Home » Archived » BIRT » Why can I not plot 2 series with different data points ?
Why can I not plot 2 series with different data points ? [message #514199] Fri, 12 February 2010 14:07 Go to next message
I need to plot data for some time series data and super-impose model on the data.
The model has much more points then the original time series (since otherwise it will not look smooth).
How can I plot these 2 series in same plot ?
I failed to see any example in documentation; the plots with 2 series always assume same number of points.
thanks
Re: Why can I not plot 2 series with different data points ? [message #514538 is a reply to message #514199] Mon, 15 February 2010 07:38 Go to previous messageGo to next message
All series must have the same number of points, but using some scripting
you can always put null point values in for the ones you do not have.
If you can generate csv data and post it I can build you an example.
Jason
neerahi wrote:
> Hi
> the data.
> thanks
Re: Why can I not plot 2 series with different data points ? [message #514671 is a reply to message #514538] Tue, 16 February 2010 04:54 Go to previous messageGo to next message
Hi thanks for the reply.
Well I tried filling the other dataset with null values , but then the model fitting was not looking very nice.
What you are saying is that using some sort of event mechanism to cater for missing value will be better option?
I will try to generate CSV and put it on the post.
thanks again
Re: Why can I not plot 2 series with different data points ? [message #514752 is a reply to message #514671] Tue, 16 February 2010 09:40 Go to previous messageGo to next message
When you post the csv explain how you want the chart to look.
Jason
> thanks again
Re: Why can I not plot 2 series with different data points ? [message #515245 is a reply to message #514752] Thu, 18 February 2010 04:43 Go to previous messageGo to next message
Hi Jason
I am adding the datasets here. The first one is a light curve with phase on x axis, and magnitude on Y. The second one is a model of the light curve e.g. modeled phase on x-axis, and modeled magnitude on Y.
Naturally model has much more data points as otherwise the fitting would not look good.
And what I need to do is to plot these 2 curves in superimposed style.
Thanks a lot for help.
Dataset 1:
phase array =
Folded phases:
[0.0, 0.017531390919086138, 0.05560741622402256, 0.05869382590987484, 0.060309646559399424, 0.06992341398800736, 0.09161709399602014, 0.09171333034093404, 0.0970098497299489, 0.10716578773226558, 0.10902671499573666, 0.11106038560924453, 0.12236023791660341, 0.16080356822562322, 0.1638899779114755, 0.19683602133102804, 0.20079350599761162, 0.2143697889936257, 0.216183076612701, 0.2297014069844374, 0.23660397605128194, 0.2796890968411272, 0.28699781035873884, 0.29772989472941636, 0.3021186655648739, 0.30606311899735644, 0.3116589719886564, 0.3196627028614754, 0.3291570734668292, 0.3349710199841822, 0.34897480673774, 0.36453656191279876, 0.37429470399302534, 0.3785112301340738, 0.39770298834014634, 0.402926046731017, 0.40569899691694994, 0.4074617395627629, 0.4150898339930931, 0.41685512398357577, 0.4169031216121684, 0.4239885834208993, 0.43739748204889356, 0.45417095873934066, 0.4561788079991001, 0.46864373645141216, 0.46958579191811106, 0.4794173949964818, 