Home » Eclipse Projects » JFace » Adding a MouseTrackListener to a TreeViewerColumn
Adding a MouseTrackListener to a TreeViewerColumn [message #514911] Wed, 17 February 2010 02:59 Go to next message
at the moment I´m having a problem with a MousTrackListener.
I wrote a Listener which pops up a Tooltip when a special Item is selected.
The GUI Object which should open the Tooltip is a FilteredTree which has some TreeViewerColumns.
I can easily add the listener to the whole Tree with the following Code.
filteredTree.getViewer().getTree().addMouseTrackListener( mouseTrack );
But I would prefer, that the tooltip only opens when my Mouse points over a defined TreeViewerColumn.
How can I add the Listener to the TreeViewerColumn instead of adding it to the whole Tree?
Or is this not possible and I have to add the Listener to the Tree and check the hovered Column when catching the MouseHover Event?
Thanks for your help!
Re: Adding a MouseTrackListener to a TreeViewerColumn [message #514913 is a reply to message #514911] Wed, 17 February 2010 03:06 Go to previous messageGo to next message
You know that ther is ColumnViewerTooltipSupport?
See http://wiki.eclipse.org/JFaceSnippets and
http://tomsondev.bestsolution.at/2009/06/08/galileo-emf-data binding-%E2%80%93-part-3/
for an advanced usage.
Tom
Am 17.02.10 08:59, schrieb TW:
> to the whole Tree?
Re: Adding a MouseTrackListener to a TreeViewerColumn [message #514925 is a reply to message #514913] Wed, 17 February 2010 03:53 Go to previous messageGo to next message
HI,
ok so I can open the tooltip by giving a ColumnViewer Object as input.
But the ColumnViewer is my FilteredTree.
I cannot open the tooltip directly, because I want to display Informations about the object which is hovered by the mouse.
I can get the object at which the mouse is pointing at from the MouseEvent.
So I think this doesn´t fix my problem (If I´m wrong please tell me).
--- UPDATE ---
I recognized, that the person in your second Link uses the CellLabelProvider to Display his tooltip.
I want to display my own tooltip which I extended from the Class ToolTip.
Can you tell me how I can do this?
[Updated on: Wed, 17 February 2010 04:04] by Moderator
Re: Adding a MouseTrackListener to a TreeViewerColumn [message #514958 is a reply to message #514925] Wed, 17 February 2010 00:44 Go to previous messageGo to next message
Yes but it uses the information coming from the ColumnLabelProvider and
displays information for each cell in the table.
Do we talk about the the TableColumn-Header or the Table-Cells?
Tom
Am 17.02.10 09:53, schrieb TW:
> HI,
> I noticed that I do not have to implement a listener to open the tooltip.
> But that doesn´t fix my problem.
> The ColumnViewerTooltipSupport shows a tooltip for ColumnViewer Objects.
> But the ColumnViewer Object is my FilteredTree and not the
> TreeViewerColumn.
> Can anybody help me here?
Re: Adding a MouseTrackListener to a TreeViewerColumn [message #514992 is a reply to message #514911] Wed, 17 February 2010 07:57 Go to previous messageGo to next message
Hi Tom,
we talk about Tree-Cells of a Tree with Columns.
I looked at the links you posted and tried to implement something like this in my application.
First I extended my ColumnLabelProvider and overwrote the getToolTipText() method.
Then I added a ColumnViewerTooltipSupport for the tree (as far as I know, you can only add this support for the whole tree and then the columns which override the getToolTipText() method show their tooltips).
So that worked quite well.
The problem is, that we already have a Tooltip class which extends the java Tooltip class. Here we have methods to easy add lines with images, bold texts or normal texts.
If I could tell my ColumnLabelProvider to open our own Tooltip for the hovered item, the problem would be fixed. But I could not open a Tooltip from the ColumnLabelProvider.
So I found another solution in the second link in one java snipped. They used the same approch then I and implemented a mouseTrackListener.
When there is a mouseHover-Event, there are some queries which check if the mouse pointer is inside the area of a specified column. If true, the Tooltip is created otherwise it is disposed.
Now my Tooltip only pops up in a special column.
Re: Adding a MouseTrackListener to a TreeViewerColumn [message #515001 is a reply to message #514992] Wed, 17 February 2010 08:11 Go to previous message
Simply subclass ColumnViewerTooltip and overwrite
"createViewerToolTipContentArea". If you look at
You see an very advanced version which uses the FormToolKit which is
created in this class:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.emf/org .eclipse.emf/examples/org.eclipse.emf.examples.databinding.p roject.ui.rcp/src/org/eclipse/emf/example/databinding/projec t/ui/rcp/views/ProjectExplorerPart.java?root=Modeling_Projec t&view=markup
Tom
Am 17.02.10 13:57, schrieb TW:
> Hi Tom,
Previous Topic:How to control a TableViewer's size?
Next Topic:TableViewer and RGB
Current Time: Thu Jul 24 00:34:59 EDT 2025
Powered by FUDForum. Page generated in 0.04078 seconds
