| What does promote do? [message #514848] |
Tue, 16 February 2010 10:48  |
My build is running fine now, testing, signing, so all great. The next step is promoting. I copied the promoting step
from the cdo build but I don't seem to get it working. It reports can't find component.
org.eclipse.emf.teneo.releng.buckminster. Which is possible as this component is not present in the workspace, but I am
not sure what a good setup is. So I hope that someone can give some more info.
What does this promote (copy.group) do? Does it do anything more than copying the features/plugins?
This is part of the build.xml:
<target name="promote" depends="init.build.properties">
<echo message="Promoting" />
<buckminster command="perform" workspace="${buildRoot}/workspace">
<cmdargs>
<arg value="org.eclipse.emf.teneo.releng.buckminster#promote" />
</cmdargs>
</buckminster>
</target>
then I have this in the cspec:
<cs:public name="promote.site" actor="ant">
<cs:actorProperties>
<cs:property key="buildFileId" value="buckminster.pdetasks"/>
<cs:property key="targets" value="copy.group"/>
</cs:actorProperties>
<cs:prerequisites alias="action.requirements">
<cs:attribute name="site.p2" component="org.eclipse.emf.teneo.site"/>
<cs:attribute name="clear.site" contributor="false"/>
</cs:prerequisites>
<cs:products alias="action.output" base="${teneo.download.area}/updates/${teneo.update.site.type}/ "/>
</cs:public>
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
| Re: What does promote do? [message #514875 is a reply to message #514848] |
Tue, 16 February 2010 18:35   |
Hi Martin,
On 02/16/2010 09:44 PM, Martin Taal wrote:
> step is promoting. I copied the promoting step from the cdo build but I
> component is not present in the workspace, but I am not sure what a good
The Buckminster build uses the releng component as the top component (referenced from the cquery during import). The
cspec of this component contains the topmost actions of the build (i.e. promote) so it's essential that it is brought
into the workspace..
No, that's exactly what it does. It copies the update site (the prerequisite) to its final location. Unless the
prerequisite exists, it will be built.
HTH,
- thomas
| Re: What does promote do? [message #514909 is a reply to message #514875] |
Wed, 17 February 2010 02:25   |
Hi Thomas,
As it only copies as you say. So this will overwrite the content of the target update site location, i.e. only the last
version of the plugins/features are available?
gr. Martin
Thomas Hallgren wrote:
> Hi Martin,
>> Hi,
> (referenced from the cquery during import). The cspec of this component
> essential that it is brought into the workspace..
> prerequisite) to its final location. Unless the prerequisite exists, it
> will be built.
> HTH,
> - thomas
The Netherlands
| Re: What does promote do? [message #514912 is a reply to message #514909] |
Wed, 17 February 2010 02:52  |
On 02/17/2010 08:25 AM, Martin Taal wrote:
> Hi Thomas,
> target update site location, i.e. only the last version of the
yes.
- thomas
FUDForum. Page generated in 0.03424 seconds
