Home » Archived » M2M (model-to-model transformation) » [ATL] How to discard source elements or translate them to 'nothing'?
[ATL] How to discard source elements or translate them to 'nothing'? [message #514049] Fri, 12 February 2010 04:56 Go to next message
Hello all,
In my ATL transformation I use matched rules for all source elements. I assign source element features to target element features, which are automatically matched by matched rules by ATL. However, some source element features (references to other source elements) are to be discarded. I simply don't assign them to target element features. However, since they are source elements, ATL automatically matches them using the matched rules, and generates target elements that end up in the root of the output. This is valid ATL behavior, but I need a way to exclude those elements from the output.
I don't think it is possible to remove such elements after they are created (within the same ATL transformation), so I need a way to make sure they are not created in the first place. Is there a way to inform ATL that certain elements from the input should be discarded (not matched by matched rules)?
I tried manually translating them to nothing (so that they are already matched, but there is no output, or they are matched and the output is something like an empty string that I add to some other feature to get rid of it), but couldn't figure out how to do that using lazy rules, called rules, or something like that...
Does anyone know a way to do this in ATL? Any help would be greatly appreciated!
Dennis
Re: [ATL] How to discard source elements or translate them to 'nothing'? [message #514052 is a reply to message #514049] Fri, 12 February 2010 05:14 Go to previous messageGo to next message
You can specify a filter on each rule to indicate which elements should be transformed or not.
from s : XX!YY (filter here)
Re: [ATL] How to discard source elements or translate them to 'nothing'? [message #514056 is a reply to message #514052] Fri, 12 February 2010 05:32 Go to previous messageGo to next message
Sylvain EVEILLARD wrote on Fri, 12 February 2010 11:14
Yes, obviously. But this would be a complicated constraint to specify. Is there no other way to do this?
Re: [ATL] How to discard source elements or translate them to 'nothing'? [message #514066 is a reply to message #514049] Fri, 12 February 2010 05:56 Go to previous messageGo to next message
One way or the other you'll have to specify somewhere which elements you want to transform...
Re: [ATL] How to discard source elements or translate them to 'nothing'? [message #514082 is a reply to message #514066] Fri, 12 February 2010 06:34 Go to previous messageGo to next message
Sylvain EVEILLARD wrote on Fri, 12 February 2010 11:56
Yes, but I was wondering if there is a way to specify the elements you DON'T want to transform, instead of specifying the elements you DO want to transform.
Re: [ATL] How to discard source elements or translate them to 'nothing'? [message #514096 is a reply to message #514049] Fri, 12 February 2010 07:39 Go to previous messageGo to next message
That's basically the same.
Make a Sequence of the elements you don't want to transform (seq) and you can use thisModule.seq->excludes(s) as filter.
Re: [ATL] How to discard source elements or translate them to 'nothing'? [message #514105 is a reply to message #514096] Fri, 12 February 2010 08:03 Go to previous messageGo to next message
OK, I'll try that. Thanks!
Re: [ATL] How to discard source elements or translate them to 'nothing'? [message #515266 is a reply to message #514049] Thu, 18 February 2010 05:17 Go to previous messageGo to next message
is it way too trivial to just define a filter for the elements you don't want, and then go
from s : XX!YY (not (filter))
? That would do what you want, right?
[Updated on: Thu, 18 February 2010 05:45] by Moderator
Re: [ATL] How to discard source elements or translate them to 'nothing'? [message #515272 is a reply to message #515266] Thu, 18 February 2010 05:32 Go to previous messageGo to next message
Let me rephrase my problem:
a rule like :
rule RULE1 {
from s : XX!YY
to ...
is required to copy all XX!YY instances, except for a few instances.
Then I have another rule:
rule SOMERULE {
from s : XX!ZZ
to t : AA!BB(
a <- s.a,
b <- s.b,
y <- Sequence{})
where the instances of XX!YY are not assigned to t.y. So, almost all XX!YY instances must be matched by the top level rule, except the XX!YY instances from SOMERULE s.y, which are discarded and not added to t.y. I would like to specify that they should not be translated, in the SOMERULE rule. Instead, I could come up with a filter to apply to the RULE1 rule, but it would be complicated, and I would rather have it localized to the SOMERULE rule.
My question is whether it is possible using some kind of lazy rule, or whatever, to translate the XX!YY instances of s.y such that they are already translated and are no longer matched by the RULE1 rule, as ATL no longer tries to match them (they are already matched)?
Hope this makes the question clearer?
Dennis
Re: [ATL] How to discard source elements or translate them to 'nothing'? [message #515279 is a reply to message #515272] Thu, 18 February 2010 05:47 Go to previous messageGo to next message
> a rule like :
> rule RULE1 {
> from s : XX!YY
> to ...
> rule SOMERULE {
> from s : XX!ZZ
> to t : AA!BB(
> a <- s.a,
> b <- s.b,
> y <- Sequence{})
> Dennis
You should try to define your need on a white board using mathematical
sets (areas) to see which filters (boolean expressions) go with each rule.
Cordialement
Vincent MAHÉ
Ingénieur plate-forme - Cesar/Artemisia - Équipe Espresso
IRISA-INRIA, Campus de Beaulieu, 35042 Rennes cedex, France
Tél: +33 (0) 2 99 84 71 00, Fax: +33 (0) 2 99 84 71 71
Re: [ATL] How to discard source elements or translate them to 'nothing'? [message #515281 is a reply to message #514049] Thu, 18 February 2010 05:59 Go to previous messageGo to next message
I would do :
helper context XX!ZZ def : filter : Boolean =
filter rule here
helper def : allSY : Sequence(XX!YY) =
XX!ZZ.allInstances()
->select(e | e.filter)
->collect(e | e.y)
->flatten()
helper context XX!YY def : filter : Boolean =
thisModule.allSY
->excludes(self)
and add s.filter as filter to both rules.
Re: [ATL] How to discard source elements or translate them to 'nothing'? [message #515893 is a reply to message #515281] Mon, 22 February 2010 02:13 Go to previous message
Thanks, I guess that'll do.
Previous Topic:CFP: 2nd International Workshop on Model Transformation with ATL (MtATL 2010)
Next Topic:ATL
Current Time: Wed Jul 23 07:31:06 EDT 2025
Powered by FUDForum. Page generated in 0.10902 seconds
