Home » Eclipse Projects » Rich Client Platform (RCP) » Placing label text on left side of check box(Placing label text on left side of check box)
Placing label text on left side of check box [message #514972] Wed, 17 February 2010 06:39 Go to next message
I searched this for a while but couldn't find any solution.
How can I place the label text before the check box?
Biju
Re: Placing label text on left side of check box [message #514977 is a reply to message #514972] Wed, 17 February 2010 02:02 Go to previous messageGo to next message
You'll have to use a Composite with a Label and Button-Widget.
Tom
Am 17.02.10 12:39, schrieb Biju:
> Biju
Re: Placing label text on left side of check box [message #514978 is a reply to message #514972] Wed, 17 February 2010 02:02 Go to previous messageGo to next message
Additionally or' the value SWT.RIGHT_TO_LEFT to the
styles on construction.
HTH & Greetings from Bremen,
Daniel Krügler
Re: Placing label text on left side of check box [message #514979 is a reply to message #514977] Wed, 17 February 2010 02:02 Go to previous messageGo to next message
I agree, that this is the correct portable way.
I sometimes use the SWT.RIGHT_TO_LEFT trick, but
that can be considered as a hack.
- Daniel
Re: Placing label text on left side of check box [message #514999 is a reply to message #514972] Wed, 17 February 2010 08:15 Go to previous message
Thanks for the solution. SWT.RIGHT_TO_LEFT worked.
The problem with label and button is on tab chage the check box selection won't be there.
Biju
Previous Topic:Remove "Software updates" and "Key assist..." actions from help menu
Next Topic:Handler enablement doesn't work unless widow focus changes
Current Time: Thu Jul 31 03:52:41 EDT 2025
Powered by FUDForum. Page generated in 0.08281 seconds