0.4807029858465338, 0.4838543041453253, 0.49482247397875645, 0.5030460623380353, 0.5105278439144673, 0.5149958366435369, 0.5204329079976634, 0.5291112744243558, 0.5477986769980054, 0.5613749599940195, 0.5616921048613824, 0.5857522158384837, 0.6001655479833268, 0.6083287065585187, 0.6394157709940256, 0.6529948289996061, 0.6669617178611272, 0.6704527589138669, 0.6959065167333085, 0.7135248585601194, 0.721226413995275, 0.739125672355908, 0.7446346983357147, 0.7497646802344611, 0.7639082926058811, 0.7755019889191792, 0.7845495750388946, 0.8012495907311975, 0.81533948152141, 0.8166644239099679, 0.8264960269950198, 0.827487773845814, 0.8499777723336037, 0.8503314168269483, 0.8538617959953619, 0.8674613798661621, 0.8691044446074817, 0.8897457270404951, 0.9204621725248665, 0.9329043088418472, 0.947023796980751, 0.9550400335596546, 0.9556010298333745, 0.9589844869988184, 0.9646538009882625]
magnitude array =
[6.213500022888184, 6.289999961853027, 6.335899829864502, 6.269100189208984, 6.322500228881836, 6.303899765014648, 6.2789998054504395, 6.108500003814697, 6.304500102996826, 6.264500141143799, 6.210000038146973, 6.212100028991699, 6.243199825286865, 6.24370002746582, 6.220699787139893, 6.092400074005127, 6.092599868774414, 6.200799942016602, 6.044099807739258, 6.030300140380859, 6.045599937438965, 6.119200229644775, 6.152299880981445, 6.104899883270264, 6.089600086212158, 6.156099796295166, 6.019599914550781, 6.212399959564209, 6.091000080108643, 6.049099922180176, 6.120299816131592, 6.128300189971924, 6.144999980926514, 6.055799961090088, 6.224899768829346, 6.087699890136719, 6.15310001373291, 6.074399948120117, 6.170000076293945, 6.076200008392334, 6.120999813079834, 6.098599910736084, 6.142499923706055, 6.133900165557861, 6.1971001625061035, 6.23960018157959, 6.146699905395508, 6.150000095367432, 6.272900104522705, 6.107900142669678, 6.204699993133545, 6.2846999168396, 6.186800003051758, 6.192599773406982, 6.1844000816345215, 6.188199996948242, 6.2866997718811035, 6.2332000732421875, 6.275199890136719, 6.297399997711182, 6.267199993133545, 6.215400218963623, 6.230400085449219, 6.321199893951416, 6.2982001304626465, 6.2378997802734375, 6.2606000900268555, 6.2967000007629395, 6.257400035858154, 6.326099872589111, 6.320499897003174, 6.289299964904785, 6.340099811553955, 6.279300212860107, 6.347400188446045, 6.306000232696533, 6.3765997886657715, 6.2947998046875, 6.304100036621094, 6.326900005340576, 6.305300235748291, 6.3221001625061035, 6.317999839782715, 6.253600120544434, 6.357500076293945, 6.346199989318848, 6.377399921417236, 6.2453999519348145, 6.3566999435424805, 6.365499973297119, 6.242000102996826, 6.2505998611450195, 6.356500148773193]
Dataset 2:
phase array =
[0.0, 0.0020, 0.0040, 0.0060, 0.0080, 0.01, 0.012, 0.014, 0.016, 0.018, 0.02, 0.022, 0.024, 0.026, 0.028, 0.03, 0.032, 0.034, 0.036, 0.038, 0.04, 0.042, 0.044, 0.046, 0.048, 0.05, 0.052, 0.054, 0.056, 0.058, 0.06, 0.062, 0.064, 0.066, 0.068, 0.07, 0.072, 0.074, 0.076, 0.078, 0.08, 0.082, 0.084, 0.086, 0.088, 0.09, 0.092, 0.094, 0.096, 0.098, 0.1, 0.102, 0.104, 0.106, 0.108, 0.11, 0.112, 0.114, 0.116, 0.118, 0.12, 0.122, 0.124, 0.126, 0.128, 0.13, 0.132, 0.134, 0.136, 0.138, 0.14, 0.142, 0.144, 0.146, 0.148, 0.15, 0.152, 0.154, 0.156, 0.158, 0.16, 0.162, 0.164, 0.166, 0.168, 0.17, 0.172, 0.174, 0.176, 