| Headless import fails [message #514440] |
Mon, 15 February 2010 06:04  |
I have an RMAP as follows:
<searchPath name="default">
<provider readerType="cvs" componentTypes="osgi.bundle,eclipse.feature,buckminster" source="true" mutable="true">
<uri format=":pserver:gjmcknight:mypass@cvs.local:/opt/data/cvsroot,{0}/"><bc:propertyRef key="buckminster.component" />
</uri>
</provider>
</searchPath>
<locator searchPathRef="default" />
This works using Eclipse ("resolve and materialize"), but with the Headless (I installed the core and CVS features from the 3.5 update site), I get the following error when running the headless "import" command:
Unable to find a searchPath for org.eclipse.core.runtime.compatibility.auth:osgi.bundle
Is there something missing from my headless install?
Do I need to explicitly provide links to these components (i.e components outside of my project (such as org.eclipse, javax.servlet etc)???
Thanks a lot!
Greg
| Re: Headless import fails [message #514462 is a reply to message #514440] |
Mon, 15 February 2010 03:20   |
Hi Greg,
You have not setup a target platform so the build runtime (the headless buckminster in this case) is used as the default
target platform. This is not ideal since whatever your build becomes dependent on the version of your build tool.
I would recommend that you set up an empty target platform in the form of a directory and that you add an entry to your
rmap that uses an 'eclipse.import' reader type that will allow buckminster to resolve target platform components against
a platform p2 repository such as http://download.eclipse.org/eclipse/updates/3.5/
You will also need to use an mspec to tell buckminster that whatever is resolved using this reader type should
materialize to the target platform (as opposed to the workspace). Something like this:
<mspec:mspec xmlns:mspec="http://www.eclipse.org/buckminster/MetaData-1.0" materializer="p2" name="mspec"
url="build.cquery">
<mspec:mspecNode materializer="workspace" namePattern="" filter="(buckminster.source=true)"/>
</mspec:mspec>
assuming that it is stored in the same directory as the 'build.cquery'.
The steps are (in this order).
1. Create an empty target platform. Can be done using buckminster setpref targetPlatformPath=<directory> or using a
target platform descriptor (.target file). Make sure the target is active.
2. Import the mspec using the Buckminster 'import' command.
3. Build.
HTH,
Thomas Hallgren
> mutable="true">
> <uri
> format=":pserver:gjmcknight:mailto:mypass@cvs.local:/opt/data/cvsroot,{0}/"><bc:propertyRef
> </uri>
> </provider>
> </searchPath>
> command:
> etc)???
> Thanks a lot!
> Greg
| Re: Headless import fails [message #514481 is a reply to message #514462] |
Mon, 15 February 2010 09:31   |
Hi Thomas
I have installed the target platform as follows:
C:\fast>..\bin\bmh\buckminster importtargetdefinition -A C:/mysrc/example-app/
example-main-site/rcp.target
Lsttargets gives this:
C:\fast>..\bin\bmh\buckminster lstargets
Using workspace at file:/C:/fast/workspace/ ...
* Eclipse RCP : win32,win32,x86/de_CH
Running Platform : win32,win32,x86/de_CH
All good so far...
I created the MSPEC as you propsed, I only changed the build.cquery to site.query (that is the filename of my CSPEC).
They exist in the same directory.
I added the following to my RMAP:
<searchPath name="galileo">
<provider readerType="eclipse.import" componentTypes="osgi.bundle,eclipse.feature"
mutable="false" source="false">
<uri format=" http://download.eclipse.org/releases/galileo?importType=bina ry"/>
</provider>
</searchPath>
<locator searchPathRef="default" pattern="^calorifer\-.*" />
<locator searchPathRef="galileo" failOnError="false" />
Now I try to import:
C:\fast>..\bin\bmh\buckminster -L DEBUG import C:/mysrc/example-app/example-main-site/site.mspec
But I receive the same errors as before:
Note: I have this in my log file:
!ENTRY org.eclipse.buckminster.core 0 293 2010-02-15 15:15:15.723
!MESSAGE Target platform provided by class org.eclipse.buckminster.pde.internal.PDETargetPlatform
Is the right target platform being used?
Here is my RMAP
<rmap
xmlns="http://www.eclipse.org/buckminster/RMap-1.0"
xmlns:bc="http://www.eclipse.org/buckminster/Common-1.0"
xmlns:mp="http://www.eclipse.org/buckminster/MavenProvider-1.0"
xmlns:pp="http://www.eclipse.org/buckminster/PDEMapProvider-1.0">
<provider
readerType="cvs"
source="true"
mutable="true">
</uri>
</provider>
</searchPath>
</provider>
</searchPath>
</rmap>
Here is my MSPEC:
<mspec:mspec xmlns:mspec="http://www.eclipse.org/buckminster/MetaData-1.0" materializer="p2" name="mspec" url="site.cquery">
</mspec:mspec>
Also, I am interested why can I materialize within eclipse without the MSPEC? Is there a default MSPEC in the eclipse plug-in?
