Home » Archived » EPP » Modeling EPP update from 3.5.0 to 3.5.1 - a loop in dependancies?
Modeling EPP update from 3.5.0 to 3.5.1 - a loop in dependancies? [message #514163] Fri, 12 February 2010 11:34 Go to next message
Hi all,
I'm having a bit of a problem updating Eclipse MT from 3.5.0 to 3.5.1. I've followed the forums with all the update site issues over the summer, but I think this is some other issue. When trying to update configuration, 3.5.1 is found in the update site (only main Galileo update is enabled), but won't update:
Cannot complete the install because of a conflicting dependency.
Software being installed: Eclipse Platform SDK 3.5.1.M20090917-0800 (org.eclipse.platform.sdk 3.5.1.M20090917-0800)
Software currently installed: Eclipse Modeling Tools 1.2.0.20090618-1854 (epp.package.modeling 1.2.0.20090618-1854)
Only one of the following can be installed at once:
org.eclipse.platform_root 3.5.0.v20090611a-9gEeG1HFtQcmRThO4O3aR_fqSMvJR2sJ
org.eclipse.platform_root 3.5.1.R35x_v20090910-9gEeG1_FthkNDSP2odXdThaOu9GFDPn83DGB7
Cannot satisfy dependency:
From: Eclipse Modeling Tools 1.2.0.20090618-1854 (epp.package.modeling 1.2.0.20090618-1854)
To: org.eclipse.epp.package.modeling.feature.feature.group [1.2.0.20090618-1854]
From: EPP Modeling Feature 1.2.0.20090618-1854 (org.eclipse.epp.package.modeling.feature.feature.group 1.2.0.20090618-1854)
To: org.eclipse.platform.feature.group [3.5.0.v20090611a-9gEeG1HFtQcmRThO4O3aR_fqSMvJR2sJ]
From: Eclipse Platform 3.5.0.v20090611a-9gEeG1HFtQcmRThO4O3aR_fqSMvJR2sJ (org.eclipse.platform.feature.group 3.5.0.v20090611a-9gEeG1HFtQcmRThO4O3aR_fqSMvJR2sJ)
To: org.eclipse.platform_root [3.5.0.v20090611a-9gEeG1HFtQcmRThO4O3aR_fqSMvJR2sJ]
From: Eclipse Platform 3.5.1.R35x_v20090910-9gEeG1_FthkNDSP2odXdThaOu9GFDPn83DGB7 (org.eclipse.platform.feature.group 3.5.1.R35x_v20090910-9gEeG1_FthkNDSP2odXdThaOu9GFDPn83DGB7)
To: org.eclipse.platform_root [3.5.1.R35x_v20090910-9gEeG1_FthkNDSP2odXdThaOu9GFDPn83DGB7]
From: Eclipse Platform SDK 3.5.1.M20090917-0800 (org.eclipse.platform.sdk 3.5.1.M20090917-0800)
To: org.eclipse.platform.feature.group [3.5.1.R35x_v20090910-9gEeG1_FthkNDSP2odXdThaOu9GFDPn83DGB7]
Seems like a circular dependancy to me (?) Is there a way to update EPP Modeling AND Eclipse Platform at once? If it's some other plugin that is fixed on using exactly 3.5.0 and nothing else, shouldn't it be listed here?
It's a bit annoying, I'm trying to figure this one out for 3 months on and off now, and I really don't want to screw up my platform by brute-force upgrade, I've grown fond of it Wink
M.
Re: Modeling EPP update from 3.5.0 to 3.5.1 - a loop in dependancies? [message #514349 is a reply to message #514163] Sun, 14 February 2010 17:03 Go to previous messageGo to next message
Its not exactly a circular dependency, just that directly, or
indirectly, a couple of features say they need exactly some version of
org.eclipse.platform_root.
I'm not really heard of updating a "package" before (everything in the
package could update, but didn't know the "package" feature itself is
installed. Did you get that from 'unziping' the modeling package? Or did
you start off with platform, then install the modeling package from a repo?
Practically, you might go to Galileo site and "installing" just the
platform update ... then use further passes to install/update other
pieces. If any one piece of it installs, it should be ok, without fear
of breaking the install. (At least, that's supposed to be the
magic/justification for p2!)
HTH
Re: Modeling EPP update from 3.5.0 to 3.5.1 - a loop in dependancies? [message #514421 is a reply to message #514349] Mon, 15 February 2010 04:40 Go to previous messageGo to next message
David Williams wrote on Sun, 14 February 2010 17:03
True, it's easier to solve than to break a circular ref.
It's the official EPP distribution (ZIP) from the site.. I guess if I installed the whole bunch of packages already in the EPP, there wouldn't be a modeling feature installed, which would made things easier.
I was trying that, but I can't find anything resembling the eclipse modeling feature listed under releases/galileo, and P2 doesn't allow me to install Eclipse Core because of this dep.
Best,
M.
Re: Modeling EPP update from 3.5.0 to 3.5.1 - a loop in dependancies? [message #515195 is a reply to message #514421] Wed, 17 February 2010 19:56 Go to previous messageGo to next message
I've tried this scenario, and seems to be working. (I'll admit, its
still running :)
But, going through it, made me think to ask ... I have these two repos
"enabled" ... do you?
EPP Packages Repository
http://download.eclipse.org/technology/epp/packages/galileo
Galileo
http://download.eclipse.org/releases/galileo
These are enabled by default in my fresh install.
Re: Modeling EPP update from 3.5.0 to 3.5.1 - a loop in dependancies? [message #515268 is a reply to message #515195] Thu, 18 February 2010 05:21 Go to previous messageGo to next message
David Williams wrote on Wed, 17 February 2010 19:56
YES! That's it - I somehow didn't have this repository listed at all. It's updating as we speak.
Is it possible to add this repository link somewhere in the EPP pages, I couldn't find it after a quick google look..
Thanks!
M.
Re: Modeling EPP update from 3.5.0 to 3.5.1 - a loop in dependancies? [message #515506 is a reply to message #515268] Thu, 18 February 2010 19:00 Go to previous messageGo to next message
Either that ... or, just make it all one repo?
I've opened the following bug, to track.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=303273
Re: Modeling EPP update from 3.5.0 to 3.5.1 - a loop in dependancies? [message #580090 is a reply to message #514349] Mon, 15 February 2010 04:40 Go to previous messageGo to next message
Best,
M.
Re: Modeling EPP update from 3.5.0 to 3.5.1 - a loop in dependancies? [message #580111 is a reply to message #580090] Thu, 18 February 2010 00:42 Go to previous messageGo to next message
still running :)
Galileo
Re: Modeling EPP update from 3.5.0 to 3.5.1 - a loop in dependancies? [message #580127 is a reply to message #580111] Thu, 18 February 2010 05:21 Go to previous messageGo to next message
Thanks!
M.
Re: Modeling EPP update from 3.5.0 to 3.5.1 - a loop in dependancies? [message #580150 is a reply to message #580127] Thu, 18 February 2010 23:40 Go to previous message
Previous Topic:Modeling EPP update from 3.5.0 to 3.5.1 - a loop in dependancies?
Next Topic:chages in UDC in Helios?
Current Time: Sat Jul 26 17:03:02 EDT 2025
Powered by FUDForum. Page generated in 0.05406 seconds