0.178, 0.18, 0.182, 0.184, 0.186, 0.188, 0.19, 0.192, 0.194, 0.196, 0.198, 0.2, 0.202, 0.204, 0.206, 0.208, 0.21, 0.212, 0.214, 0.216, 0.218, 0.22, 0.222, 0.224, 0.226, 0.228, 0.23, 0.232, 0.234, 0.236, 0.238, 0.24, 0.242, 0.244, 0.246, 0.248, 0.25, 0.252, 0.254, 0.256, 0.258, 0.26, 0.262, 0.264, 0.266, 0.268, 0.27, 0.272, 0.274, 0.276, 0.278, 0.28, 0.282, 0.284, 0.286, 0.288, 0.29, 0.292, 0.294, 0.296, 0.298, 0.3, 0.302, 0.304, 0.306, 0.308, 0.31, 0.312, 0.314, 0.316, 0.318, 0.32, 0.322, 0.324, 0.326, 0.328, 0.33, 0.332, 0.334, 0.336, 0.338, 0.34, 0.342, 0.344, 0.346, 0.348, 0.35, 0.352, 0.354, 0.356, 0.358, 0.36, 0.362, 0.364, 0.366, 0.368, 0.37, 0.372, 0.374, 0.376, 0.378, 0.38, 0.382, 0.384, 0.386, 0.388, 0.39, 0.392, 0.394, 0.396, 0.398, 0.4, 0.402, 0.404, 0.406, 0.408, 0.41, 0.412, 0.414, 0.416, 0.418, 0.42, 0.422, 0.424, 0.426, 0.428, 0.43, 0.432, 0.434, 0.436, 0.438, 0.44, 0.442, 0.444, 0.446, 0.448, 0.45, 0.452, 0.454, 0.456, 0.458, 0.46, 0.462, 0.464, 0.466, 0.468, 0.47, 0.472, 0.474, 0.476, 0.478, 0.48, 0.482, 0.484, 0.486, 0.488, 0.49, 0.492, 0.494, 0.496, 0.498, 0.5, 0.502, 0.504, 0.506, 0.508, 0.51, 0.512, 0.514, 0.516, 0.518, 0.52, 0.522, 0.524, 0.526, 0.528, 0.53, 0.532, 0.534, 0.536, 0.538, 0.54, 0.542, 0.544, 0.546, 0.548, 0.55, 0.552, 0.554, 0.556, 0.558, 0.56, 0.562, 0.564, 0.566, 0.568, 0.57, 0.572, 0.574, 0.576, 0.578, 0.58, 0.582, 0.584, 0.586, 0.588, 0.59, 0.592, 0.594, 0.596, 0.598, 0.6, 0.602, 0.604, 0.606, 0.608, 0.61, 0.612, 0.614, 0.616, 0.618, 0.62, 0.622, 0.624, 0.626, 0.628, 0.63, 0.632, 0.634, 0.636, 0.638, 0.64, 0.642, 0.644, 0.646, 0.648, 0.65, 0.652, 0.654, 0.656, 0.658, 0.66, 0.662, 0.664, 0.666, 0.668, 0.67, 0.672, 0.674, 0.676, 0.678, 0.68, 0.682, 0.684, 0.686, 0.688, 0.69, 0.692, 0.694, 0.696, 0.698, 0.7, 0.702, 0.704, 0.706, 0.708, 0.71, 0.712, 0.714, 0.716, 0.718, 0.72, 0.722, 0.724, 0.726, 0.728, 0.73, 0.732, 0.734, 0.736, 0.738, 0.74, 0.742, 0.744, 0.746, 0.748, 0.75, 0.752, 0.754, 0.756, 0.758, 0.76, 0.762, 0.764, 0.766, 0.768, 0.77, 0.772, 0.774, 0.776, 0.778, 0.78, 0.782, 0.784, 0.786, 0.788, 0.79, 0.792, 0.794, 0.796, 0.798, 0.8, 0.802, 0.804, 0.806, 0.808, 0.81, 0.812, 0.814, 0.816, 0.818, 0.82, 0.822, 0.824, 0.826, 0.828, 0.83, 0.832, 0.834, 0.836, 0.838, 0.84, 0.842, 0.844, 0.846, 0.848, 0.85, 0.852, 0.854, 0.856, 0.858, 0.86, 0.862, 0.864, 0.866, 0.868, 0.87, 0.872, 0.874, 0.876, 0.878, 0.88, 0.882, 0.884, 0.886, 0.888, 0.89, 0.892, 0.894, 0.896, 0.898, 0.9, 0.902, 0.904, 0.906, 0.908, 0.91, 0.912, 0.914, 0.916, 0.918, 0.92, 0.922, 0.924, 0.926, 0.928, 0.93, 0.932, 0.934, 0.936, 0.938, 0.94, 0.942, 0.944, 0.946, 0.948, 0.95, 0.952, 0.954, 0.956, 0.958, 0.96, 0.962, 0.964, 0.966, 0.968, 0.97, 0.972, 0.974, 0.976, 0.978, 0.98, 0.982, 0.984, 0.986, 0.988, 0.99, 0.992, 0.994, 0.996, 0.998, 1.0]
magnitude array =
[6.238234786497262, 6.2393397988124555, 6.240429826166061, 6.241504829807738, 6.242564780847432, 6.243609660170966, 6.244639458349409, 6.245654175542306, 6.24665382139484, 6.247638414929006, 6.248607984428889, 6.24956256732013, 6.25050221004367, 6.251426967923875, 6.252336905031133, 6.253232094039036, 6.254112616076239, 6.254978560570259, 6.255830025100556, 6.256667115217779, 6.257489944287115, 6.2582986333123785, 6.259093310758405, 6.259874112368962, 6.260641180980319, 6.261394666330592, 6.262134724865013, 