SORRY WORK IN PROGRESS...WILL POST MY PROGRESS IN A LITTLE WHILE
Greg
[Updated on: Mon, 15 February 2010 10:01] by Moderator
| Re: Headless import fails [message #514498 is a reply to message #514481] |
Mon, 15 February 2010 10:15   |
Hi Greg,
Judging from your RMAP you forgot one of the things I suggested:
"add an entry to your rmap that uses an 'eclipse.import' reader type that will allow buckminster to resolve target
platform components against a platform p2 repository such as http://download.eclipse.org/eclipse/updates/3.5/"
Thomas Hallgren
On 02/15/2010 03:31 PM, gjmcknight@schlagundrahm.ch wrote:
> Hi Thomas
> All good so far...
> !ENTRY org.eclipse.buckminster.core 4 293 2010-02-15 15:15:22.228
> !MESSAGE ERROR [0000] : No suitable provider for component
> javax.servlet:osgi.bundle was found in resourceMap
> file:/C:/fast/workspace/calorifer-main-site/site.rmap
> ERROR [0000] : Unable to find a searchPath for javax.servlet:osgi.bundle
> Here is my RMAP
> <rmap
> <provider readerType="cvs" componentTypes="osgi.bundle,eclipse.feature"
> <uri
> </uri>
> </provider>
> </searchPath>
> <locator searchPathRef="default" pattern="^example\-.*" />
> </rmap>
> Here is my MSPEC:
> <mspec:mspec
> </mspec:mspec>
> Any ideas?
> Thanks
> Greg
| Re: Headless import fails [message #514667 is a reply to message #514650] |
Tue, 16 February 2010 04:46   |
OK, here is the log (from workspace/.metadata/.log)
!SESSION 2010-02-16 10:15:37.662 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_17
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_CH
Framework arguments: -L DEBUG import C:/mysrc/example-app/example-main-site/site.mspec
Command-line arguments: -L DEBUG import C:/mysrc/example-app/example-main-site/site.mspec
!ENTRY org.eclipse.buckminster.runtime 0 293 2010-02-16 10:15:39.968
!MESSAGE import 'C:/mysrc/example-app/example-main-site/site.mspec'
!ENTRY org.eclipse.buckminster.core 0 293 2010-02-16 10:15:41.283
!MESSAGE Platform install location: C:\bin\bmh
!ENTRY org.eclipse.buckminster.core 0 293 2010-02-16 10:15:41.760
!ENTRY org.eclipse.buckminster.core 0 293 2010-02-16 10:15:58.064
!MESSAGE Provider cvs(:pserver:gjmcknight:mypass@cvs.local:/opt/data/cvsroot,example-main-site/): materializing to C:/fast/workspace/features/example-main-site/
!ENTRY org.eclipse.buckminster.core 4 293 2010-02-16 10:15:58.248
!MESSAGE ERROR [0004] : Unable to determine target platform install location
!ENTRY org.eclipse.buckminster.runtime 4 0 2010-02-16 10:15:58.251
!MESSAGE Unable to determine target platform install location
!ENTRY org.eclipse.buckminster.core 4 293 2010-02-16 10:15:59.856
!MESSAGE Errors and Warnings
!STACK 1
org.eclipse.core.runtime.CoreException: Errors and Warnings
at org.eclipse.buckminster.runtime.BuckminsterException.wrap(Bu ckminsterException.java:109)
at org.eclipse.buckminster.core.materializer.MaterializationJob .internalRun(MaterializationJob.java:175)
at org.eclipse.buckminster.core.materializer.MaterializationJob .run(MaterializationJob.java:144)
Contains: [0004] : Unable to determine target platform install location
!SUBENTRY 1 org.eclipse.buckminster.core 4 0 2010-02-16 10:15:59.858
!SUBENTRY 2 org.eclipse.buckminster.runtime 4 0 2010-02-16 10:15:59.858
!MESSAGE [0004] : Unable to determine target platform install location
!ENTRY org.eclipse.buckminster.core 1 293 2010-02-16 10:15:59.862
!MESSAGE TAG-ID 0004 = Query for example-main-site:eclipse.feature, path: example-main-site:eclipse.feature$1.0.0.qualifier -> example-main-feature:eclipse.feature$1.0.0.qualifier -> example-main:osgi.bundle$1.0.0.qualifier
!ENTRY org.eclipse.buckminster.core 0 293 2010-02-16 10:16:02.865
!MESSAGE Doing full workspace refresh
!ENTRY org.eclipse.buckminster.core 0 293 2010-02-16 10:16:02.868
!MESSAGE Waiting for jobs to end
As you can see, I have cut the resolution stuff out of the middle of the log.
Here is the active target:
And here is the commands I have run:
C:\fast>..\bin\bmh\buckminster importtargetdefinition -A C:/mysrc/example-app/example-main-site/rcp.target
The workspace directory has two sub-directories, "features" and "plugins" after the import.
FUDForum. Page generated in 0.07222 seconds
