Home » Archived » BIRT » getting the DE API to work
getting the DE API to work [message #51353] Fri, 24 June 2005 13:59 Go to next message
Originally posted by: tony.tony.com
I have playing with this issue for sometime now and still have not figured
it out. I have read the design and the report engine integration. I have
gotten the files off of the cvs and into my workspace. This is where i am
lost. i have 2 folders now org.eclipse.birt.model and
org.eclipse.birt.core. What do i do from there? i have tried importing
the classes but it does not seem to find them. thanks for helping
Re: getting the DE API to work [message #51608 is a reply to message #51353] Mon, 27 June 2005 11:45 Go to previous message
Originally posted by: none.none.com
Hi Tony,
Is your project a simple java project or a plugin project?
- If it is a simple java project, you need your classpath to reference the
jar files of the core and model (model.jar and core.jar) as well as their
dependencies (check other jars under the plugin folder structure of
core/model). If you downloaded the source from CVS, you will have to build
the model/core jars. If you got it from the download area, they should
already be there.
- If it is a plugin project, open plugin.xml and add core and model plugin
as required plug-ins under the dependencies tab.
Hope this helps,
David
"Tony" <tony@tony.com> wrote in message
news:d9c95e1cb37cb14227eee2e05fa265de$1@www.eclipse.org...
Previous Topic:Finding the API Docs
Next Topic:import packages
Current Time: Tue Nov 04 23:32:37 EST 2025
Powered by FUDForum. Page generated in 0.03715 seconds