6.262861519537259, 6.263575219606981, 6.2642760004336795, 6.264964043267062, 6.265639535034049, 6.266302668122564, 6.266953640162258, 6.267592653802338, 6.26821991648664, 6.268835640226105, 6.269440041368836, 6.270033340367858, 6.270615761546792, 6.271187532863563, 6.271748885672328, 6.272300054483785, 6.272841276724036, 6.2733727924921485, 6.273894844316614, 6.274407676910847, 6.27491153692791, 6.275406672714615, 6.275893334065199, 6.276371771974714, 6.276842238390757, 6.277304985973095, 6.277760267837826, 6.278208337317692, 6.278649447715072, 6.2790838520572985, 6.27951180285289, 6.279933551848858, 6.28034934978926, 6.280759446175163, 6.281164089026187, 6.281563524643774, 6.281957997376374, 6.282347749386677, 6.282733020421079, 6.283114047581517, 6.283491065099838, 6.283864304114871, 6.284233992452323, 6.284600354407682, 6.28496361053225, 6.285323977422473, 6.285681667512699, 6.286036888871511, 6.286389845001773, 6.28674073464453, 6.287089751586887, 6.287437084474016, 6.287782916625397, 6.288127425855443, 6.288470784298614, 6.288813158239149, 6.289154707945536, 6.289495587509822, 6.28983594469075, 6.290175920767648, 6.290515650388116, 6.290855261432352, 6.2911948748771716, 6.291534604666611, 6.291874557588101, 6.29221483315426, 6.292555523490427, 6.2928967132279805, 6.293238479403543, 6.293580891364123, 6.293924010678281, 6.2942678910533605, 6.294612578258868, 6.294958110056031, 6.295304516133612, 6.295651818049999, 6.296000029181636, 6.296349154677823, 6.296699191421918, 6.2970501279989755, 6.297401944669849, 6.297754613351771, 6.298108097605433, 6.298462352628585, 6.298817325256148, 6.299172953966857, 6.299529168896432, 6.299885891857259, 6.300243036364606, 6.300600507669311, 6.3009582027969815, 6.301316010592437, 6.3016738117765785, 6.302031478997701, 6.302388876901142, 6.30274586219927, 6.303102283748977, 6.303457982635398, 6.3038127922618346, 6.304166538445807, 6.304519039521193, 6.304870106446374, 6.305219542918327, 6.305567145492605, 6.3059127037091045, 6.306256000223562, 6.306596810944688, 6.306934905176855, 6.307270045768246, 6.3076019892643735, 6.307930486066865, 6.308255280597422, 6.308576111466845, 6.308892711649014, 6.309204808659709, 6.309512124740176, 6.309814377045291, 6.310111277836227, 6.310402534677486, 6.310687850638173, 6.310966924497385, 6.311239450953573, 6.311505120837757, 6.311763621330441, 6.312014636182097, 6.312257845936271, 6.312492928159994, 6.312719557669219, 6.3129374067653945, 6.313146145470761, 6.313345441767157, 6.313534961837331, 6.313714370308629, 6.313883330498878, 6.314041504664312, 6.31418855424938, 6.314324140138274, 6.314447922908001, 6.314559563082846, 6.314658721390055, 6.314745059016566, 6.314818237866623, 6.314877920820103, 6.314923771991381, 6.314955456988579, 6.314972643172994, 6.314974999918577, 6.314962198871253, 6.314933914207938, 6.314889822895057, 6.314829604946414, 6.314752943680234, 6.314659525975191, 6.31454904252528, 6.3144211880933385, 6.314275661763067, 6.314112167189355, 6.31393041284678, 6.313730112276075, 6.313510984329194, 6.3132727534082775, 6.313015149709487, 6.312737909456922, 6.3124407751372775, 6.312123495730811, 6.31178582693916, 6.31142753140988, 6.311048378957511, 6.310648146781062, 6.31022661967773, 6.309783590252731, 6.3093188591250895, 6.308832235129245, 6.308323535512331, 6.3077925861270066, 