Home » Eclipse Projects » JFace » TableViewer and RGB
TableViewer and RGB [message #514959] Wed, 17 February 2010 05:43 Go to next message
how can I show in a TableViewer RGB Color like in the ColorCellEditor? The Viewer shows only the String, but I want to show the Color. How can i do this?
import org.eclipse.jface.layout.TableColumnLayout;
import org.eclipse.jface.viewers.ArrayContentProvider;
import org.eclipse.jface.viewers.CellEditor;
import org.eclipse.jface.viewers.CellLabelProvider;
import org.eclipse.jface.viewers.ColorCellEditor;
import org.eclipse.jface.viewers.ColumnWeightData;
import org.eclipse.jface.viewers.EditingSupport;
import org.eclipse.jface.viewers.ICellModifier;
import org.eclipse.jface.viewers.ILabelProvider;
import org.eclipse.jface.viewers.ILabelProviderListener;
import org.eclipse.jface.viewers.IStructuredContentProvider;
import org.eclipse.jface.viewers.LabelProvider;
import org.eclipse.jface.viewers.TableViewer;
import org.eclipse.jface.viewers.TableViewerColumn;
import org.eclipse.jface.viewers.TextCellEditor;
import org.eclipse.jface.viewers.Viewer;
import org.eclipse.jface.viewers.ViewerCell;
import org.eclipse.swt.SWT;
import org.eclipse.swt.graphics.Image;
import org.eclipse.swt.graphics.RGB;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Event;
import org.eclipse.swt.widgets.Listener;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.TableColumn;
import org.eclipse.swt.widgets.TableItem;
import snippet.TestEditor.Kunde;
import snippet.TestEditor.MyCellEditingSupport;
import snippet.TestEditor.MyCellLabelProvider;
public class Snippet007FullSelection {
    public static class MyModel {
        private RGB rgb;
        public MyModel(RGB rgb) {
            this.setRgb(rgb);
        public void setRgb(RGB rgb) {
            this.rgb = rgb;
        public RGB getRgb() {
            return rgb;
    public Snippet007FullSelection(Shell shell) {
        Composite tableComposite = new Composite(shell, SWT.NONE);
        TableColumnLayout tableColumnLayout = new TableColumnLayout();
        tableComposite.setLayout(tableColumnLayout);
        final TableViewer v = new TableViewer(tableComposite,SWT.BORDER | SWT.SINGLE);
        final TableViewerColumn viewerNameColumn = new TableViewerColumn(
                v, SWT.NONE);
        viewerNameColumn.getColumn().setText("RGB");
        tableColumnLayout.setColumnData(viewerNameColumn.getColumn(),
                new ColumnWeightData(100, 10, true));
        v.setLabelProvider(new ILabelProvider() {
            public void removeListener(ILabelProviderListener listener) {
                // TODO Auto-generated method stub
            public boolean isLabelProperty(Object element, String property) {
                return false;
            public void dispose() {
            public void addListener(ILabelProviderListener listener) {
            public String getText(Object element) {
                return ((MyModel)element).getRgb().toString();
            public Image getImage(Object element) {
                return null;
        v.setContentProvider(new ArrayContentProvider());
        v.setCellEditors(new CellEditor[] {new ColorCellEditor(v.getTable()) });
        v.setColumnProperties(new String[]{"rgb"});
        v.setCellModifier(new ICellModifier() {
            public void modify(Object element, String property, Object value) {
            public Object getValue(Object element, String property) {
                return null;
            public boolean canModify(Object element, String property) {
                return true;
        MyModel[] model = createModel();
        v.setInput(model);
        v.getTable().setLinesVisible(true);
        v.getTable().setHeaderVisible(true);
    private MyModel[] createModel() {
        MyModel[] elements = new MyModel[10];
        for( int i = 0; i < 10; i++ ) {
            elements[i] = new MyModel(new RGB(0,0, 0));
        return elements;
     * @param args
        Display display = new Display ();
        Shell shell = new Shell(display);
        shell.setLayout(new FillLayout());
        new Snippet007FullSelection(shell);
        shell.open ();
        while (!shell.isDisposed ()) {
            if (!display.readAndDispatch ()) display.sleep ();
        display.dispose ();
Re: TableViewer and RGB [message #514964 is a reply to message #514959] Wed, 17 February 2010 05:48 Go to previous messageGo to next message
You should not set the LabelProvider on the TableViewer but a
ColumnLabelProvider on the column and overwrite getBackgroundColor()
Please take a look at our snippets http://wiki.eclipse.org/JFaceSnippets
Tom
Am 17.02.10 11:43, schrieb SirWayne:
> Hello,
> i do this?
> import org.eclipse.swt.widgets.Display;
> public class Snippet007FullSelection { public static class MyModel {
> private RGB rgb;
> this.setRgb(rgb);
> this.rgb = rgb;
> return rgb;
> SWT.SINGLE);
> TableViewerColumn(
> v, SWT.NONE);
> tableColumnLayout.setColumnData(viewerNameColumn.getColumn() ,
> @Override
> @Override
> property) {
> return false;
> @Override
> @Override
> @Override
> @Override
> return null;
> @Override
> value) {
> @Override
> return null;
> @Override
> return true;
> v.setInput(model);
> return elements;
> * @param args
> public static void main(String[] args) {
> shell.open ();
> display.dispose ();
Re: TableViewer and RGB [message #514974 is a reply to message #514964] Wed, 17 February 2010 06:43 Go to previous messageGo to next message
thanks for your answer. Which Snippet do you mean?
If i modify my code, it will paint the whole line with cyan. I want only a small Image like in the CellEditor. Do i have to create the image myself?
        viewerNameColumn.setLabelProvider(new ColumnLabelProvider(){
        		return "";
//				return element.toString();
        	public Color getBackground(Object element) {
        		return v.getTable().getDisplay().getSystemColor(SWT.COLOR_CYAN);
How can I show a checkbox e.g in col 2? Is there a Snippet?I only find the Snippet056BooleanCellEditor, but i miss the BooleanCellEditor class.
Re: TableViewer and RGB [message #514976 is a reply to message #514974] Wed, 17 February 2010 06:54 Go to previous messageGo to next message
The CellEditor is also part of the snippet project the best thing is to
checkout project from cvs.
Yes you need to generate the image on the file or use the
OwnerDraw-LabelProvider to put your Table into ownerdraw mode and draw
on the GC.
Tom
Am 17.02.10 12:43, schrieb SirWayne:
> Hello,
> return "";
> @Override
> return
Re: TableViewer and RGB [message #515044 is a reply to message #514976] Wed, 17 February 2010 09:48 Go to previous message
Ah thanks!!! I have the BooleanEditor and my Owner drawer. It works fine. Smile
No iam looking for a example how i can show a checkbox or button in a TableViewerColumn. Is there a own CellProvider?
Previous Topic:Adding a MouseTrackListener to a TreeViewerColumn
Next Topic:Implementing IPartitionTokenScanner With Multi-Line Tokens
Current Time: Sat Jul 26 18:16:07 EDT 2025
Powered by FUDForum. Page generated in 0.04291 seconds
