I want to show the Color. How can i do this?
import org.eclipse.jface.layout.TableColumnLayout;
import org.eclipse.jface.viewers.ArrayContentProvider;
import org.eclipse.jface.viewers.CellEditor;
import org.eclipse.jface.viewers.CellLabelProvider;
import org.eclipse.jface.viewers.ColorCellEditor;
import org.eclipse.jface.viewers.ColumnWeightData;
import org.eclipse.jface.viewers.EditingSupport;
import org.eclipse.jface.viewers.ICellModifier;
import org.eclipse.jface.viewers.ILabelProvider;
import org.eclipse.jface.viewers.ILabelProviderListener;
import org.eclipse.jface.viewers.IStructuredContentProvider;
import org.eclipse.jface.viewers.LabelProvider;
import org.eclipse.jface.viewers.TableViewer;
import org.eclipse.jface.viewers.TableViewerColumn;
import org.eclipse.jface.viewers.TextCellEditor;
import org.eclipse.jface.viewers.Viewer;
import org.eclipse.jface.viewers.ViewerCell;
import org.eclipse.swt.SWT;
import org.eclipse.swt.graphics.Image;
import org.eclipse.swt.graphics.RGB;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Event;
import org.eclipse.swt.widgets.Listener;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.TableColumn;
import org.eclipse.swt.widgets.TableItem;
import snippet.TestEditor.Kunde;
import snippet.TestEditor.MyCellEditingSupport;
import snippet.TestEditor.MyCellLabelProvider;
public class Snippet007FullSelection {
public static class MyModel {
private RGB rgb;
public MyModel(RGB rgb) {
this.setRgb(rgb);
public void setRgb(RGB rgb) {
this.rgb = rgb;
public RGB getRgb() {
return rgb;
public Snippet007FullSelection(Shell shell) {
Composite tableComposite = new Composite(shell, SWT.NONE);
TableColumnLayout tableColumnLayout = new TableColumnLayout();
tableComposite.setLayout(tableColumnLayout);
final TableViewer v = new TableViewer(tableComposite,SWT.BORDER | SWT.SINGLE);
final TableViewerColumn viewerNameColumn = new TableViewerColumn(
v, SWT.NONE);
viewerNameColumn.getColumn().setText("RGB");
tableColumnLayout.setColumnData(viewerNameColumn.getColumn(),
new ColumnWeightData(100, 10, true));
v.setLabelProvider(new ILabelProvider() {
public void removeListener(ILabelProviderListener listener) {
// TODO Auto-generated method stub
public boolean isLabelProperty(Object element, String property) {
return false;
public void dispose() {
public void addListener(ILabelProviderListener listener) {
public String getText(Object element) {
return ((MyModel)element).getRgb().toString();
public Image getImage(Object element) {
return null;
v.setContentProvider(new ArrayContentProvider());
v.setCellEditors(new CellEditor[] {new ColorCellEditor(v.getTable()) });
v.setColumnProperties(new String[]{"rgb"});
v.setCellModifier(new ICellModifier() {
public void modify(Object element, String property, Object value) {
public Object getValue(Object element, String property) {
return null;
public boolean canModify(Object element, String property) {
return true;
MyModel[] model = createModel();
v.setInput(model);
v.getTable().setLinesVisible(true);
v.getTable().setHeaderVisible(true);
private MyModel[] createModel() {
MyModel[] elements = new MyModel[10];
for( int i = 0; i < 10; i++ ) {
elements[i] = new MyModel(new RGB(0,0, 0));
return elements;
* @param args
Display display = new Display ();
Shell shell = new Shell(display);
shell.setLayout(new FillLayout());
new Snippet007FullSelection(shell);
shell.open ();
while (!shell.isDisposed ()) {
if (!display.readAndDispatch ()) display.sleep ();
display.dispose ();
Re: TableViewer and RGB [message #514964 is a reply to message #514959] |
Wed, 17 February 2010 05:48   |
You should not set the LabelProvider on the TableViewer but a
ColumnLabelProvider on the column and overwrite getBackgroundColor()
Please take a look at our snippets http://wiki.eclipse.org/JFaceSnippets
Tom
Am 17.02.10 11:43, schrieb SirWayne:
> Hello,
> i do this?
> import org.eclipse.swt.widgets.Display;
> public class Snippet007FullSelection { public static class MyModel {
> private RGB rgb;
> this.setRgb(rgb);
> this.rgb = rgb;
> return rgb;
> SWT.SINGLE);
> TableViewerColumn(
> v, SWT.NONE);
> tableColumnLayout.setColumnData(viewerNameColumn.getColumn() ,
> @Override
> @Override
> property) {
> return false;
> @Override
> @Override
> @Override
> @Override
> return null;
> @Override
> value) {
> @Override
> return null;
> @Override
> return true;
> v.setInput(model);
> return elements;
> * @param args
> public static void main(String[] args) {
> shell.open ();
> display.dispose ();
FUDForum. Page generated in 0.29104 seconds