6.307239221619686, 6.306663285614048, 6.3060646308896935, 6.305443119555825, 6.304798623219827, 6.304131023150622, 6.3034402104367, 6.3027260861386925, 6.301988561436388, 6.301227557770089, 6.300443006976195, 6.299634851416927, 6.298803044104082, 6.297947548816738, 6.297068340212817, 6.296165403934425, 6.295238736706871, 6.294288346434534, 6.293314252274272, 6.292316484734127, 6.291295085733785, 6.290250108674125, 6.2891816184969365, 6.28808969173787, 6.286974416572581, 6.285835892856024, 6.284674232154848, 6.283489557772872, 6.28228200476959, 6.281051719971708, 6.27979886197765, 6.278523601155053, 6.2772261196312185, 6.275906611276511, 6.274565281680698, 6.273202348122246, 6.271818039530547, 6.27041259644112, 6.268986270943767, 6.267539326623718, 6.266072038495786, 6.264584692931555, 6.263077587579621, 6.2615510312789455, 6.260005343965329, 6.258440856571071, 6.256857910917863, 6.255256859602943, 6.253638065878594, 6.252001903525037, 6.250348756716774, 6.24867901988807, 6.246993097564053, 6.24529140424133, 6.243574364206632, 6.2418424113771005, 6.240095989128954, 6.238335550120175, 6.236561556107309, 6.234774477756479, 6.23297479444872, 6.231162994079732, 6.229339572854175, 6.227505035074607, 6.225659892925188, 6.223804666250275, 6.221939882328016, 6.220066075639095, 6.21818378763073, 6.216293566476082, 6.21439596682919, 6.212491549575585, 6.210580881578724, 6.208664535422372, 6.206743089149109, 6.2048171259950715, 6.2028872341211265, 6.200954006340584, 6.199018039843648, 6.1970799359187305, 6.19514029967081, 6.1931997397369924, 6.191258867999422, 6.189318299295743, 6.1873786511272435, 6.185440543371339, 6.18350459795974, 6.181571438619553, 6.17964169054803, 6.177715980118237, 6.175794934576991, 6.173879181741697, 6.171969349696269, 6.170066066486321, 6.168169959813783, 6.166281656731154, 6.1644017833355305, 6.162530964462632, 6.160669823380965, 6.1588189814863314, 6.156979057996846, 6.155150669648647, 6.153334430392477, 6.151530951091313, 6.1497408392192225, 6.147964698561619, 6.146203128917107, 6.144456725801067, 6.142726080151178, 6.141011778035042, 6.139314400360078, 6.137634522585859, 6.13597271443907, 6.134329539631237, 6.132705555579407, 6.131101313129944, 6.129517356285593, 6.127954221935974, 6.126412439596799, 6.124892531127172, 6.123395010502245, 6.121920383538344, 6.120469147648152, 6.119041791595078, 6.117638795252096, 6.11626062936524, 6.114907755321875, 6.113580624923863, 6.1122796801657975, 6.111005353018398, 6.109758065217212, 6.108538228056744, 6.107346242190126, 6.106182497434461, 6.105047372581935, 6.10394123521682, 6.102864441538475, 6.1018173361904395, 6.100800252095723, 6.099813510298397, 6.098857419811555, 6.097932277471764, 6.0970383678000575, 6.09617596286957, 6.09534532217989, 6.094546692538187, 6.093780307947202, 6.093046389500149, 6.092345145282593, 6.091676770281363, 6.091041446300542, 6.090439341884597, 6.089870612250511, 6.089335399217808, 6.088833831164702, 6.088366022972407, 6.087932075986424, 6.087532077983178, 6.087166103144002, 6.08683421203646, 6.086536451603036, 6.0862728551571665, 6.086043442386643, 6.0858482193643555, 6.085687178566383, 6.085560298897401, 6.085467545723405, 6.085408870911702, 6.085384212878174, 6.085393496641745, 6.085436633886045, 6.085513523028207, 6.085624049294778, 6.085768084804656, 6.085945488659039, 6.086156107038303, 6.086399773305748, 6.086676308118166, 6.0869855195431235, 6.087327203182926, 6.087701142305148, 6.088107107979679, 6.08854485922217, 6.089014143143804, 6.089514695107309, 6.090046238889079, 6.090608486845417, 6.09120114009423, 6.091823888683666, 6.092476411785125, 6.093158377882623, 6.0938694449694575, 6.094609260750208, 6.095377462847965, 6.09617367901665, 6.096997527358293, 6.097848616545139, 6.098726546046447, 6.099630906359828, 6.100561279247004, 6.101517237973808, 6.102498347554323, 6.103504164998958, 6.104534239566353, 6.105588113018932, 6.1066653198819605, 6.10776538770593, 6.108887837332142, 6.110032183161292, 6.111197933424915, 6.112384590459515, 6.1135916509832136, 6.114818606374754, 6.116064942954675, 6.117330142268507, 6.118613681371795, 6.119915033116793, 6.121233666440638, 6.12256904665485, 6.123920635731421, 6.125287892612528, 6.126670273475818, 6.128067232045412, 6.129478219880836, 6.130902686670706, 6.132340080526478, 6.13378984827611, 6.13525143575744, 6.136724288111118, 6.138207850072906, 6.139701566265171, 6.141204881487409, 6.142717241005607, 6.14423809084028, 6.145766878053018, 6.147303051031359, 6.148846059771816, 6.150395356160914, 6.151950394254038, 6.153510630551947, 6.155075524274789, 6.15664453763344, 6.158217136098025, 6.159792788663458, 6.16137096811183, 6.1629511512715105, 6.164532819272805, 6.166115457800004, 6.167698557339705, 6.169281613425229, 6.170864126877021, 6.172445604038868, 6.174025557009825, 6.175603503866416, 6.177178968906621, 6.178751482836455, 6.1803205830044385, 6.181885813604759, 6.1834467258806445, 6.185002878322555, 6.186553836861078, 6.188099175054438, 6.189638474270484, 6.191171323863088, 6.192697321342829, 6.194216072541887, 6.19572719177305, 6.197230301982737, 6.198725034897988, 6.2002110311672975, 6.201687940495249, 6.203155421770878, 6.204613143189677, 6.2060607823692004, 6.207498026458203, 6.208924572239258, 6.210340126224806, 6.21174440474659, 6.213137134038432, 6.214518050312315, 6.215886899827746, 6.2172434389543545, 6.2185874342277225, 6.219918662398404, 6.221236910474144, 6.222541975755261, 6.223833665863204, 6.225111798758028, 6.226376202770316, 6.227626716583627, 6.228863189252864, 6.230085480194435, 6.231293459173925, 6.232487006287001, 6.233666011933604, 6.23483037678543, 6.235980011746766, 6.237114837908693, 6.238234786496727]
Re: Why can I not plot 2 series with different data points ? [message #515340 is a reply to message #515245] Thu, 18 February 2010 09:05 Go to previous message
Neerahi,
Charts can only be tied to one dataset. If you are getting this data
into BIRT from csv files, can you create one csv file with this format:
phase1, mag1, phase2, mag2 newline
You can build joint datasets that combine datasets, but for csv this is
a bit slower. So you could have
file one
phase1, mag1 newline
file two
phase2, mag2, newline
Can you create one of the scenarios above and email to me at
jasonweathersby at windstream dot net?
Jason
neerahi wrote:
> Hi Jason
> not look good.
> Dataset 1:
> phase array = Folded phases:
> magnitude array =
> Dataset 2:
> phase array =
> magnitude array =
Previous Topic:BIRT - Header Content Manipulation
Next Topic:How to set initial window size?
Current Time: Sat Jul 19 02:03:24 EDT 2025
Powered by FUDForum. Page generated in 0.05629 seconds
